MacBook Pro A1502 (820-3476-A) password
  • farouk_1994
    • Mar 2021
    • 399
    • algeria
    #61
    Originally posted by SMDFlea
    The serial number in the bios you posted is different, yours is C02P4AVWG3FK , it should beC02P4AVWG3QJ
    Use MacEfiToolkit to change it with software https://github.com/MuertoGB/MacEfiToolkit or watch piernovs video and edit with a hex editor.
    https://www.badcaps.net/forum/troubl...24#post1622424
    4.3. Apple
    For 2017 and older machines, serial number is stored in Fsys store of BIOS and can be edited with hexadecimal editor. Fsys checksum needs to be fixed afterwards
    Search for "ssn", edit the serial number, save, open dump in UEFITool, go to the Fsys store and write down the suggested checksum in the panel on the right. Checksum is 4 bytes at the end of the Fsys store, between one zone of 0x00 either Gaid or another zone of 0xFF, it must be written in reverse order (so last 2 characters from UEFITool must be written first).
    See: https://www.youtube.com/watch?v=poA8HByYqTM
    Yes i changed the SN at the end it's just as my signature but it is indeed his bios file
    • sanjiv16
      • Jul 2013
      • 52
      • philippines
      #62
      hi please help efi password
      MacBook A1502
      SN: C02T44L1FVH3
      EMC: 2835
      TIA
      • shiyab
        • Sep 2023
        • 1611
        • india
        #63
        MacBook A1502
        SN: C02T44L1FVH3
        EMC: 2835
        TIA
        TRY
        • sanjiv16
          • Jul 2013
          • 52
          • philippines
          #64
          Originally posted by shiyab
          TRY
          thank you so much sir
          • shiyab
            • Sep 2023
            • 1611
            • india
            #65
            OK thank
            • rabsonnjala
              mujahid
              • Apr 2021
              • 25
              • malawi
              #66
              UEFI Password removal needed . please help
              MacBook A1502
              SN: C02P50A1G3QR
              EMC: 2875​
              • shiyab
                • Sep 2023
                • 1611
                • india
                #67
                MacBook A1502
                SN: C02P50A1G3QR
                EMC: 2875​
                hi try
                  • 21936
                  MacBook A1502
                  SN: C02P50A1G3QR
                  EMC: 2875​
                  The bios is corrupt, use a different one and copy your serial number to it
                  • Mugi
                    • Feb 2022
                    • 13
                    #69
                    MacBook A1502
                    SN: C02MJEDRFGYY
                    EMC: 2678
                    • shiyab
                      • Sep 2023
                      • 1611
                      • india
                      #70
                      MacBook A1502
                      SN: C02MJEDRFGYY
                      EMC: 2678
                      try
                      • Mugi
                        • Feb 2022
                        • 13
                        #71
                        Thank you very much sir
                        • TECHO TN
                          • Jan 2024
                          • 68
                          • algeria
                          #72
                          Originally posted by peste
                          Re: MacBook Pro A1502 (820-3476-A) password
                          the password is deleted..if the bios is ok and you write without errors it should work...don't forget the PRAM reset..
                          Hello my friend
                          I have a macbook pro a1502 mid 2014
                          I removed the efi password but when i wanted to reinstall os i was surprised by an icloud pin
                          what should i do ?
                          • peste
                            • Dec 2016
                            • 13629
                            • ROMANIA
                            #73
                            Originally posted by TECHO TN
                            Hello my friend
                            what should i do ?
                            did you reset the PRAM??
                            • TECHO TN
                              • Jan 2024
                              • 68
                              • algeria
                              #74
                              No, i don't know how i only modified my bios dump to erase the efi pass than i soldered the bios chip in its place
                              • TECHO TN
                                • Jan 2024
                                • 68
                                • algeria
                                #75
                                Please sir
                                Can i upload my bios original dump to clear the efi pass and icloud pin ?
                                • TECHO TN
                                  • Jan 2024
                                  • 68
                                  • algeria
                                  #76
                                  Its ok friend, i solved the problem
                                  Thank you
                                  • curiositymaster
                                    • Apr 2021
                                    • 45
                                    • Nigeria
                                    #77
                                    Thank you
                                    You can help others who have the same problem in the future by posting how you solved yours. The last time I had this experience, I used another Macbook to securely erase the SSD and it worked afterwards.
                                    • TECHO TN
                                      • Jan 2024
                                      • 68
                                      • algeria
                                      #78
                                      Sure 😉
                                      i only resetthe pram
                                      • ddhlawi
                                        • Feb 2017
                                        • 169
                                        • algerian
                                        #79
                                        Hello
                                        I have mac Book pro Bios password
                                        A1502 EMC 2678
                                        Serial : C02LRMHRFH00
                                        • danito
                                          • Jun 2016
                                          • 1097
                                          • Romania
                                          #80
                                          Originally posted by ddhlawi
                                          Hello
                                          A1502 EMC 2678
                                          Try
                                          • mferna14
                                            Password removal on MacBook Pro A2159
                                            by mferna14
                                            Hi friends., I am working on MacBook Pro A2159 touchbar 2019. The old logic board was liquid spilled so I ordered another logic board from AE. Received it & all worked fine till I got to the Chinese login screen where the login screen password tobe entered. I tried to reset the password but it again gave me options which I do not know about the Apple ID. I formatted the onboard SSD. & wanted to change the startup boot sequence but in order to change it, again the password is needed for that too. Is there a way to get rid of this password?? The seller has not replied back past 2 days, how...
                                            05-13-2025, 04:16 PM
                                          • ritalo
                                            MacBook Air 13 2014 - Remove EFI password
                                            by ritalo
                                            I have a MacBook Air 13 inches 2014.
                                            I have set a EFI password and I can't remember it : now I want to reinstall macOS and I can't because the MacBook is asking for the password.
                                            I know how to remove the password with a usb programmer.
                                            I plug the usb programmer to the motherboard and to my pc with usb, I read the EFI and I save it to a file.
                                            Then I have to find this value in the file : $SVS because it indicate where is the password.
                                            But I can't find the value.
                                            I have attached the file​
                                            Thank...
                                            05-14-2024, 12:10 PM
                                          • Danielreinaa
                                            HELP need password bios Macbook A1706
                                            by Danielreinaa
                                            Hola chicos, espero estén bien, he estado buscando información para aprender a hacer eliminación de password EFI en macbooks.
                                            Actualmente tengo un problema con una macbook pro A1706 820-00923 SN:C02VD3GJHV2Q
                                            Si podrian ayudarme les agradeceria mucho o algun link para aprender a hacerlo y no volver a molestarles.
                                            gracias de antemano y que tengan una linda tarde, disculpen si estoy rompiendo alguna norma.
                                            Hi guys, I hope you are doing well, I have been looking for information to learn how to remove the EFI password on macbooks.
                                            09-07-2024, 03:47 PM
                                          • gbuniva
                                            MacBook A1502 (820-3476-A) Repair case with solution
                                            by gbuniva
                                            Hi everyone, I want to share my tech experience with a MacBook Pro A1502 late 2013 that won´t turn on.
                                            The computer arrived dead, when connected to Magsafe no lights on the connector.
                                            Here some Measures at some testpoints on de LB 820-3476-A :
                                            PP3V42_G3H 1.7V
                                            PPBUS_G3H = 0V
                                            PPVBAT_G3H_CHGR_RE = 0V
                                            PP3V3_S5 = 0V
                                            PP5V_S4 = 0V
                                            P5V1_SW = 5.5V
                                            PP3V3_S0SW_SSD =0V
                                            PP3V3_S0SW_SSD_FET =0V
                                            PPDCIN_G3H_INRUSH = 16.10V
                                            PPDCIN_G3H_CHGR = 16.10V
                                            PP5V_S5 - 0v
                                            PP3V3_S5 - 0v
                                            PP3V3_SUS - 0V
                                            PM_RSMRST_L - 0v...
                                            04-09-2025, 07:11 PM
                                          • Nopslide
                                            by Nopslide
                                            04-01-2024, 04:27 PM
