Lenovo G585 Bios for UMA mainboard
  • caspian
    • Oct 2015
    • 1591
    • Laptop
    Dear forum members,
    Laptop: Lenovo G585
    Mainboard: LA-8681P
    I have attached the Bios dump from my Lenovo G585 with a GPU:
    https://www.badcaps.net/forum/attach...0&d=1545390665
    If someone has a Bios dump from a Lenovo G585 that has no GPU, please upload it here for me.
    I urgently need it if it is from a LA-8681P mainboard without GPU.
    thanks
    • 21999
    Re: Lenovo G585 Bios for UMA mainboard
    Try this one: https://www.laboneinside.com/lenovo-g585-bios-bin/
    • mahmoodjavan
      Banned
      • Mar 2018
      • 584
      • iran
      [QUOTE=caspian;869874]Dear forum members,
      Laptop: Lenovo G585
      Mainboard: LA-8681P
      thanks[/QUOplz test
      • caspian
        • Oct 2015
        • 1591
        • Laptop
        thank you
        I have tested both these Bios dumps, but there was no change. probably, the FCH is defective. If I find this mainboard, I will replace the entire mainboard.
        • mcplslg123
          • Jun 2015
          • 7262
          • india
          Originally posted by caspian
          thank you
          Replacing the FCH will likely fix your problem. You dont do bga rework??
          • caspian
            • Oct 2015
            • 1591
            • Laptop
            no, I do not have any BGA machine. because it is too expensive. Every time I discover a BGA chip is defective, I stop repairing and return the laptop back to customer.
            • caspian
              • Oct 2015
              • 1591
              • Laptop
              both the above Bios dumps seem to belong to a mainboard with GPU. I still looking for another bios dump that differs from these dumps.
                • 21999
                Try the one here,i think its a UMA version: https://www.badcaps.net/forum/showthread.php?t=39017
                • caspian
                  • Oct 2015
                  • 1591
                  • Laptop
                  thanks, that link contains a bios dump which is the same as the one provided in Post#3. So I tried it before.
                  this thread is connected to my other thread here:
                  https://www.badcaps.net/forum/showthread.php?t=73661
                  still looking for a UMA bios dump or somehow to combine the bios dumps of Post1 and Post2. because each one makes some part of the FCH work correctly.
                    • 21999
                    Sorry, i should have checked first before posting it. I found a bios that may be the right one this time,although its for a ideapad G485 its the same bios version as the UMA G585
                    offset 3E000 IdeaPad G485 , Win Key at 350000
                    34FE000 $BVDT$...$.1)$6CCN96WW(V8.08).........$QAWGE.
                    QAWGE is a UMA board i believe ?
                    • caspian
                      • Oct 2015
                      • 1591
                      • Laptop
                      As you help me continue this repair, I appreciate. I will try this file and report back.
                        • 21999
                        The EC posted by @mahmoodjavan at post #3 has these strings starting at offset 4000 QAWGE,QAWGF,QAWGK .Can you backup your EC and check if it has those same strings,or compare the two files.Maybe you have to flash the EC.
                        • caspian
                          • Oct 2015
                          • 1591
                          • Laptop
                          I do not have any EC programmer. So I hope EC programming is not required.
                          Only QAWGE is mentioned in all the above Bios dumps. and the mainboard is marked by QAWGE.
                          • caspian
                            • Oct 2015
                            • 1591
                            • Laptop
                            I have tried the bios dump of Post#10. It acts the same as the dump of Post#2. that means no change.
                            Only the original dump (in Post#1) works well but it was not written to accept UMA conversion. after they updated the Bios to the one of Post#2, it accepts UMA conversion but it is not compatible to my mainboard.
                            I am still looking for other Bios dumps to try.
                            • caspian
                              • Oct 2015
                              • 1591
                              • Laptop
                              is there a way to extract the GPU or graphics section from Post#2 's Bios and replace it into Post#1 's Bios?
                              • lefos
                                • Nov 2013
                                • 321
                                • Greece
                                If somebody ever needs a bios for this UMA board then this is it. Laptop has shorted APU.
                                So I think the dump will be OK
                                The board is QAWGE LA-8681P Rev 1.0 2012-04-02.
                                • Micro System
                                  • Nov 2014
                                  • India
                                  Thanks your file is working ok
                                  • mrbrian
                                    • Feb 2017
                                    • 5
                                    • venezuela
                                    works perfect, tested, thank you so much
                                    • lucaszmn
                                      by lucaszmn
                                      Problem:
                                      Initial Findings:
                                      • I concluded that the
                                      08-12-2025, 03:01 PM
                                    • Wahaz
                                      by Wahaz
                                      10-30-2023, 08:42 PM
                                    • grimacelord
                                      by grimacelord
                                      Hello there.
                                      History:
                                      03-15-2023, 03:29 PM
                                    • to5it0
                                      by to5it0
                                      10-24-2025, 01:35 AM
                                    • mkdj
                                      Lenovo IdeaPad 3 - Hard Disk not recognized in BIOS
                                      by mkdj
                                      Dear all,
                                      I have recently fixed a Lenovo IdeaPad 3 15 ALC6 that was not booting due to a BIOS issue. After flashing the BIOS, the laptop boots up, but hard disk is not recognized in BIOS. Is says "Hard Disk : Not Installed". I have tried with 2 different drives (one that I know is working on another laptop) but I get the same result. I do not know if disks were recognized before I got the laptop and fix it, but I don't see any reason why not. I can boot on USB though.
                                      Here the steps I have taken to fix the laptop:
                                      - downloaded latest BIOS from Lenovo Website...
                                      10-18-2025, 03:43 AM
