La-f121p bİos dump help
  • bekirsalman
    • Nov 2016
    • 137
    • turkey
    Cal51 la-f121p
    rev : 1.0 (a00)
    2018-02-08
    dell İnspİron
    p75f
    p75f002
    Electronicman
    • 20763
    Re: La-f121p bİos dump help
    Here you go .
    • bekirsalman
      • Nov 2016
      • 137
      • turkey
      Originally posted by SMDFlea
      Here you go .
      buddy thank you but i need to file me 16 mb
      Electronicman
        • 20763
        Post your bios backup if you have it .
        • bekirsalman
          • Nov 2016
          • 137
          • turkey
          http://dosya.co/7qt72fvwo216/f12.BIN.html
          Electronicman
            • 20763
            The first bios i posted is for the intel version,my mistake. Here`s the AMD bios version, i merged the bios update with your bios backup.
            INSPIRON 5775 AMD BIOS + EC
            • bekirsalman
              • Nov 2016
              • 137
              • turkey
              thank you very much brother bios is working
              Electronicman
              • Levi
                • May 2014
                • 59
                • Ghana
                i have the same unit bios password . have tried the above bios bin but not working. any help out there. revision is 1.0 (a00) . i have uploaded the locked file.
                • piernov
                  • Jan 2016
                  • 4435
                  • France
                  There is no attached file.
                  • Levi
                    • May 2014
                    • 59
                    • Ghana
                    • mk praveen
                      • Aug 2014
                      • 33
                      • india
                      hi sir....some one removed bios chip in motherboard....i need bios chip details....means 16mb fw or fv(1,8v or 3.3V)
                      • Habble7
                        by Habble7
                        Suspected Cause:
                        Troubleshooting Attempts:
                        05-22-2025, 07:28 AM
                      • Mephysis
                        DUMP DVR HIKVISION DS-7208HGHI-K1 (80389 Rev 1.3 Firmware)
                        by Mephysis
                        Hello guys i really need help, i recently updated my DS-7208HGHI-K1 and it somehow got bricked, I've got it up and working now by flashing a new dump file i found but the serial number is really wrong and the uploader of the dump file probably intentionally did it.
                        I still have the bricked dump file is it possible to transfer the serial number of the "bricked dump" to the "working dump"?
                        03-27-2025, 02:34 AM
                      • hyperwood
                        [REQUEST] 2MB BIOS Dump for Lenovo NM-E471 Rev 2.0 (Winbond 25Q16JWSIQ Chip)
                        by hyperwood
                        I’m looking for a 2 MB BIOS dump for a Lenovo IdeaPad 5 16ARH7H / Legion 5 with mainboard NM-E471 Rev. 2.0.
                        The BIOS chip is a Winbond W25Q16FW (1.8V, 2MB) and it's completely unresponsive / bricked. I tried recovery via USB but no success. Now I want to reflash it externally using a CH341A programmer.
                        I already found 32MB dumps (e.g. from Vinafix and Badcaps), but they are too large for the chip – and the last 2MB in those files are just FF FF FF....
                        ✅ What I need:
                        • A working 2MB BIOS dump
                        • Matching NM-E471 Rev. 2.0, e.g. JY575
                        06-25-2025, 02:28 PM
                      • Andreas_de
                        Power supply Manson NTP-5561 (5661) LCD controller dead - PIC18F87K90 HEX dump required
                        by Andreas_de
                        Hello!
                        i got a damaged Manson NTP-5561 (60V, 1,6A DC output) and and the main issue is that the controler IC for the LCD display has a short. The controler IC PIC18F87K90 is mounted on the back of the back of the LCD. Vss-Vdd = 3 Ohm. The 5V and 3,3V power line was killed as well, but that is not a problem. A new LDO 3,3V and 5V 7805 is already ordered.
                        Replacing the PIC18F87K90 is necessary but that makes no sense without having the HEX dump of the new controler.
                        Does anybody have such a power supply and could do a HEX dump of the Flash and EEPROM memory?
                        04-12-2025, 10:38 AM
                      • re-atari
                        Anycubic Photon 5.5 3D printer 25Q32 flashrom dump needed
                        by re-atari
                        Hello all, as the title says, I'm very much in need of a valid firmware dump of a Anycubic Photon 5.5 3D resin printer. It's stored in a Winbond 25Q32, so it's 4Mbyte.
                        Here's a little background for my request. A few weeks ago I bought this 3D printer from a guy who had moved on to a PLA printer. I got it at a vey reasonable price, as it was in a defective state. The seller told me that he had experienced a power failure during a firmware upgrade, after which the printer appeared to be dead. He thought the firmware was corrupted in such a way that the printer was now bricked. As he...
                        02-03-2025, 06:49 PM
