hp 11 stream bios
  • akande
    • Dec 2017
    • 278
    • Nigeria
    hp 11 stream bios
    hp 11 stream bios needed bi: da0y02mb6c0 rev c
    i have tl688 programmer the chip is CFEON but the number is not listed on the programmer . pls help on how to flash this chip
    • 22275
    Re: hp 11 stream bios
    You havn`t said what the cFeon part number is . Use a cross reference,find a pin to pin spec compatible bios and program as that part if its in the tl866 list.
    https://www.winbond.com/hq/support/r...oss-reference/
    • akande
      • Dec 2017
      • 278
      • Nigeria
      thanks for reply the part number is OH32-104..
        • 22275
        Wrong part number . Post everything that is on the cFeon ,or post a clear picture .
        • mcplslg123
          • Jun 2015
          • 7262
          • india
          SMDFlea, the correct part number is i beleive QH32-104. I think its a typing error by akande. Its a 4MB bios chip so you can try all what is listed in your programmer software. This chip is widely used and is supportred by almost all programmers. You may need to update your programmer software with latest version .
          • akande
            • Dec 2017
            • 278
            • Nigeria
            thanks i was able to get the correct code and programm successfully , but system not display , i try reflow the board but no luck any idea plz
            • STKR123
              The right BIOS Programmer - The right software (HP Elitebook 820 G1, 840 G2) no soldering, EC, DMI, ME
              by STKR123
              Greetings badcaps community,
              I havent done this for a long time and want to start it all again, after some evil and annyoing illness.
              So I apologize in advance, if some phrases might sound a bit like gibberish or illogical to you.
              Im trying my best to fully describe what I plan to achieve and hope I was choosing the right sub-forum for my new adventure.
              I have a Elitebook 820 G1 and a Elitebook 840 G2 here.
              These ask for a password when entering the BIOS, but boot just fine from the internal SSD.
              I learned that desoldering...
              10-29-2024, 06:03 AM
            • hotcrossedbuns999
              M715q Desktop (ThinkCentre) - Type 10M3 - Request bios chip location and useable bios for use with CH341A Programmer.
              by hotcrossedbuns999
              My pc updated bios through Windows Update and I was greeted with BLACK SCREEN WITH CPU FAN MAX SPEED. I don't think there is even a screen signal, because it triggers my monitor for a couple seconds and then the monitor turns off. I tried the other outputs as well.
              1. I tried clearing bios, resetting bios, removed the CMOS battery, removed m.2 ssd, wifi, and ram. Still black screen with CPU fan blasting.
              2. I tried using the Lenovo BIOS CD and BIOS USB, but neither worked. At least I couldn't get anything to work.
              3. I could only locate two chips that look like bios chips. Could someone verify this
              01-03-2025, 12:32 PM
            • macabook
              by macabook
              🧩 Initial Issue
              07-24-2025, 02:17 PM
            • zlr8r
              looking for fully extracted by programmer Bios for a Dell Inspiron 17 (7786)
              by zlr8r
              looking for a fully extracted (by programmer) Bios for a Dell Inspiron 17 (7786) v.1.09 or newer, so I can compare it with my own bios to check for corruption.
              cheers
              Dell Inspiron 17 (7786) Laptop
              Service Tag: 5J0NHT2
              Bios: 1.9.0
              MOBO: RO 15 17 WHL 2GB MB / 18706-2
              Attached;
              1. My saved bios using a programmer
              2. Dells Bios updater .exe (v1.16)
              3. Dells Bios recovery file
              4. What I got when i tried to extract the main bios .bin file from Dells Bios v1.16 exe/rcv using some .py script i found online.
              5. Image of ME...
              12-18-2023, 03:08 PM
              by Vesko356
              08-11-2023, 03:27 AM
