need bios to Asus ROG GL552VW with working Keyboard lights thx for :llorando::llorando:
Help need DUMP bios Asus ROG GL552VW
Re: Help need DUMP bios Asus ROG GL552VW
Here it is how to fix it
https://www.badcaps.net/forum/showthread.php?t=69782 -
I'm going to try and tell him, ty!Comment
by mkdjDear all,
I would appreciate if someone could take time to explain the issue, so that I can learn. But I would...-
Channel: BIOS Requests ONLY!
by razor_amdWith ASUS, not everything is quite so simple. I will show you my way. It may be longer or harder but it is the right way to do it in my humble opinion.
This is the picture of 3 similar ASUS motherboards, all of them being X555LD...-
by piratiHello everyone,
by DynaxSCHi,
Usually on ASUS boards it worked...-
by AhariHi all,
I...-
- Loading...
