hp mini 110-3547TU bios needed
  • Romulo
    • Nov 2016
    • 484
    • Philippines
    I need bios of hp mini 110-3547tu please
    • 22276
    Re: hp mini 110-3547TU bios needed
    Try this one.Extracted from hp official bios.If you need DMI info,win key added from your bios backup use a hex editor, or use nbdmifit.
    • Romulo
      • Nov 2016
      • 484
      • Philippines
      thanks its working
      • Romulo
        • Nov 2016
        • 484
        • Philippines
        i have another problem with this hp mini its working fine on safe mode on windows but when i restart to normal mode it boots then before welcome screen appears display goes black screen but the fan is spinning.when i tried to reinstall os it boots first then it goes black screen again, so i tried reformat and reinstall the hard drive to another laptop and plugged back in to this hp mini the same issue boots fine on safe mode but not in normal mode.anyone can help me on this please
          • 22276
          What OS have you installed .
          • Romulo
            • Nov 2016
            • 484
            • Philippines
            windows 7
            • Romulo
              • Nov 2016
              • 484
              • Philippines
              even i try reformatting in this notebook cannot go on it goes black screen and lights present and fan working
                • 22276
                Try different RAM ,or clean the contacts, and try with an external monitor .
                • Romulo
                  • Nov 2016
                  • 484
                  • Philippines
                  tried already with different ram and clean contacts if i boot on normal mode first turn on display comes after the loading windows appeared screen goes black.but when i boot on safe mode display not goes black
                  • Romulo
                    • Nov 2016
                    • 484
                    • Philippines
                    but if i removed the hardrive and tried turned on it stock to hp logo
                      • 22276
                      Maybe.... https://sjackm.wordpress.com/2014/04...r-bios-freeze/
                      • Romulo
                        • Nov 2016
                        • 484
                        • Philippines
                        i think there is a problem with this ram slot because when i try to clean plugged back the ram it blinks 3times and when i replaced with another ram now no display and the fan at full speed
                        • Romulo
                          • Nov 2016
                          • 484
                          • Philippines
                          anyone please help on this still the same issue screen goes black on normal boot mode but ok on safe mode
