Asus A501LX bios need
  • marcin02152
    • Oct 2014
    • 134
    • Polska
    Hi, i need bios dump
    Asus A501LX
    mb: K501LX 2.0
    i7-5500U
    Thanks.
    • 21671
    Re: Asus A501LX bios need
    Can you post your bios backup .
    • marcin02152
      • Oct 2014
      • 134
      • Polska
      I don't have old dump. Flash is damaged.
      • cacla
        • Apr 2015
        • 444
        here it si
        • wisechip
          • Dec 2020
          • philippines
          Hello, i also need bios version K501LXF1206.. For Asus K501LX.. Please attach a file my friends..
          • Marc97
            • Jan 2016
            • 189
            • Phillipines
            Originally posted by cacla
            here it si
            tested file for i5,,, thank you
            godbless
            • alirafee
              • Jun 2015
              • 91
              • iran
              asus k501lb-dm140t
              mb k501lx
              cn 5438
              • hoaca388
                Badcaps
                • Jan 2022
                • 12268
                You MUST:
                Read BIOS guides, methods, resources and tools
                Try the method at BIOS guides, methods, resources and tools before requesting help
                Explain you were not able to succeed with the methods at BIOS guides, methods, resources and tools
                Use search function in case someone already answered your request
                Post under a related thread if it exists
                Provide the full machine model number, serial number (or Service tag, SNID) and the board model number (see https://www.badcaps.net/forum/showthread.php?t=88758 ) ,The serial number, make, full model number, motherboard model and revision (except QR codes) must be written/typed at your request as per the rules. Not as a picture, part of the file name and so on.
                Name your thread with make, full model numbers and request
                Provide a BIOS/EC dump if possible
                Attach files directly to your post instead of linking to external websites
                Post what the problem is, be specific - black screen, no boot, running slow, password. Do NOT post "clean me", "clear bios", "clean bios", "fix bios", "bios need" or other such terms
                • alirafee
                  • Jun 2015
                  • 91
                  • iran
                  thank you
                  • peste
                    peste commented
                    Editing a comment
                    Don't post pictures unless asked...write with the keyboard..
                    .No one wastes time enlarging pictures, turning them, or using a magnifying glass to see numbers or letters..
                    it makes our work easier, not yours..
                • alirafee
                  • Jun 2015
                  • 91
                  • iran
                  thank you
                  MB K501LX REV 2
                  60NB08P0-MB1202-202
                  MAC 1CB72CE71F4F K501LB
                  QCCXK50LH53801418
                  31XK5MB00L0
                  • razor_amd
                    by razor_amd
                    12-15-2020, 07:07 PM
                  • DynaxSC
                    by DynaxSC
                    06-14-2024, 03:49 PM
                  • Ahari
                    by Ahari
                    I...
                    08-13-2025, 06:12 AM
                  • jbonavita
                    by jbonavita
                    Some issues
                    Things I tried
                    04-29-2025, 09:38 PM
                  • ArkzG
                    [REQUEST] ASUS TUF A15 FA506NF (2021) - Clean BIOS dump needed (UEFI Password locked)
                    by ArkzG
                    Hey guys, I have an "ASUS TUF Gaming A15 FA506NF (2021)" that's locked with a UEFI password, I need to reprogram the BIOS chip but can't find a clean ".bin" file for this specific model, I've tried the official BIOS updates from ASUS support page, but they're 32MB updaters that don't extract to a usable 2MB .bin file for direct chip programming.
                    What I currently have available:
                    - Model: FA506NF (2021)
                    - BIOS chip: GD25LQ16 (16Mbit/2MB)
                    - Tools: CH341A programmer ready to use
                    Does anyone have either a clean 2MB .bin dump of this model,...
                    09-26-2025, 09:34 PM
