Iris BTM MB 14214-1 bios dump
  • Duranitron
    • Jul 2014
    • 544
    • Philippines
    looking for the bios dump of this model..thanks..
    Dell Inspiron 14 (Iris BTM MB 14214-1)
    Never stop LEARNING because life never stops TEACHING!
  • on/off
    • Oct 2016
    • 333
    • Indonesia
    Re: Iris BTM MB 14214-1 bios dump
    Upload your backup, maybe someone will help you.
    • Duranitron
      • Jul 2014
      • 544
      • Philippines
      here is the backup bios bin of my laptop hope someone can help me.. thanks again.
      • Duranitron
        • Jul 2014
        • 544
        • Philippines
        i got hold of this bios dump from the net hope this fix it.. thanks for the help guys.. i post the progress here...
        here is the bios dump i got from the net hope this helps.
        • on/off
          • Oct 2016
          • 333
          • Indonesia
          That's strange, I can't extract from web update...need to learn how do that
          • Duranitron
            • Jul 2014
            • 544
            • Philippines
            update: flash the bios with dump from the net.
            still the same symptoms:
            no video
            when you put the power adapter the cpu fan spins and turn on all the power with led light on,
            after that the led light will die together with the cpu fan but all the power are present, the 3.3vdc, 5.1vdc 1.35vdc,
            2.7vdc in the battery section since there is on battery attached
            1.8vdc s5 VCC for bios 25Q64FWSIG, cpu power is .9vdc .8 vdc and 1vdc . because the cpu fan die the cpu is heating up. any suggestion.
            since the model schematic is not available. i can't get any schematics that is identical to this model. any help or suggestion guys.. thanks
              • 21662
              Try this bios extracted from dell update,with a clean TXE area.This has no DMI info included.
                • 21662
                Check PM .
                • ziggster
                  • Feb 2019
                  • 72
                  • israel
                  please test and update us
                  • Duranitron
                    • Jul 2014
                    • 544
                    • Philippines
                    thanks for the bios dump..
                    i tried smdflea and ziggster given bios dump
                    still the same symptoms.. i think the bios ic is the failed component cause when i verify the written data the bios programmer gives a error in address 0000 like that. ill try to buy the 25Q64FWsig bios and ill keep you posted for the progress. thanks a lot guys..
                    • michelraj410@gmail.com
                      • Feb 2017
                      • 10
                      • india
                      i have same problem 8beep sound only come no display.bios reflash.same problem help mw
                      • mcplslg123
                        • Jun 2015
                        • 7262
                        • india
                        This bios chip is 1.8V. have you taken that into consideration??
                        • Duranitron
                          • Jul 2014
                          • 544
                          • Philippines
                          thanks sorry for the very late response. i already fixed it replacing the bios eprom. i program it using adapter for 1.8 volts with my ezpro2010. thanks for the help guys...
                          • skardi403
                            • Indonesia
                            which one bios file used?
                            • jimore
                              • Nov 2020
                              • 179
                              • mexico
                              BRO NO CHARGING indicate,posible bios or not.
                            • red_apache
                              • Mar 2014
                              • 9
                              • indonesia
                              bios tested for me, thx
                              • Duranitron
                                • Jul 2014
                                • 544
                                • Philippines
                                Need your help guys! DELL IRIS BTM MB 14214-1 PWB 1JTN6 REV A00 bios or clean ME
                                all AO or ALW voltage present 3.3v and 5v 1.8v VCC present in EEPROM , 3.3v VCC present in NPCE985PB10 I/O,
                                power button pin 2 has 3.3v and will drop to zero when power button is pressed.
                                Model # Dell Inspiron 14 3451 14214
                                SERVICE TAG SN: BSQND32
                                attached is my extracted bios.
                                Thanks again in advance
                                • hoaca388
                                  Badcaps
                                  • Jan 2022
                                  • 12268
                                  Inspiron 3451
                                  • Duranitron
                                    • Jul 2014
                                    • 544
                                    • Philippines
                                    Originally posted by hoaca388
                                    Inspiron 3451
                                    Thank you hoaca388. gonna try this bin file..
                                    • Duranitron
                                      • Jul 2014
                                      • 544
                                      • Philippines
                                      Inspiron 3451
                                      thank you very much.. your bios works..HOw did you repair my bios?
                                      • Habble7
                                        by Habble7
                                        Suspected Cause:
                                        Troubleshooting Attempts:
                                        05-22-2025, 07:28 AM
                                      • haitham sharabati
                                        [Request] Clean BIOS dump for HP 15-da2007ne (8XF55EA#ABV) - N4000 - BIOS Lock
                                        by haitham sharabati
                                        Hello engineers 😀,
                                        I’m kindly requesting a clean and unlocked BIOS dump for the following HP laptop, as it’s bricked after flashing SP152727. The system now keeps rebooting, and the original issue was an Administrator / Power-On Password that I can no longer access.😏
                                        🔧 Device Info:
                                        - Model: HP 15-da2007ne
                                        - Product Number: 8XF55EA#ABV
                                        - Serial Number: CND0338P0D
                                        - CPU: Intel Celeron N4000
                                        - EC/BIOS Chip: [Add chip number from the motherboard or BIOS chip]
                                        💀 Problem:😅
                                        - Device shows “Administrator Password”...
                                        08-07-2025, 04:54 AM
                                      • Citymin
                                        by Citymin
                                        S/N : 5RNK9FFT70...
                                        08-05-2025, 05:12 AM
                                      • DynaxSC
                                        by DynaxSC
                                        11-17-2023, 10:56 AM
                                      • greelidd
                                        K6604J Vivobook RTX 4070 BIOS Dump Request
                                        by greelidd
                                        Hi all! Tldr: need a bios dump (.bin format) for K6604J (rtx 4070 and i9-13980hx)
                                        Longer story: my vivobook stopped booting after i switched out the thermal paste. I think the BIOS got corrupted. Everything i tried didn’t work until finally i decided to buy a CH341A BIOS programmer and just send over the BIOS directly from another PC onto the BIOS chip. I connected fine and backed up the existing BIOS, but i can’t find a clean BIOS that’s a .bin format. And I tried using UEFI software to extract all the files from the ASUS BIOS .exe file and get to the .bin but it was a .302...
                                        09-01-2025, 06:14 PM
