please dum file 6050a2364501-mb-a03
  • ravenmx
    • May 2018
    • 167
    • puebla
    this bios is for hp 425 amd 6050a2364501-mb-a03 i need this file please.
    • 20807
    Re: please dum file 6050a2364501-mb-a03
    Download the bios from HP: https://ftp.hp.com/pub/softpaq/sp735...00/sp73921.exe
    Extract the .exe using 7-Zip or winrar , look in the folder called Rompaq .Your full 2MB bios is 68DVA.BIN
    • ravenmx
      • May 2018
      • 167
      • puebla
      thanks you i download the file, but have problem for the model and serial number, is clean any idea for edit the serial number, thanks you
        • 20807
        Yes, if you can boot into windows use Wndmifit ,if you can`t use nbdmifit
        https://www.badcaps.net/forum/showthread.php?t=69204
        Post your old bios backup if you have any more problems.
        • ravenmx
          • May 2018
          • 167
          • puebla
          thnks you
          • Forest79
            by Forest79
            07-23-2023, 07:39 AM
          • maanee11
            Help to get Lenovo BIOS bin file for Thinkpad T560
            by maanee11
            Hello Everyone,
            I have Thinkpad T560 Which has corrupted BIOS. I have acquired Ch341A SPI flasher to program the BIOS externally. I see that to program the BIOS, i need a bin file for the BIOS. I was able to extract the .exe file of BIOS from Lenovo given here in this link:
            https://pcsupport.lenovo.com/au/en/p...me=BIOS%2FUEFI
            In the extracted files, I see that BIOS containing file has extension .FL1 and I need to extract or convert it...
            05-15-2022, 11:59 AM
          • Sebastian Codrean
            BIOS file for ASUS F542UN laptop
            by Sebastian Codrean
            Hello to all of you! I need help with a BIOS file.
            The BIOS chip is fried on my Asus F542UN laptop, and I bought a new chip that needs programming. I have a CH341a programmer but I need a .bin BIOS file. On Asus support page the firmware has another extension, .310 and from reading on this forum I understand that that file is not complete BIOS.
            So, in short I need the "complete" BIOS .bin file to flash on the new chip. Another issue is that on back of the case the label says F542UN but on the sticker on the motherboard it's X542UN.
            02-20-2025, 10:25 AM
          • Fr33man
            BIOS file (.BIN) for semi-Bricked IdeaPad 3-14ALC6
            by Fr33man
            I soft BRICKED my Lenovo IdeaPad laptop (black screen with led lights on, responsive keyboard backlight, fans spinning) after messing about with a Github tool called Smokeless. I am now attempting to reflash the bios through USB, but I am not sure if I extracted the correct BIOS ROM file to flash, and I also could not find the correct file name to rename it to (GLCrisis.bin, GLCN.bin, Currom.bin??). In addition to attempting to reflash the Bios with a USB, I have also performed the following activities:
            *Novo button power on
            *Disconnected internal battery...
            09-23-2024, 01:16 PM
          • iZakre
            HP Pavilion 15 bc400ns - Complete Black Screen - Only video on live usb
            by iZakre
            Hello everybody!
            To put you in context I recently replaced the battery from my HP Pavilion 15 bc400ns with a used one, everything was going good. The same day, I decided to update the BIOS, everything went good. The thing occurred after I let the battery drain iddling on Windows 11 for the second time to calibrate it that the screen did not turn on again, the computer was on but the screen did not turn, like it would not wake from hibernation. I decided to restart the computer but got no video.
            The thing is that I had installed TeamViewer and could log into the computer...
            02-19-2023, 02:27 PM
