Need HP DV6-3040EP BIOS
  • dmartins
    David M
    • Apr 2014
    • 197
    • Lisbon
    Hello ,
    I need EC & Bios dump for HP DV6-3040EP
    MB DA0LX6MB6G2 REV G
    Thanks in advance
  • mahmoodjavan
    Banned
    • Mar 2018
    • 584
    • iran
    Re: Need HP DV6-3040EP BIOS
    Originally posted by dmartins
    Hello ,
    Thanks in advance
    plz test
    • mahmoodjavan
      Banned
      • Mar 2018
      • 584
      • iran
      Hello ,
      Thanks in advance
      other file
      • wil888
        • Jan 2021
        • syria
        • Habble7
          by Habble7
          Suspected Cause:
          Troubleshooting Attempts:
          05-22-2025, 07:28 AM
        • DynaxSC
          by DynaxSC
          11-17-2023, 10:56 AM
        • grimacelord
          Trying To Find UUID In BIOS Dump - HP 14-dq0055dx
          by grimacelord
          This laptop is the same laptop I was working on in this thread and I wasn't sure if I should post a new topic or post in that thread because I already solved the issue that thread was discussing and this is a completely different issue although it is dealing with the same laptop. I decided to make a new thread since it's a new issue, but please move if I made a mistake.
          Motherboard model number: DA0PAMB46A1 REV: A
          Secondary motherboard model number: 0PAB
          SKU: 685K4UA
          Serial number is: 5CD3223BJP
          Recently reflashed this laptop with latest BIOS and once...
          05-07-2024, 08:06 AM
        • DynaxSC
          Who has a MSI Z590 PRO WIFI - Need BIOS dump ?
          by DynaxSC
          I need a BIOS dump for MSI Z590 PRO WIFI from a real physical board, along with MAC address and serial no.
          It must be a dump from a physical board, as it contains personalized data eg. MAC Address, UUID, Serial no.
          I have a board which has lost the BIOS contents, I have the MAC and serial to this board, and need to insert it into the another BIOS image. To do it, I need to have a real image from a real board, as the images from the MSI site are without this data. The only way to find where MAC/UUID/Serial is located in the BIOS is to have a bios...
          11-06-2022, 05:22 PM
        • vinaypundith
          Razer RZ09-01682 Blade Stealth 13 2016 BIOS dump needed
          by vinaypundith
          I have this laptop that does boot but it's on an older BIOS that has issues with Secure Boot, and I cannot use the normal Razer BIOS updater because for some reason the serial number is missing / got deleted somehow (Common issue on this model, from what I've read). I got a dump of the BIOS chip (or at least what I think is the BIOS chip), and its 16MB in size - the files from the Razer BIOS update are 8MB. (There's two 8MB files, am I supposed to combine these somehow? Or combine with an Intel ME firmware? I have no idea).
          So, I'm looking for a BIOS dump for this machine - a 16MB one....
          08-03-2024, 12:32 PM
