Need bios for ASUS R301LA MOBO X302LA/LJ (or ASUS F302L)
  • bumper1
    • Jul 2014
    • 77
    • Poland
    I have flooded Asus R301LA MOBO X302LA/LJ REV 2.0
    Asus F302L also has this mobo, so mayby bios also will suit.
    Voltages on coils looks ok, fan is spinning, but no screen, nothing on VGA. Current without battery about 0,3A.
  • Elsid79
    • Aug 2015
    • 47
    • Ukraine
    Re: Need bios for ASUS R301LA MOBO X302LA/LJ (or ASUS F302L)
    try it ASUS R301LA (X302LA)
    Work DUMP
    • bumper1
      • Jul 2014
      • 77
      • Poland
      Thanks, but nothing changed with laptop- must be bigger problem with this flooding.
      • patit
        • Jan 2019
        • 6
        • Turkey
        X302LA/LJ EC ROM + MAIN BIOS nedded
        ASUS F302L
        Mainboard X302LA/LJ
        KBC: KB9018QF A3
        i5-5200U SR23Y
        NVIDIA GeForce 920M
        I replaced broken ENE KB9018QF A3 and need EC firmware.
        Anyone who have it pls help.
        Patrick
          • 22275
          Re: X302LA/LJ EC ROM + MAIN BIOS nedded
          Originally posted by patit
          asus f302l
          mainboard x302la/lj
          kbc: Kb9018qf a3
          i5-5200u sr23y
          nvidia geforce 920m
          hi,
          i replaced broken ene kb9018qf a3 and need ec firmware.
          patrick
          ec .
          • patit
            • Jan 2019
            • 6
            • Turkey
            As i see you extracted EC ROM from BIOS .
            Or this is from working mainboard?
            I tested your EC Firmware but still is the same- 78mA from power supply, fan max speed, no power for RAM and CPU (no eneble signal), no LEDs indicators. 3/5V and 1.05V for PCH present.
            I alredy tried a few EC and MAIN BIOS (from ASUS web site also)
            • peste
              • 13915
              • ROMANIA
              put the bios backup here
              • patit
                • Jan 2019
                • 6
                • Turkey
                Bios backup
                • peste
                  • 13915
                  • ROMANIA
                  try
                  • patit
                    • Jan 2019
                    • 6
                    • Turkey
                    unfortunately the files don't work. Still is the same. I think the EC firmware is incorrect.
                    Maybe someone have EC ROM backup from working mainboard?
                    • Claudiomfa
                      • Nov 2015
                      • 455
                      • Portugal
                      ASUS F302L
                      Mainboard X302LA/LJ
                      KBC: KB9018QF A3
                      i5-5200U SR23Y
                      NVIDIA GeForce 920M
                      Patrick
                      You change kb9018qf because of what? if it's because damaged, verify if motherboatd have other fail components.
                      If you change with a new one, you don't need to write ec firmware because asus laptop programing them on first starting.
                      • patit
                        • Jan 2019
                        • 6
                        • Turkey
                        3.3V was shorted.That was EC. Now is ok.
                        You're right, laptop programing EC on first starting.
                        I thought that i need write firmware.
                        Any sugeston what else can be damaged?
                        I will try with another BIOS.
                        • razor_amd
                          by razor_amd
                          12-15-2020, 07:07 PM
                        • pirati
                          by pirati
                          10-27-2025, 04:20 PM
                        • grimacelord
                          by grimacelord
                          07-10-2025, 02:52 PM
                        • DynaxSC
                          by DynaxSC
                          06-14-2024, 03:49 PM
                        • jbonavita
                          by jbonavita
                          Some issues
                          Things I tried
                          04-29-2025, 09:38 PM
