P150SM-A Corrupted Bios
  • Umadbro
    • Jul 2018
    • 65
    • Portugal
    Hi I've got a Clevo P150SM-A, with a Prema Mod Bios installed. Everything was working well but after a bad XTU configuration my laptop is now stuck in a reboot loop of 10 seconds, it doesn't display anything. I plugged a usb onto one of the ports and the light on the stick doesn't switch on, so I believe this is a corrupt bios issue. I disassembled the laptop and removed the motherboard, and I'm now waiting the arrival of a Clip Socket adaptor, which I intend to use to dump my current bios using my Raspberry Pi 3b.
    I do not have much experience in this matter so I would like some help to figure out some of my questions:
    After checking the motherboard/diagram, i found 2 chips that I believe to be the ones where the firmware is stored, but I'm not entirely sure if this is right. This are "cFeon QH16-104HIP" and "cFeon QH32-104HIP". I think only one of them is the right chip that stores the firmware, and I would say it is the second one, but as they are align next to each other I can't tell for sure that all the data is stored in only one of them. Are these the right chips? And if so, what is the use for each one of them?
    My second questions is, after dumping the bios, I've seen that some people are able to fix them, but there's also others that post a working bios to then flash onto the chip, but I couldn't find any respective to my motherboard in these website. Is there anywhere else I would be able to find it in case no one has a back up for me?
    Specs and Important Info:
    Laptop: P150SM-A
    Motherboard: 6-71-P15S0-DA3A
    CPU: 4810MQ
    GPU: 880M 8GB
    Any help will be very appreciated.
  • IDislikemakingLogins
    • Feb 2017
    • 38
    • moon
    Re: P150SM-A Corrupted Bios
    I have seen a few computers with 2 bios chips, The bios file i found seams to be 4mb, I use uefitool to look around dumps. sometimes one chip only seams to have uefi stuff on it an other has the rest. The bios file i found (4mb one) seams to have only uefi stuff and not the bios or the me stuff. Id back up both of the chips and just try the 4mb one, I cant find anything from the 2mb one but it may have the rest of the bios on it.
    https://github.com/LongSoft/UEFITool...ses/tag/0.25.1
    http://forum.notebookreview.com/thre...r-2014.790474/
    • Umadbro
      • Jul 2018
      • 65
      • Portugal
      Hi and thank you for your reply.
      After spending some times researching I got to the conclusion that each chip contains different information:
      cFeon QH16-104HIP - This one stores the EC Firmware
      cFeon QH32-104HIP - This one stores the BIOS Rom
      Being that the backlight on the keyboard still works, the fans still spins e.t.c. I would say the EC is still intact, so I'll focus in the one that takes care of the actual bios.
      I'm still waiting for the clip. It should arrive soon but until then I can't do much. The link you sent me doesnt seem to point me to a bios dump but a actual bios update, so I'm a bit confused. Am I not suppose to flash a dump from a working bios?
      I have found a few websites like "http://************/index.php?threads/k770g-6-71-bios.33928/" which claims to have the bin files I need, but I'm not entirely sure this is a trustworthy source. It asks me to pay for a premium subscription so I can download the files, but I'm not sure if this is a safe website. Have you or anyone used it before?
      I spent some time emailing Clevo support to ask for some assistance on finding my issue, and the person I was speaking with seem to disagree the problem comes from the bios itself. He wasn't very nice about it and it didn't get me to any conclusion in the end, but it obviously left me thinking, is it actually possible that my bios becomes corrupt over misconfigurations on XTU?
      I'll keep you up to date and post my dump files whenever my clip arrives. Thank you.
        • 20933
        When you get your clip, backup both chips,and make a note which one was which.When you get a new bios and EC you can compare the bios and ec structure with a hex editor,such as HxD. Bios and EC should both be flashed.
        https://repo.palkeo.com/clevo-mirror/P1xxSM-A/
        • Umadbro
          • Jul 2018
          • 65
          • Portugal
          Thank you, I'll wait for the clip to arrive and post the results.
          • Umadbro
            • Jul 2018
            • 65
            • Portugal
            Hello, I finally manage to get a backup from both Bios and EC chips.
            The clip didn't seem to be so easy to connect so I decided to solder it straight to the components. the chip EN25QH32 (bios) was quite easy to backup, after three backups and checking the checksum I believe I've got a good dump. The chip EN25QH16 (EC) was a bit more complicated, mostly because I'm not very experienced with the code I'm using, and is also hard to find information of how to use it. After 10 dumps I think I've got a good one to go, but I might need someone to check it before just to make sure that is right. ec1.bin, ec2.bing, ec3.bin and ec6.bin seem to have a wrong checksum and after compare it with ExD I'm sure they are bad dumps, all the others seem to be the same. I still included all the backups on the attachment so anyone can see if they are actually good or not. I used 'flashrom' with my Raspberry PI to obtain the backups.
            From here I dont know what is the next step I should take. I know the idea would be flash a good dump onto the chips but I think I'll need someone to check mine first, as I'm not totally sure if that is actually the problem with my motherboard.
            I'll wait for any help before doing anything else.
            Thank you.
              • 20933
              If you`re having problems buy a cheap CH341A programmer on ebay.They cost less than £5.
              • Umadbro
                • Jul 2018
                • 65
                • Portugal
                Obtaining the dumps is not a problem. My Raspberry Pi could find and identify the chips and dump them without issues. Now I just need someone with a bit more experience to evaluate them so I know if a corrupted bios/ec is actually the problem with my board, and if it is, I'll need the right files to correct them. I can't tell by myself as I don't have the experience to analyse and fix hex files.
                • rioreno
                  • Feb 2009
                  • 540
                  • Indonesia
                  i was check your bios backup (2MB and 4MB) :
                  and i got this...
                  - 2MB (ec4) containing Descriptor region and ME Region
                  ec1, ec2 ec3 empty rom,
                  - 4MB contain BIOS Region and EC (first of 65kb)
                  PRJ:P17ASM
                  DATE: 2014/03/24
                  VER: 1.03.04
                  IT8587
                  P170SMA030.rom
                  FID.x.P170SMA
                  You said your bios type P150SMA, but its diffferent with your backup, have you ever flashing or updated bios before?
                  • Umadbro
                    • Jul 2018
                    • 65
                    • Portugal
                    Hi, and thank you for checking my backups.
                    I've flashed this bios myself long ago and my laptop worked for a long time with it installed. This is one of the modded bios from Prema Mod, I don't know why would it say is for the 170SM-A but as far as I know both models are very similar and possibly use the same bios, so maybe Prema made a bios which can be flashed in both laptops, but this is just an assumption. What I know is that this bios worked perfectly for the time the laptop was operational.
                    As mentioned before ec1,2,3 and 6.bin are not good dumps for sure but I thought it might be useful to post them.
                    I'm a bit confused with what you said, I thought the 2mb chip was the EC and the 4mb the Bios but you said that's not the case.
                    In your opinion do you think the files are corrupt? Now that I think about it, I don't think I'll ever be able to compare it being that this is not a official bios.
                    • rioreno
                      • Feb 2009
                      • 540
                      • Indonesia
                      my opinion the bios region has some error,, you can check using UEFItool and compare with bios from P17xSMA_B0311.zip...
                      try this from downloaded from SMDFlea link (post#4)
                      2mb and 4mb
                      extracted and split from P17xSMA_B0311.zip
                      your logo will change to CLEVO..
                      goodluck
                      • Umadbro
                        • Jul 2018
                        • 65
                        • Portugal
                        Do you think it will be okay to flash a different laptop version onto my flahs? Mine is the P15xSM-A, not the P17xSM-A
                          • 20933
                          Heres the P15xSM-A bios and ec . If you flash the P17 or P15 flash both the bios and ec
                          • rioreno
                            • Feb 2009
                            • 540
                            • Indonesia
                            You say that your backup file has been long use, until bad XTU config..
                            I check id/ver your backup file with uefitool and hxd, i cannot find p15 but i only find p17.. so i think your bios its ok flash with p17...
                            however we will know after you try that..
                              • 20933
                              Theres only one small difference between the P15 and P17 bios from the palkeo repo, standard and overclocking .
                              • Umadbro
                                • Jul 2018
                                • 65
                                • Portugal
                                I'm just about to start flashing the bios/ec, I'll post the results straight after finishing it.
                                I can't remember if that was the case bus as both laptops are very very similar I would say Prema must have created a bios update that suits and can be installed in both models, but as unfortunately he is not sharing is amazing work anymore I can't guarantee this is what happen. Shame, this laptop is nothing without that bios, the bottle neck is horrible with the stock rom, but I guess better a laptop that works than a brick that does nothing.
                                • Umadbro
                                  • Jul 2018
                                  • 65
                                  • Portugal
                                  I've just finished to flash the bios/ec and test the laptop and everything is working like charm!!! I was very surprised to see it working. The bios logo is not from Clevo but 'Style Note'??? Not sure why but it doesn't really matter being that now the laptop is back in track. The Power throttle is also back duo to the stock rom, but after some XTU tweaks it might have made it a bit better, but I'll need to test it to make sure. Thank you all for your help, I'm really pleased with the results I've got in the end.
                                  Now I'm wondering, would there be a way to fix my original modded bios? It's probably not worth the trouble as it must take a lot of effort, but as there is no way to get it from Prema anymore, this bios is quite of a rarity.
                                  By the way, the files I flashed were form the P15xSM-A.
                                  Once again, thank you all for your help.
                                  • rioreno
                                    • Feb 2009
                                    • 540
                                    • Indonesia
                                    Nice... so now we know after you flash your nb can be flash with p15 or p17..
                                    Style note is clevo logo, BUT you can change easily that logo with any logo if you need.
                                    • Umadbro
                                      • Jul 2018
                                      • 65
                                      • Portugal
                                      Well, sort off. I still used the right bios for my model. If you look into the repository of bios both models have their own bios, but as far as I'm concerned there's little to no difference between thouse motherboards
                                      • ProfessorPolygon
                                        • Jan 2021
                                        Hey,
                                        Would those bios files work with any P150SM? I've got a similar issue and can't find bios files anywhere. Found these but not sure how to flash them currently as they don't include the dos files. I have created a dos usb stick but any guidance would be great.
                                        • macabook
                                          by macabook
                                          🧩 Initial Issue
                                          07-24-2025, 02:17 PM
                                        • TylerHyde21
                                          Lenovo TD350 ThinkServer BIOS v505 Corrupted BIOS,
                                          by TylerHyde21
                                          Hello, the bios on my Lenovo TD350 ThinkServer got corrupted during a bios update, the bios restore function killed the Server.
                                          I need to flash the bios inside the MX25L12835F SOP8, i have already desolder the chip and solder it into my SOP8 adapter and read it with a ROM programmer.
                                          I use the innoextract 1.9 software to extract the bios file from the .exe file that i download from lenovo website, can you help me edit the Hex file (removing the Index part and resize the file)?
                                          This guy claim to have done it https://forums.lenovo.com/t5/ThinkSe...doesnt-Start-u...
                                          06-29-2024, 10:38 AM
                                        • Loli Popu
                                          DELL LATITUDE 5590 BIOS CORRUPTED BY CH341
                                          by Loli Popu
                                          Hello guys ,i have a dell latitude 5590 with f411p bios,this laptop has bios password ,i tried to read the bios(winbond 25q128jv) with ch341 but when goes to verify give error ,it said doesnt match .After this i flashed another bios which is cleaned and then the laptop was dead ,i tried to turn on but only white light in the buton power turned on several times and then no display at all .I had a backup and flashed again the original bios ,but this time the laptop will not turn on at all ,no light nothing,the bios original bios that i flashed was having verify error when i verified with ch341 ,i...
                                          12-13-2024, 08:29 AM
                                        • Ugur87
                                          Need Bios or Help for Corrupted Bios.bin XPlus Series 81
                                          by Ugur87
                                          Hello
                                          ive got a brand new Xplus Series 81 mini Notebook, but its not turning on, my friend take it and make something with it, everthing looks fine , charging , power input perfect , fans spinning but no image, now i read the bios chip with ch341a programmer, i think its corrupted, is there any way to fix a corrupted bios bin ? please help...
                                          07-14-2025, 06:41 PM
                                          by Vesko356
                                          08-11-2023, 03:27 AM
