Asus x556uj rev 2.0 clear me _ bios dump
  • alibinyousaf
    • Dec 2021
    • 8
    • dubai
    Re: Asus x556uj rev 2.0 clear me _ bios dump
    Please Someone Clear ME for Me,
    Here the Files.
    its Late Display for me
    • hoaca388
      Badcaps
      • Jan 2022
      • 11733
      Originally posted by alibinyousaf
      please someone clear me for me,
      here the files.
      Its late display for me
        • 20884
        Here the Files.
        ME Firmware Cleaning Guide - https://www.badcaps.net/forum/showthread.php?t=88533 .https://winraid.level1techs.com/t/gu...lization/31277
        • rakibul85
          • Mar 2017
          • 26
          • Bangladesh
          thank you
          • jimore
            • Nov 2020
            • 177
            • mexico
            Originally posted by teqcom
            Asus x556uj rev 2.0 plz clear me _ bios dump
            freez from laptop asus x556uj/x556uf rev 2.0
            • dahnking
              • Apr 2018
              • 257
              • kenya
              #26
              My motherboard Asus X556UJ REV.2.0.
              WINBOND 25Q64FVSIQ
              INTEL i5 SR2EY
              NVIDIA N16S-GT2-S-A2
              ITE IT8995E-128
              BIOS OK , WORKING FOR MY 100%
              tested working
              • CIBERNIASL
                • Dec 2018
                • 3
                • MADRID
                #27
                WINBOND 25Q64FVSIQ
                INTEL i5 SR2EY
                ITE IT8995E-128
                Thank you very much, it worked perfectly.
                • razor_amd
                  by razor_amd
                  12-15-2020, 07:07 PM
                • DynaxSC
                  by DynaxSC
                  06-14-2024, 03:49 PM
                • Habble7
                  by Habble7
                  Suspected Cause:
                  Troubleshooting Attempts:
                  05-22-2025, 07:28 AM
                • Anchar777
                  ASUS P1412CE need BIOS DUMP
                  by Anchar777
                  Sorry for creating a second post, I didn't understand how to fix the error in the message. I need help, laptop ASUS P1412CE (P1411CEA-EK0395X) SN: N4NXCV033901146. There was a failure during BIOS flashing, and the laptop stopped turning on. The original, non-working BIOS is attached. Unfortunately, I was unable to correctly generate the BIOS from what is presented on the Asus website. Help me make a dump. Thank you....
                  06-26-2025, 03:39 AM
                • kcp0085
                  Request BIOS dump for ASUS FA617NS-A16.R77600
                  by kcp0085
                  Aloha, I'm trying to recover my ASUS TUF Gaming A16 (FA617NS-A16.R77600)
                  I have the CH341A programmer and can flash the BIOS chip directly. I need a verified full .bin dump (2MB or full SPI region) for this specific model.
                  Specs:
                  - ASUS TUF FA617NS-A16
                  - CPU: AMD Ryzen 7
                  - BIOS chip: Winbond W25Q16JVSIQ (2MB)
                  If anyone has a full dump or can share from a working unit, it would be hugely appreciated.
                  Thanks in advance!​
                  05-02-2025, 12:52 AM
