please dum file 6050a2364501-mb-a03
  • ravenmx
    • May 2018
    • 182
    • puebla
    this bios is for hp 425 amd 6050a2364501-mb-a03 i need this file please.
    • 22279
    Re: please dum file 6050a2364501-mb-a03
    Download the bios from HP: https://ftp.hp.com/pub/softpaq/sp735...00/sp73921.exe
    Extract the .exe using 7-Zip or winrar , look in the folder called Rompaq .Your full 2MB bios is 68DVA.BIN
    • ravenmx
      • May 2018
      • 182
      • puebla
      thanks you i download the file, but have problem for the model and serial number, is clean any idea for edit the serial number, thanks you
        • 22279
        Yes, if you can boot into windows use Wndmifit ,if you can`t use nbdmifit
        https://www.badcaps.net/forum/showthread.php?t=69204
        Post your old bios backup if you have any more problems.
        • ravenmx
          • May 2018
          • 182
          • puebla
          thnks you
          • to5it0
            Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e 2H1703-27220F Rev. A Marked as U2501 on the motherboard.
            by to5it0
            Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e - Stuck with 0275 Error CMS
            I am attempting a repair on a Lenovo ThinkPad Yoga 11e that is currently stuck at boot with the error: "0275 error CMS" even after setup new bios battery and will not allow me to enter the BIOS/Setup.
            This is a critical issue that I believe requires flashing the BIOS chip directly using a programmer (e.g., CH341A/RT809H), as standard software updates or resets are not possible.
            I have opened the laptop and identified the main BIOS chip...
            10-24-2025, 01:35 AM
          • Citymin
            by Citymin
            S/N : 5RNK9FFT70...
            08-05-2025, 05:12 AM
          • maanee11
            Looking for BIOS flash file for HUAWEI MateBook X Pro 2019 (MACH-WX9)
            by maanee11
            Hello Everyone,
            I have HUAWEI MateBook X Pro 2019 (MACH-WX9) whose BIOS got corrupted i beleive. I have acquired Ch341A SPI flasher to program the BIOS externally. I see that to program the BIOS, i need BIOS bin/hex file which i could use to reflash it externally via the flasher tool.
            It seems like the support page of this model no longer exist: https://consumer.huawei.com/be/lapto...ro-2019/specs/
            In the website, you can only see specs etc.
            I have not tried to extract the BIOS dump yet as I want to see if there is any ray of sunshine...
            11-08-2025, 04:08 AM
          • m1ch43lzm
            Notice to users of XGecu TL866II Plus / T48 / T56 / T76 programmers regarding BIOS backup file size
            by m1ch43lzm
            Hi everyone
            I noticed on the Xgpro software the BIOS backup files have extra bytes at the end when reading some chips, this is because the Xgpro software also reads the OTP region of those flash chips, and by default will append that region to the saved file
            Programmer models: XGecu TL866II Plus / T48 / T56 / T76
            Example: GD25LQ128D (1.8V), IC size is listed as 0x1000000 Bytes (16777216 bytes) + 0xC00 bytes, those extra 0xC00 bytes will be appended to the end of the saved file by default, resulting in a file size of 16780288 bytes
            There's also an extra OTP Secu.R...
            09-06-2025, 05:47 PM
          • Forest79
            by Forest79
            However, the chip (a Macronix MX25L25673GMI-08G) has a size of 32 MB, and the BIOS file from the Lenovo website (extracted with UEFITool) has a little more than 16 MB. Thus, the software my acquaintance used (SiberiaProg v1.45, with a CH341A Programmer)...
            07-23-2023, 07:39 AM
