ep121
  • mahmoodjavan
    Banned
    • Mar 2018
    • 584
    • iran
    ep121
    i need bios for asus eee slate ep121 bios dump 4mb
    • 21177
    Re: ep121
    Bios .
    • faz5349
      • Sep 2017
      • 3
      • malaysia
      Re: ep121
      try this it is also asus ep121 compatible i've try this on ep121 and its working bios dump 4mb
      • mahmoodjavan
        Banned
        • Mar 2018
        • 584
        • iran
        Re: ep121
        Originally posted by SMDFlea
        Bios .
        tanks working
        • laststate
          • Jul 2014
          • 10
          • turkey
          Re: ep121
          u said 4mb bios ...SMDFlea sending 2mb bios and its work?
          • razor_amd
            by razor_amd
            12-15-2020, 07:07 PM
          • DynaxSC
            by DynaxSC
            06-14-2024, 03:49 PM
          • Ahari
            by Ahari
            I...
            08-13-2025, 06:12 AM
          • jbonavita
            by jbonavita
            Some issues
            Things I tried
            04-29-2025, 09:38 PM
          • kodox
            Asus ExpertBook B1400CB Bios Dump Needed
            by kodox
            need original bios dump, original bios has flashed by other technician before me.
            attached bios was read from the chip but no display and amperage fluctuating from 0.6A to 0.34 and back to 0.6A.
            unit info:
            Model: Asus ExpertBook B1400CBA-0711A1235U
            S/N: R6NXNZ006657238
            CN: 7F6F
            Mainboard Code: B1500CBA R2.1...
            08-16-2025, 12:20 PM
