Need bios dump Asus X550JX 2.1
  • cyngo
    • Jun 2015
    • 219
    • Indonesia
    Please share bios Asus X550JX rev 2.1
    or clean me my bios
    my laptop stuck on logo
    thank you.
    • 22276
    Re: Need bios dump Asus X550JX 2.1
    Try this one .
    • cyngo
      • Jun 2015
      • 219
      • Indonesia
      Thank you for the help. but the problem still remains the same.
        • 22276
        Another for you to try .
        • mustafaozbek_1
          • Oct 2014
          • turkey
          thank you
          • samy alexi
            • Mar 2017
            • 93100
            thank you
            • en_mih
              • May 2015
              • romania
              hy , what version of bios worked????
              • shlag
                • Jan 2019
                • 3
                All versions are tested and working. Checked.
                • sikap.lilin
                  • Oct 2019
                  • Indonesia
                  Need this Bios file and landed here, Thanks for sharing.
                  • lance.wang
                    • Mar 2020
                    • Taiwan
                    Also need this BIOS, and thanks for the sharing.
                    • c.daniel
                      • Mar 2017
                      • 108
                      • Romania
                      This version i try, it's working. Thank you very much.
                      • eservice computer
                        • Oct 2020
                        • thailand
                        • canali
                          • Oct 2014
                          • 196
                          • turkey
                          • mkdj
                            by mkdj
                            Dear all,
                            10-19-2025, 04:41 AM
                          • razor_amd
                            by razor_amd
                            12-15-2020, 07:07 PM
                          • pirati
                            by pirati
                            10-27-2025, 04:20 PM
                          • DynaxSC
                            by DynaxSC
                            06-14-2024, 03:49 PM
                          • Ahari
                            by Ahari
                            I...
                            08-13-2025, 06:12 AM
