Samsung NP940X3G bios needed
  • tomodachi
    • Apr 2012
    • 603
    • Turkey
    Motherboard code AMOR3-13 Rev : 1.1
    Thank you
    • 21145
    Re: Samsung NP940X3G bios needed
    Can you post your bios backup .
    • liu00901
      • Nov 2018
      • 8
      • China
      SAMSUNG NP940X3G,Try This one,NP940X3G_BA41-02257A_NEW
      • tomodachi
        • Apr 2012
        • 603
        • Turkey
        My backup here, thank you
        • tomodachi
          • Apr 2012
          • 603
          • Turkey
          Motherboard codes are same and so must be the bios dump, but unfortunately it didn't make any change, I will look for other problems.Thanks anyway
            • 21145
            Try this one.I found a download link on notebookreview,extracted the bios update,merged with your bios and cleaned the ME area.
            • sosit
              • Feb 2023
              • 40
              • oman
              Hi All
              my samsung NP940X3G nothing coming in display
              when i turn on only the bleu light coming and fan spinning
              but put charger it charging and show in display battery icon
              i think my bios issue
              i will upload my bios backup
              • hardware1
                • Sep 2021
                • 2939
                • N/A
                Originally posted by sosit
                Hi All
                Here's your New BIOS, try it and give me the results.
                Last edited by hardware1; 05-31-2023, 10:44 AM. Reason: Forgot to attach the file :(
                all donations are welcome,
                • sosit
                  • Feb 2023
                  • 40
                  • oman
                  Your file worked perfectly
                  Thanks alot
                  • volcour
                    • Dec 2015
                    • 90
                    • algiria
                    Hello Please I need EC file Samsung NP940X3G
                    AMOR3-13 R :1.0
                    BA41-02257A NANYA
                    ENE KB9010BF C4
                  • eldadi
                    • Aug 2020
                    • Italia
                    hi, I need the bios for np940x3g-k02it s/n jhzw91if400006d
                    original bios
                    • reeza_plus
                      • Aug 2015
                      • 57
                      • canada
                      MODEL SAMSUNG NP940X3G-K05CA
                      S/N: JJA991IF400069Y
                      MOTHERBOARD NUMER: BA41-02257a
                      ISSUE: NO DISPLAY
                      CAN SOMEONE FIX IT THANKS
                      • hoaca388
                        Badcaps
                        • Jan 2022
                        • 11874
                        ISSUE: NO DISPLAY
                        Try
                        • reeza_plus
                          • Aug 2015
                          • 57
                          • canada
                          Originally posted by hoaca388
                          Try
                          still no display and fan is not spinning!
                          • Kjell
                            Samsung Series 9 - BIOS issue
                            by Kjell
                            After installing Linux, I can no longer enter the BIOS of my Samsung Series 9 (NP900X3C) laptop. When pressing [F2] during boot I simply get a black screen. Same thing when pressing [F10] and choosing "Setup" from the "App Menu" tab. Apparently this is a relatively common issue with Samsung laptops of that generation, but unfortunately i haven't been able to resolve the issue (yet).
                            Things i've tried so far; reinstalled Windows 10, checked for redundant boot entries, tried to factory reset using the emergency keyhole, attempted to clear the NVRAM by physically...
                            08-01-2025, 09:15 AM
                          • tlindi
                            Toughbook CF-18KHH65LE (Customer Special Configuration) Supervisor Password needed remove HDD locking and BIOS Access ...
                            by tlindi
                            Sublect line continuation: ... Jaguar IDS PC aka Panasonic
                            Ack
                            Ack
                            01-30-2025, 04:26 AM
                          • macabook
                            by macabook
                            🧩 Initial Issue
                            07-24-2025, 02:17 PM
                          • Habble7
                            by Habble7
                            Suspected Cause:
                            Troubleshooting Attempts:
                            05-22-2025, 07:28 AM
                          • Citymin
                            by Citymin
                            S/N : 5RNK9FFT70...
                            08-05-2025, 05:12 AM
