Iris BTM MB 14214-1 bios dump
    looking for the bios dump of this model..thanks..
    Dell Inspiron 14 (Iris BTM MB 14214-1)
    Never stop LEARNING because life never stops TEACHING!
    Re: Iris BTM MB 14214-1 bios dump
    Upload your backup, maybe someone will help you.
      here is the backup bios bin of my laptop hope someone can help me.. thanks again.
        i got hold of this bios dump from the net hope this fix it.. thanks for the help guys.. i post the progress here...
        here is the bios dump i got from the net hope this helps.
          That's strange, I can't extract from web update...need to learn how do that
            update: flash the bios with dump from the net.
            still the same symptoms:
            no video
            when you put the power adapter the cpu fan spins and turn on all the power with led light on,
            after that the led light will die together with the cpu fan but all the power are present, the 3.3vdc, 5.1vdc 1.35vdc,
            2.7vdc in the battery section since there is on battery attached
            1.8vdc s5 VCC for bios 25Q64FWSIG, cpu power is .9vdc .8 vdc and 1vdc . because the cpu fan die the cpu is heating up. any suggestion.
            since the model schematic is not available. i can't get any schematics that is identical to this model. any help or suggestion guys.. thanks
              Try this bios extracted from dell update,with a clean TXE area.This has no DMI info included.
                Check PM .
                  please test and update us
                    thanks for the bios dump..
                    i tried smdflea and ziggster given bios dump
                    still the same symptoms.. i think the bios ic is the failed component cause when i verify the written data the bios programmer gives a error in address 0000 like that. ill try to buy the 25Q64FWsig bios and ill keep you posted for the progress. thanks a lot guys..
                      i have same problem 8beep sound only come no display.bios reflash.same problem help mw
                        This bios chip is 1.8V. have you taken that into consideration??
                          thanks sorry for the very late response. i already fixed it replacing the bios eprom. i program it using adapter for 1.8 volts with my ezpro2010. thanks for the help guys...
                            which one bios file used?
                              BRO NO CHARGING indicate,posible bios or not.
                              bios tested for me, thx
                                Need your help guys! DELL IRIS BTM MB 14214-1 PWB 1JTN6 REV A00 bios or clean ME
                                all AO or ALW voltage present 3.3v and 5v 1.8v VCC present in EEPROM , 3.3v VCC present in NPCE985PB10 I/O,
                                power button pin 2 has 3.3v and will drop to zero when power button is pressed.
                                Model # Dell Inspiron 14 3451 14214
                                SERVICE TAG SN: BSQND32
                                attached is my extracted bios.
                                Thanks again in advance
                                  Inspiron 3451
                                  Become a Badcaps supporter
                                  Thanks to all supporters.
                                    Originally posted by hoaca388 View Post
                                    Inspiron 3451
                                    Thank you hoaca388. gonna try this bin file..
                                      Inspiron 3451
                                      thank you very much.. your bios works..HOw did you repair my bios?
