IBM Thinkpad R52 Password on SYSTEM
  • lorins_core
    BlackSmith
    • Dec 2012
    • 552
    • Philippines
    even on Bios Setup can't Access Have Password
    User or Owner He do not Know the Password?
    I try to basic Troubleshoot. Dismantle Laptop Reset Cmos Bios using Remove the Cmos Battery also Discharge. No Luck
    i think need to Clean the Bin File.
    Here The Bin File
    Tia
  • MJ-meo-dmt
    • May 2016
    • 186
    • South Africa
    Re: IBM Thinkpad R52 Password on SYSTEM
    I think those have the Atmel chips there are usually two of them. Replace them both or the one closest to the BIOS region(circuit).
    The way to do it is remove all power from the board esp CMOS.
    Then replace the chips and then only start it with AC plugged in. Then check.
    while alive { live(toFullest=true) }
      • 22278
      The password is stored in a secure chip such as PC8394T-VJG , https://www.allservice.ro/forum//viewtopic.php?t=47
      https://www.badcaps.net/forum/showth...ghlight=pc8394
      • lorins_core
        BlackSmith
        • Dec 2012
        • 552
        • Philippines
        Thank For You advice.
        But they have no Atmel? the only Eeprom Chip or Bios what i saw is Prod Code 24C64WP?
        It is a Same?
          • 22278
          Try these scl sda points .http://www.ja.axxs.net/r52.htm
          • MJ-meo-dmt
            • May 2016
            • 186
            • South Africa
            Uhmm. Are you sure? They aren't as big as the normal BIOS chips. They look more like the 8 leg/pin mosfet type.
            Otherwise try the other way what SMDFlea suggested
            EDIT: I see now that 24C64WP is the size that I'm referring to... Uhm even the schematic says there are Atmel chips x2.... Maybe they used those instead?
            • lorins_core
              BlackSmith
              • Dec 2012
              • 552
              • Philippines
              I have a Question. need to used KMX1 Device. RT908F can DO That?
              • lorins_core
                BlackSmith
                • Dec 2012
                • 552
                • Philippines
                Yes Sir i'm 101% Sure. wait I send The Image Later
                  • 22278
                  No you don`t need a KMX. With the 24RF08 or equivalent chip on some thinkpads you just need to short pin 5 and 6 together at the right time while booting up to remove the password. The R52 definitely uses the PC8394T ,and you can use any TTL device to read the chip ,using the scl,sda points. I made a
                  simple-i2cprog years ago, its easy to make.If the RT908F can read ttl try it.
                  To read the chip use R24RF08 reader and decode the password with IBMPass, if R24RF08 reader doesn`t work try the pc8394 tools
                  • lorins_core
                    BlackSmith
                    • Dec 2012
                    • 552
                    • Philippines
                    Thank For That Sir. well can you teach me the Procedure. i need to fix this Laptop.
                    Thank Again
                      • 22278
                      What bios programmer/s do you have .
