Iris BTM MB 14214-1 bios dump
  • hoaca388
    Badcaps
    • Jan 2022
    • 12268
    Originally posted by Duranitron
    thank you very much.. your bios works..HOw did you repair my bios?
    That is a new file.
    • Duranitron
      • Jul 2014
      • 544
      • Philippines
      Originally posted by hoaca388
      That is a new file.
      ah ok. thank you very much for the help..
      • Habble7
        by Habble7
        Suspected Cause:
        Troubleshooting Attempts:
        05-22-2025, 07:28 AM
      • haitham sharabati
        by haitham sharabati
        Hello engineers 😀,
        🔧 Device Info:
        - Model: HP 15-da2007ne
        - Product Number: 8XF55EA#ABV
        - Serial Number: CND0338P0D
        - CPU: Intel Celeron N4000
        💀 Problem:😅
        08-07-2025, 04:54 AM
      • Citymin
        by Citymin
        S/N : 5RNK9FFT70...
        08-05-2025, 05:12 AM
      • DynaxSC
        by DynaxSC
        11-17-2023, 10:56 AM
      • greelidd
        K6604J Vivobook RTX 4070 BIOS Dump Request
        by greelidd
        Hi all! Tldr: need a bios dump (.bin format) for K6604J (rtx 4070 and i9-13980hx)
        Longer story: my vivobook stopped booting after i switched out the thermal paste. I think the BIOS got corrupted. Everything i tried didn’t work until finally i decided to buy a CH341A BIOS programmer and just send over the BIOS directly from another PC onto the BIOS chip. I connected fine and backed up the existing BIOS, but i can’t find a clean BIOS that’s a .bin format. And I tried using UEFI software to extract all the files from the ASUS BIOS .exe file and get to the .bin but it was a .302...
        09-01-2025, 06:14 PM
