Asus to300ld
  • max7
    • Nov 2015
    • 67
    • sudan
    Asus to300ld
    ASUS TO300LD-dw088h
  • newfoxinformatica
    • Mar 2015
    • 29
    • brasil
    Re: Asus to300ld
    bios fail error ?
    • razor_amd
      by razor_amd
      12-15-2020, 07:07 PM
    • Sus256
      HISENSE 65E7KQ PRO - no boot
      by Sus256
      Hi all!
      HISENSE 65E7KQ PRO
      RSAG7.820.13512 - chassis
      MT9618BAATAB - cpu
      RSAG7.820.12059 - power
      HD650Y3U77 - panel
      KLM8G1GETF - emmc
      Replaced emmc.
      Terminal log
      UART
      AC_ON
      E-B
      FDE enabled
      06-01-2025, 02:11 AM
    • throwaway327
      by throwaway327
      Model No: RC72LA
      Serial No: SBNVKD001014459
      06-18-2025, 05:52 PM
    • jbonavita
      by jbonavita
      Some issues
      Things I tried
      04-29-2025, 09:38 PM
    • greg.chalk
      Asus strix b660-i itx, bios unlock, FPT Error 167: Protected Range Registers
      by greg.chalk
      I updated my pc, from Evga z270 itx to Asus b660-i itx motherboard. In my old z270 motherboard everything whas easy because everything in bios was unlocked (fd, me etc), and could do everything I want.
      Now in my Asus b660 everything is locked (except main bios region). I dont mind so much but I want to unlock bios so I can flash a new splash screen (I have done it with my old motherboard).
      I made a bios dump with FPT (fptw64 -d mod.rom -bios), I modded it and I tried to flash back
      (fptw64 -f mod.rom -bios). I got Error 167: Protected Range Registers are currently...
      10-02-2022, 10:54 PM
