How to restore my serial number on my bios?
  • mentosmec
    • Jun 2018
    • 64
    • Belgique
    Re: How to restore my serial number on my bios?
    I just tried the file it works NBDMIF-1.14b "HPBQ193.exe
    I changed the serial number and then backed up
    Unfortunately it does not save anything I'm still in the same problem
    • mentosmec
      • Jun 2018
      • 64
      • Belgique
      here are the numbers
        • 22276
        Theres no link ?
        • mentosmec
          • Jun 2018
          • 64
          • Belgique
          you do not see the pictures?
          • mentosmec
            • Jun 2018
            • 64
            • Belgique
            • mentosmec
              • Jun 2018
              • 64
              • Belgique
              #26
                • 22276
                No.
                Whats your serial number
                • mentosmec
                  • Jun 2018
                  • 64
                  • Belgique
                  #28
                  Originally posted by smdflea
                  no.
                  5cb3120vmh
                    • 22276
                    Now i know why nbdmifit wasn`t working . Your bios backup you posted the link to,at post #20 is exactly the same as the bios posted here at post #1 https://www.badcaps.net/forum/showthread.php?t=46678 .The bios has an admin and user password .
                    Try the bios from ala_borbe at post #8 on that same thread .
                    • mentosmec
                      • Jun 2018
                      • 64
                      • Belgique
                      #30
                      thank you I will try tomorrow night:Roche:
                      • imranromi
                        • Jan 2015
                        • 1291
                        • Pakistan
                        #31
                        Where is your file without serial number post here.
                        • mentosmec
                          • Jun 2018
                          • 64
                          • Belgique
                          #32
                          I just program the chip with the plug 8470p novi.bin.
                          it's still the same problem as on line # 14
                            • 22276
                            Make a UEFI bootable drive,and run wndmifit
                            • mentosmec
                              • Jun 2018
                              • 64
                              • Belgique
                              #34
                              Problem solved
                              link for the files :https://drive.google.com/file/d/1ZGe...ew?usp=sharing
                              passwords to extract the file:/www.badcaps.net
                              flash a programmer with 8470p novi.BIN
                              * Working on Windows
                              on the desktop extract the file NbDmiFit_2.06.zip
                              go to the folder
                              1NbDmiFit_2.06 -> wndmifit-> wndmifit.exe
                              complete the information:
                              choose the model: Hp EliteBook 8570p
                              ******** Tpm State: on
                              ****** computrace: on
                              serial number: 5cb ........
                              -> copy serial number *
                              system board ct: PDXVU00WB1406k
                              ( clic sur commit & Lock MPM )
                              • mentosmec
                                • Jun 2018
                                • 64
                                • Belgique
                                #35
                                Problem solved
                                go to the folder
                                • urgodfather
                                  • Jan 2019
                                  • 21
                                  • murica
                                  #36
                                  So, I was thinking.... How are you all obtaining and restoring these dumps? Direct access to the EEPROM or are you using a boot disk to obtain a backup?
                                  Also, why not just use HP's BiosConfigUtility with a /get:"filenamehere.txt" to have a full output of everything config. Serial, UUID, Bios version, etc etc. Afterwards you can restore only the VSS styles portion of a clean dump with flashrom.
                                  Just a question. Also, has anyone had issues blowing out the MAC address of the nic after using one of these dumps?
                                  • Wahaz
                                    by Wahaz
                                    10-30-2023, 08:42 PM
                                  • evilgenius31
                                    Zephyrus G14 GA401QH-211 Bios missing serial number
                                    by evilgenius31
                                    Hi All,
                                    I was told to post my corrupted bios dump here. My Zephyrus G14 GA401QH-211 is missing the serial number in the bios. NVME drives can't be detected by the bios either. The bios version is 410.
                                    Serial: M4NRKD01530915H
                                    Thanks in advance!...
                                    11-10-2025, 03:58 PM
                                  • Friend33
                                    Changing BIOS Serial Number After Motherboard Replacement on EliteBook x360 G3
                                    by Friend33
                                    I have an EliteBook x360 G3 where I had to replace the motherboard. Everything is working fine and there are no errors during boot. However, I have the issue that the serial number in the BIOS is incorrect. When I run the DMI tool under Windows, I get an error stating that I am not in Unlocked Mode and therefore cannot make any changes. I was able to change the Asset Tag directly in the BIOS. Now I am wondering, can I simply read the BIOS chip, change the serial number with a hex editor, and write it back, or what other options do I have? The old motherboard did not work at...
                                    06-16-2024, 03:13 PM
                                  • acerRI
                                    Gigabyte MB missing serial number in BIOS
                                    by acerRI
                                    We have in company to custom PCs with Gigabyte B760 GAMING X (1.0). When i export hwhash for enrolling PC in azure, i got computer name as MMDEFAULTSTRING.
                                    PCs wiht this name are not compliant with company policy, number should be MMDxxxxxx (xxxxxx is serial number of mb).
                                    I have found that is possible to embbed in BIOS serial number so when i exporting, it will get proper computer name.
                                    Does anyone have know if somehow do that, maybe with some hexeditor, because i have found that some specialized tools are needed.
                                    Any help will be...
                                    09-23-2025, 05:26 AM
                                  • TecnicaNTT
                                    Lenovo Thinkbook 16P G2 ACH - BIOS Serial number missing
                                    by TecnicaNTT
                                    I got a Lenovo Thinkbook 16P G2 ACH on the bench with a botched BIOS (somehow my client blanked it). I restored the laptop and got it up and running with original BIOS from Lenovo Support website.
                                    My problem is now that the machine details are missing in the BIOS (Serial Number, MTM, etc.)
                                    I tried to write the details with the Lenovo Uone Tool but had now luck. It is giving me an error: "ERROR: Locate protocol with LenovoEeprom, Status=[e]. EEPROM fail when reading or writing data."
                                    I am now asking here for help if anyone knows how to do this in...
                                    09-20-2024, 08:10 AM
