How to restore my serial number on my bios?
  • urgodfather
    replied
    Re: How to restore my serial number on my bios?
    So, I was thinking.... How are you all obtaining and restoring these dumps? Direct access to the EEPROM or are you using a boot disk to obtain a backup?
    Also, why not just use HP's BiosConfigUtility with a /get:"filenamehere.txt" to have a full output of everything config. Serial, UUID, Bios version, etc etc. Afterwards you can restore only the VSS styles portion of a clean dump with flashrom.
    Just a question. Also, has anyone had issues blowing out the MAC address of the nic after using one of these dumps?
  • mentosmec
    replied
    Originally posted by mentosmec
    Problem solved
    link for the files :https://drive.google.com/file/d/1ZGe...ew?usp=sharing
    passwords to extract the file:/www.badcaps.net
    flash a programmer with 8470p novi.BIN
    * Working on Windows
    on the desktop extract the file NbDmiFit_2.06.zip
    go to the folder
    1NbDmiFit_2.06 -> wndmifit-> wndmifit.exe
    complete the information:
    choose the model: Hp EliteBook 8570p
    ******** Tpm State: on
    ****** computrace: on
    serial number: 5cb ........
    -> copy serial number *
    system board ct: PDXVU00WB1406k
    ( clic sur commit & Lock MPM )
  • mentosmec
    replied
    Problem solved
    go to the folder
    replied
    Make a UEFI bootable drive,and run wndmifit
  • mentosmec
    replied
    thank you I will try tomorrow night:Roche:
    I just program the chip with the plug 8470p novi.bin.
    it's still the same problem as on line # 14
  • imranromi
    replied
    Where is your file without serial number post here.
  • mentosmec
    replied
    Originally posted by SMDFlea
    Now i know why nbdmifit wasn`t working . Your bios backup you posted the link to,at post #20 is exactly the same as the bios posted here at post #1 https://www.badcaps.net/forum/showthread.php?t=46678 .The bios has an admin and user password .
    Try the bios from ala_borbe at post #8 on that same thread .
    replied
  • mentosmec
    replied
    Originally posted by smdflea
    no.
    Whats your serial number
    5cb3120vmh
    replied
    you do not see the pictures?
    No.
  • mentosmec
    replied
    I just tried the file it works NBDMIF-1.14b "HPBQ193.exe
    I changed the serial number and then backed up
    Unfortunately it does not save anything I'm still in the same problem
  • mentosmec
    replied
  • mentosmec
    replied
    replied
    Theres no link ?
  • mentosmec
    replied
    here are the numbers
  • mentosmec
    replied
  • mentosmec
    replied
    Hold down win key + up arrow and down arrow until hp logo shows, then try wndmifit . If it doesn`t work then post your bios backup .
    it still does not functionhttps://drive.google.com/file/d/1XyA...ew?usp=sharing
    replied
  • mentosmec
    replied
    Try this version .
    always the same problem
    replied
    Try this version .
  • Wahaz
    by Wahaz
    10-30-2023, 08:42 PM
  • Friend33
    Changing BIOS Serial Number After Motherboard Replacement on EliteBook x360 G3
    by Friend33
    I have an EliteBook x360 G3 where I had to replace the motherboard. Everything is working fine and there are no errors during boot. However, I have the issue that the serial number in the BIOS is incorrect. When I run the DMI tool under Windows, I get an error stating that I am not in Unlocked Mode and therefore cannot make any changes. I was able to change the Asset Tag directly in the BIOS. Now I am wondering, can I simply read the BIOS chip, change the serial number with a hex editor, and write it back, or what other options do I have? The old motherboard did not work at...
    06-16-2024, 03:13 PM
  • TecnicaNTT
    Lenovo Thinkbook 16P G2 ACH - BIOS Serial number missing
    by TecnicaNTT
    I got a Lenovo Thinkbook 16P G2 ACH on the bench with a botched BIOS (somehow my client blanked it). I restored the laptop and got it up and running with original BIOS from Lenovo Support website.
    My problem is now that the machine details are missing in the BIOS (Serial Number, MTM, etc.)
    I tried to write the details with the Lenovo Uone Tool but had now luck. It is giving me an error: "ERROR: Locate protocol with LenovoEeprom, Status=[e]. EEPROM fail when reading or writing data."
    I am now asking here for help if anyone knows how to do this in...
    09-20-2024, 08:10 AM
  • jackkyxu
    HP 15-eu1026nr BIOS (Serial number, prodID etc)
    by jackkyxu
    Can someone help me adding serial number, product name and product ID to this BIOS for a 15-eu1026nr HP laptop?
    I had to flash using the BIOS file I downloaded from HP website, but it's missing all info.
    Serial: 8CG2205LDR
    ProdID: 67W66UA#ABA
    Model: ​ 15-eu1026nr...
    04-17-2025, 11:00 AM
  • xxxchudyxxx
    How to transfer serial number and DMI data from bad HP BIOS to good one?
    by xxxchudyxxx
    i have a corrupted BIOS file from a laptop, but i need to recover the serial number and DMI info (like product name, UUID, etc.). I also have a good BIOS dump from the same model.
    Is there a simple way to copy the DMI data from the bad file to the good one?
    HP 650 G3
    Thanks!...
    06-24-2025, 06:28 AM
