Lenovo G585
  • caspian
    • Oct 2015
    • 1591
    • Laptop
    Lenovo G585
    Dear forum members,
    I have hot a Lenovo G585 laptop with AMD APU and FCH. the laptop does not display anything on the screen. I am still testing it. All voltage rails are present.
    The FCH gets hotter than normal. But had tested the laptop 3 days ago. At that time, the FCH used to get just a bit warm. However, the FCH generates its output signals well, such as PLT_RST# and PWRGood.
    when the laptop turns on, the screen is black and the webcam light stays on continuously.
    I have checked the tiny capacitors located on the FCH chip (see the photo). some of them are shorted. I mean they have 1 ohm resistance to GND on both sides. the other caps on the chip are not shorted. A while ago, I had a HP laptop with AMD FCH on its mainboard. two of the tiny capacitors located on that FCH chip were shorted too.
    schematics:
    https://www.badcaps.net/forum/attach...7&d=1490606457
    Is it normal in an AMD FCH chip to have a few tiny capacitors (located on the FCH chip) to be shorted?
    If it is an Intel PCH, I know the PCH is defective. But I do not know about AMD FCH.
    thanks
  • caspian
    • Oct 2015
    • 1591
    • Laptop
    Re: Lenovo G585
    the shorted caps have 0 v when I turn the laptop on. No voltage rail is shorted on the mainboard.
    • mcplslg123
      • Jun 2015
      • 7262
      • india
      Re: Lenovo G585
      Some of the small caps on amd fch does show continuity in diode mode-that's normal. Did you flashed bios?? Webcam light remaining glowing is more often than not a bios issue on lenovo G580/85.
      • caspian
        • Oct 2015
        • 1591
        • Laptop
        Re: Lenovo G585
        KB9012 works fine and controls the fan very good. I will reprogram the Bios IC to see what will happen.
        The FCH used to be 50'C when the laptop was fine. Now, the FCH reaches 75'C with black screen 40 seconds after turning on. Does this make sure that the FCH is defective? or is it due to some problem from another IC?
        • caspian
          • Oct 2015
          • 1591
          • Laptop
          Re: Lenovo G585
          I reprogrammed the Bios and the laptop acts the same. It is not fixed yet. I do not know why the FCH gets 25'C hotter than normal. I do not know what makes the webcam light stay on.
          • caspian
            • Oct 2015
            • 1591
            • Laptop
            Re: Lenovo G585
            I want to convert this mainboard to UMA. But I cannot find the resistors R682, R683, R684, and R685. No boardview is available. Does anyone know where these resistors are located on the mainboard?
            • mcplslg123
              • Jun 2015
              • 7262
              • india
              Re: Lenovo G585
              Post closeup photo of amd chips.
              • caspian
                • Oct 2015
                • 1591
                • Laptop
                Lenovo G585 DIS to UMA Conversion
                Finally, I managed to locate those resistors. I attached two photos on how to convert the mainboard LA-8681P from DIS to UMA. Just two resistors have to be moved from one side the mainboard to the other side of the mainboard. Nobody else did it so far on this mainboard.
                I moved the two resistors. but my laptop did not get fixed. I am sure the two resistors are correctly found. after this conversion, the FCH still thinks the mainboard is DIS. I do not know why. probably due to defective FCH or defective APU or something else. maybe I need to use a UMA version of Bios. but nobody has mentioned any available Bios dump is UMA or DIS. probably, both are the same. I do not know.
                I even disconnected power to the GPU chip. but there was no change.
                • Conste
                  • Oct 2018
                  • 235
                  Re: Lenovo G585
                  Did you try to heat up the FCH a littte bit (120°C)?
                  • caspian
                    • Oct 2015
                    • 1591
                    • Laptop
                    Re: Lenovo G585
                    I did, but there was no change.
                    I do not know why the FCH does not recognize the mainboard as a UMA mainboard after converting it to UMA. Maybe, I also need to change something else too such as reprogramming Bios using a UMA dump.
                    I have attached my Bios dump for Lenovo G585 with a GPU. If someone has a Bios dump from a Lenovo G585 that has no GPU, please upload it here for me.
                    MOD EDIT: Bios moved - https://www.badcaps.net/forum/showthread.php?t=96854
                    • caspian
                      • Oct 2015
                      • 1591
                      • Laptop
                      Re: Lenovo G585
                      note: to convert this mainboard to UMA, sometimes it is required to move just one of the two resistors that I demonstrated in the photos. So test them yourself to see which one works.
                      • caspian
                        • Oct 2015
                        • 1591
                        • Laptop
                        Re: Lenovo G585
                        I discovered something:
                        - when I use my original Bios, the mainboard gets off if I press the power button. but the FCH does not understand the UMA conversion.
                        - when I use the Bios provided by SMDFlee, the mainboard does not get off if I press the power button. but the FCH understands the UMA conversion well.
                        Bios provided by SMDFlee:
                        https://www.badcaps.net/forum/showthread.php?t=73763
                        using both the Bios dumps, it has black screen and the webcam stays on.
                        So, is it possible that the FCH is fine?
                        Does it need another bios dump to get fixed?
                        • caspian
                          • Oct 2015
                          • 1591
                          • Laptop
                          Re: Lenovo G585
                          Although the mainboard is reconfigurable, it seems the original Bios dump does not have the capability of conversion to UMA. that means it works only if there is a healthy GPU on the board. the GPU of my laptop may be defective.
                          It seems the manufacturer wrote the original Bios to work only for GPU-based mainboard. that may be why nobody has successfully converted this mainboad to UMA on the Internet. However, I am not sure.
                          has anyone converted any AMD-based laptop to UMA so far?
                          • caspian
                            • Oct 2015
                            • 1591
                            • Laptop
                            Re: Lenovo G585
                            Has anyone converted any AMD-based laptop from DIS to UMA graphics so far?
                            • brew99
                              • Jan 2019
                              • 132
                              Re: Lenovo G585
                              I think I am having the same issue with my LA-8127P motherboard where the FCH is heating up after turn on. The fan will start soon after turn on to keep the CPU and GPU cool, but I get no video (VGA). Mine is also a AMD. I found the two resistors to change over to make it UMA only, and will give it a shot. I don't have a different BIOS file to load though.
                              • caspian
                                • Oct 2015
                                • 1591
                                • Laptop
                                Re: Lenovo G585
                                In general, I do not know whether DIS-UMA conversion works in AMD-based laptops or not?
                                • mielta
                                  • Apr 2015
                                  • 368
                                  Re: Lenovo G585
                                  Hi
                                  Try This
                                  • caspian
                                    • Oct 2015
                                    • 1591
                                    • Laptop
                                    Re: Lenovo G585
                                    thank you. I have tries this bios before with no result.
                                    Does anyone know whether DIS-UMA conversion works in AMD-based laptops in general?
                                    or is it just for Intel-based laptops?
                                    • lucas911
                                      • Jan 2021
                                      • 2
                                      • Denmark
                                      Re: Lenovo G585
                                      Hello
                                      On page 16 of the repair la-8681p instructions, in the upper right corner is the configuration of what the resistor does in the given place. The list is on the same page, next to the ati_robsonxt m2 graphic shemat. Unfortunately, I can't locate this gpio9 because I don't have boardview for it.
                                      • alrep
                                        • Sep 2017
                                        • 8
                                        • Russia
                                        Re: Lenovo G585
                                        To remake la-8681p in UMA, you need to rearrange two resistors, as in the photographs, and close the PC818 capacitor.
                                          LENOVO ThinkCentre M72e Tiny ThinkCentre M G465 Specification for Upgrade or Repair
                                          This specification for the LENOVO ThinkCentre M72e Tiny can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ThinkCentre M72e Tiny boardview and ThinkCentre M72e Tiny schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                          09-12-2024, 03:36 PM
                                          LENOVO ThinkCentre M72e Tiny ThinkCentre M G460 Specification for Upgrade or Repair
                                          LENOVO ThinkCentre M72e Tiny ThinkCentre M G470 Specification for Upgrade or Repair
