MacBook Pro A1502 (820-3476-A) password
  • master_clone33
    • Aug 2021
    • il
    #41
    Re: MacBook Pro A1502 (820-3476-A) password
    Hello Peste, heres the original file i got.. only problem is that when i read and saved the original, i used SOP8 instead of WSON8... hope it could still work.
    Thank you.
    • peste
      • 13581
      • ROMANIA
      #42
      Thank you.
      the password is deleted..if the bios is ok and you write without errors it should work...don't forget the PRAM reset..
      • ajbernasko
        • Mar 2022
        • 229
        • ghana
        #43
        Please I have A1502 emc 2678 board number 820-3476-A, does not show ssd in diskutil list command, but can boot with windows maybe there's an error somewhere please help me. chip is N25Q064A
        • ajbernasko
          • Mar 2022
          • 229
          • ghana
          #44
          please can someone help me you clean this file above for me ? Thank you
          • mrwab
            Banned
            • Jan 2014
            • 83
            • morocco
            #45
            try and replay
            • ajbernasko
              • Mar 2022
              • 229
              • ghana
              #46
              Originally posted by mrwab
              try and replay
              okay, my programmer cannot write this files, keeps giving me same address error 10h, even the back up file gives me same error. can I use any other like the SOP8 200mil with 64MB at 1.8V to write this file ?
              • ajbernasko
                • Mar 2022
                • 229
                • ghana
                #47
                Hi I was able to write the file but it is boot looping no post
                • ajbernasko
                  • Mar 2022
                  • 229
                  • ghana
                  #48
                  Please what do I need to know? I wrote new firmware for this macbook with board number 820-3476-a and gave me no image no cpu voltage, now i am trying to write back the old file and still give me no image no cpu volts as well
                  • ahmarzo
                    • Mar 2015
                    • 173
                    • india
                    #49
                    macbook a1502 password reset
                    please remove password from my backup macbook pro a1502 emc 2875 motherboard part number 820-3476-A.
                    • piszpunta
                      • Jan 2019
                      • 255
                      • poland
                      #50
                      Try
                      • ahmarzo
                        • Mar 2015
                        • 173
                        • india
                        #51
                        not working shows on battery charging icon when power button is pressed but not booting.
                        • peste
                          • 13581
                          • ROMANIA
                          #52
                          Re: macbook a1502 password reset
                          try..
                          • gokhan312
                            • 5
                            • türkiye
                            #53
                            THERE IS A PASSWORD WHEN OPENING UP. CAN ANYONE HELP ME REMOVE IT? PLEASE HELP
                              • 21874
                              Don`t post in ALL CAPS please.Post the serial number as per the rules.
                              RULES UPDATE for BIOS requests/offers AVOID BANNING, READ BEFORE POSTING
                              You MUST:
                              • Provide the full machine model number, serial number (or Service tag, SNID) and the board model number (see https://www.badcaps.net/forum/showthread.php?t=88758 ) ,The serial number, make, full model number, motherboard model and revision (except QR codes) must be written/typed at your request as per the rules. Not as a picture, part of the file name and so on.
                              • waseem nuaman
                                • Oct 2015
                                • 6
                                • Malta
                                #55
                                Hi good evening friends can someone remove password of MacBook a1502 please thanks
                                • waseem nuaman
                                  • Oct 2015
                                  • 6
                                  • Malta
                                  #56
                                  here is old bios with password
                                  • peste
                                    • 13581
                                    • ROMANIA
                                    #57
                                    post S/N, EMC, motherboard model, etc.
                                    • waseem nuaman
                                      • Oct 2015
                                      • 6
                                      • Malta
                                      #58
                                      S/no: C02P4AVWG3QJ
                                      • farouk_1994
                                        • Mar 2021
                                        • 398
                                        • algeria
                                        #59
                                        S/no: C02P4AVWG3QJ
                                        After reprogramme your chip press Alt+Command+P+R+powerbotton until it's reboot in order to reset Nvram
                                          • 21874
                                          The serial number in the bios you posted is different, yours is C02P4AVWG3FK , it should beC02P4AVWG3QJ
                                          Use MacEfiToolkit to change it with software https://github.com/MuertoGB/MacEfiToolkit or watch piernovs video and edit with a hex editor.
                                          https://www.badcaps.net/forum/troubl...24#post1622424
                                          4.3. Apple
                                          For 2017 and older machines, serial number is stored in Fsys store of BIOS and can be edited with hexadecimal editor. Fsys checksum needs to be fixed afterwards
                                          Search for "ssn", edit the serial number, save, open dump in UEFITool, go to the Fsys store and write down the suggested checksum in the panel on the right. Checksum is 4 bytes at the end of the Fsys store, between one zone of 0x00 either Gaid or another zone of 0xFF, it must be written in reverse order (so last 2 characters from UEFITool must be written first).
                                          See: https://www.youtube.com/watch?v=poA8HByYqTM​
                                          • mferna14
                                            Password removal on MacBook Pro A2159
                                            by mferna14
                                            Hi friends., I am working on MacBook Pro A2159 touchbar 2019. The old logic board was liquid spilled so I ordered another logic board from AE. Received it & all worked fine till I got to the Chinese login screen where the login screen password tobe entered. I tried to reset the password but it again gave me options which I do not know about the Apple ID. I formatted the onboard SSD. & wanted to change the startup boot sequence but in order to change it, again the password is needed for that too. Is there a way to get rid of this password?? The seller has not replied back past 2 days, how...
                                            05-13-2025, 04:16 PM
                                          • ritalo
                                            MacBook Air 13 2014 - Remove EFI password
                                            by ritalo
                                            I have a MacBook Air 13 inches 2014.
                                            I have set a EFI password and I can't remember it : now I want to reinstall macOS and I can't because the MacBook is asking for the password.
                                            I know how to remove the password with a usb programmer.
                                            I plug the usb programmer to the motherboard and to my pc with usb, I read the EFI and I save it to a file.
                                            Then I have to find this value in the file : $SVS because it indicate where is the password.
                                            But I can't find the value.
                                            I have attached the file​
                                            Thank...
                                            05-14-2024, 12:10 PM
                                          • Danielreinaa
                                            HELP need password bios Macbook A1706
                                            by Danielreinaa
                                            Hola chicos, espero estén bien, he estado buscando información para aprender a hacer eliminación de password EFI en macbooks.
                                            Actualmente tengo un problema con una macbook pro A1706 820-00923 SN:C02VD3GJHV2Q
                                            Si podrian ayudarme les agradeceria mucho o algun link para aprender a hacerlo y no volver a molestarles.
                                            gracias de antemano y que tengan una linda tarde, disculpen si estoy rompiendo alguna norma.
                                            Hi guys, I hope you are doing well, I have been looking for information to learn how to remove the EFI password on macbooks.
                                            09-07-2024, 03:47 PM
                                          • gbuniva
                                            MacBook A1502 (820-3476-A) Repair case with solution
                                            by gbuniva
                                            Hi everyone, I want to share my tech experience with a MacBook Pro A1502 late 2013 that won´t turn on.
                                            The computer arrived dead, when connected to Magsafe no lights on the connector.
                                            Here some Measures at some testpoints on de LB 820-3476-A :
                                            PP3V42_G3H 1.7V
                                            PPBUS_G3H = 0V
                                            PPVBAT_G3H_CHGR_RE = 0V
                                            PP3V3_S5 = 0V
                                            PP5V_S4 = 0V
                                            P5V1_SW = 5.5V
                                            PP3V3_S0SW_SSD =0V
                                            PP3V3_S0SW_SSD_FET =0V
                                            PPDCIN_G3H_INRUSH = 16.10V
                                            PPDCIN_G3H_CHGR = 16.10V
                                            PP5V_S5 - 0v
                                            PP3V3_S5 - 0v
                                            PP3V3_SUS - 0V
                                            PM_RSMRST_L - 0v...
                                            04-09-2025, 07:11 PM
                                          • Nopslide
                                            HP Omen 15-dh0052nf power-on & bios password
                                            by Nopslide
                                            Hello everyone, I come here to tell you my problem regarding the power-on password. It is not a bios reset demand, and i can't have any access to windows. This is the bios and power-on password that is blocking all other things.
                                            My Omen 15-dh0052nf purchased second-hand was configured with the bios password upon purchase (very simple password :P ).
                                            Having decided to sell it in order to get something more powerful, I reset all BIOS settings and set a blank administrator password. But the power-on password cannot be changed to a blank one so I let the actual password set....
                                            04-01-2024, 04:27 PM
