Need bios SONY VJF152C11N
  • luvbe3
    Chicken
    • Oct 2017
    • 147
    • JAPAN
    i have dump with passbios
    main code DAHKDDMB6C0 REV:C
  • luvbe3
    Chicken
    • Oct 2017
    • 147
    • JAPAN
    Re: Need bios SONY VJF152C11N
      • 20311
      Use sony password script
      http://dogber1.blogspot.com/2009/05/...ered-bios.html
      • luvbe3
        Chicken
        • Oct 2017
        • 147
        • JAPAN
        Originally posted by SMDFlea
        thanks!!!
        i'm done
        • 157263350
          • May 2019
          • 10
          • China
          很好的一个 bios
          • zaheer118
            • Feb 2016
            • 14
            • pakistan
            copy your file but bios password protect do you have password if u have please share with me
            thanxxxx
            br zaheer
              • 20311
              thanxxxx
              br zaheer
              Read post #1 again - "i have dump with passbios"
              See post #3 how to remove the password .
              • Habble7
                by Habble7
                Suspected Cause:
                Troubleshooting Attempts:
                05-22-2025, 07:28 AM
              • DynaxSC
                by DynaxSC
                11-17-2023, 10:56 AM
              • grimacelord
                Trying To Find UUID In BIOS Dump - HP 14-dq0055dx
                by grimacelord
                This laptop is the same laptop I was working on in this thread and I wasn't sure if I should post a new topic or post in that thread because I already solved the issue that thread was discussing and this is a completely different issue although it is dealing with the same laptop. I decided to make a new thread since it's a new issue, but please move if I made a mistake.
                Motherboard model number: DA0PAMB46A1 REV: A
                Secondary motherboard model number: 0PAB
                SKU: 685K4UA
                Serial number is: 5CD3223BJP
                Recently reflashed this laptop with latest BIOS and once...
                05-07-2024, 08:06 AM
              • DynaxSC
                Who has a MSI Z590 PRO WIFI - Need BIOS dump ?
                by DynaxSC
                I need a BIOS dump for MSI Z590 PRO WIFI from a real physical board, along with MAC address and serial no.
                It must be a dump from a physical board, as it contains personalized data eg. MAC Address, UUID, Serial no.
                I have a board which has lost the BIOS contents, I have the MAC and serial to this board, and need to insert it into the another BIOS image. To do it, I need to have a real image from a real board, as the images from the MSI site are without this data. The only way to find where MAC/UUID/Serial is located in the BIOS is to have a bios...
                11-06-2022, 05:22 PM
              • vinaypundith
                Razer RZ09-01682 Blade Stealth 13 2016 BIOS dump needed
                by vinaypundith
                I have this laptop that does boot but it's on an older BIOS that has issues with Secure Boot, and I cannot use the normal Razer BIOS updater because for some reason the serial number is missing / got deleted somehow (Common issue on this model, from what I've read). I got a dump of the BIOS chip (or at least what I think is the BIOS chip), and its 16MB in size - the files from the Razer BIOS update are 8MB. (There's two 8MB files, am I supposed to combine these somehow? Or combine with an Intel ME firmware? I have no idea).
                So, I'm looking for a BIOS dump for this machine - a 16MB one....
                08-03-2024, 12:32 PM
