IBM Thinkpad R52 Password on SYSTEM
  • lorins_core
    BlackSmith
    • Dec 2012
    • 551
    • Philippines
    even on Bios Setup can't Access Have Password
    User or Owner He do not Know the Password?
    I try to basic Troubleshoot. Dismantle Laptop Reset Cmos Bios using Remove the Cmos Battery also Discharge. No Luck
    i think need to Clean the Bin File.
    Here The Bin File
    Tia
  • MJ-meo-dmt
    • May 2016
    • 186
    • South Africa
    Re: IBM Thinkpad R52 Password on SYSTEM
    I think those have the Atmel chips there are usually two of them. Replace them both or the one closest to the BIOS region(circuit).
    The way to do it is remove all power from the board esp CMOS.
    Then replace the chips and then only start it with AC plugged in. Then check.
    while alive { live(toFullest=true) }
      • 20659
      The password is stored in a secure chip such as PC8394T-VJG , https://www.allservice.ro/forum//viewtopic.php?t=47
      https://www.badcaps.net/forum/showth...ghlight=pc8394
      • lorins_core
        BlackSmith
        • Dec 2012
        • 551
        • Philippines
        Thank For You advice.
        But they have no Atmel? the only Eeprom Chip or Bios what i saw is Prod Code 24C64WP?
        It is a Same?
          • 20659
          Try these scl sda points .http://www.ja.axxs.net/r52.htm
          • MJ-meo-dmt
            • May 2016
            • 186
            • South Africa
            Uhmm. Are you sure? They aren't as big as the normal BIOS chips. They look more like the 8 leg/pin mosfet type.
            Otherwise try the other way what SMDFlea suggested
            EDIT: I see now that 24C64WP is the size that I'm referring to... Uhm even the schematic says there are Atmel chips x2.... Maybe they used those instead?
            • lorins_core
              BlackSmith
              • Dec 2012
              • 551
              • Philippines
              I have a Question. need to used KMX1 Device. RT908F can DO That?
              • lorins_core
                BlackSmith
                • Dec 2012
                • 551
                • Philippines
                Yes Sir i'm 101% Sure. wait I send The Image Later
                  • 20659
                  No you don`t need a KMX. With the 24RF08 or equivalent chip on some thinkpads you just need to short pin 5 and 6 together at the right time while booting up to remove the password. The R52 definitely uses the PC8394T ,and you can use any TTL device to read the chip ,using the scl,sda points. I made a
                  simple-i2cprog years ago, its easy to make.If the RT908F can read ttl try it.
                  To read the chip use R24RF08 reader and decode the password with IBMPass, if R24RF08 reader doesn`t work try the pc8394 tools
                  • lorins_core
                    BlackSmith
                    • Dec 2012
                    • 551
                    • Philippines
                    Thank For That Sir. well can you teach me the Procedure. i need to fix this Laptop.
                    Thank Again
                      • 20659
                      What bios programmer/s do you have .
                      • maanee11
                        Help to get Lenovo BIOS bin file for Thinkpad T560
                        by maanee11
                        Hello Everyone,
                        I have Thinkpad T560 Which has corrupted BIOS. I have acquired Ch341A SPI flasher to program the BIOS externally. I see that to program the BIOS, i need a bin file for the BIOS. I was able to extract the .exe file of BIOS from Lenovo given here in this link:
                        https://pcsupport.lenovo.com/au/en/p...me=BIOS%2FUEFI
                        In the extracted files, I see that BIOS containing file has extension .FL1 and I need to extract or convert it...
                        05-15-2022, 11:59 AM
                      • GIGA10
                        Gigabyte G5 KE Clearing CMOS won't reset BIOS Admin password
                        by GIGA10
                        Hello everyone. I'm not sure if this post belongs in this section? If not, please kindly move it to right section Mod/Admin.
                        I have a Gigabyte G5 KE laptop and I have forgotten the BIOS Admin password. I can enter BIOS menu but when trying to enter BIOS settings it ask for my password which I have forgotten. I can boot also in to Windows 11. I have tried to clearing CMOS by removing the CMOS battery for 10h. I have tried also to remove both power battery and CMOS battery and bridge the CMOS 2 pin connector on the motherboard. Then when booting I get a message that NVRAM has been...
                        12-23-2022, 03:31 AM
                      • Maxpower3
                        Brand name and Model Type for Lenovo error 2202 product name is invalid
                        by Maxpower3
                        Info for error 2202 LenovoThinkPad models and type
                        Extract from ThinkPad Maintenance Utilities Configuration File
                        plnsrv.ini Version 1.01
                        Some information that may be useful
                        There must also be missing models, add them to the list if you know of any.
                        Code:
                        brand name
                        20B1=ThinkPad Edge E445
                        20B2=ThinkPad Edge E545
                        20BC=ThinkPad Edge E145
                        20BM=ThinkPad X140e
                        20BL=ThinkPad X140e
                        20A3=ThinkPad X230s
                        20AH=ThinkPad X230s
                        20AK=ThinkPad X240s
                        20AJ=ThinkPad X240s
                        02-21-2024, 10:27 AM
                      • jacksomething
                        help remove password thinkpad x390 yoga bios .bin file
                        by jacksomething
                        Hello!
                        Could you please help me to clear the password from this .bin file? I used vertyanov to read the EC but I don't understand how to clean the ME region myself.
                        Thank you very much...
                        05-15-2022, 07:39 AM
                        Lenovo ThinkPad ThinkPad T14 Gen 1 (AMD) Notebook T Specification for Upgrade or Repair
                        This specification for the Lenovo ThinkPad ThinkPad T14 Gen 1 (AMD) Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ThinkPad T14 Gen 1 (AMD) boardview and ThinkPad T14 Gen 1 (AMD) schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any...
                        09-07-2024, 05:20 AM
