dar18dmb6d1 rev d
  • bachir2004
    • Feb 2015
    • 437
    • maroc
    dar18dmb6d1 rev d
    PLEASE INEED A WORKING BIOS EC AND MAIN FOR HP G6 dar18dmb6d1 rev d.ORIGINAL DUMP ATTACHED.BID0338A.
    • 20649
    Re: dar18dmb6d1 rev d
    Try this bios, your DMI included. Sorry, no EC .
    • bachir2004
      • Feb 2015
      • 437
      • maroc
      many thanks will try and reply
      • bachir2004
        • Feb 2015
        • 437
        • maroc
        no change.does anyone have have ec dump?thank you so much for help.
          • 20649
          Heres another bios,with your DMI ,and EC included this time .
          • bachir2004
            • Feb 2015
            • 437
            • maroc
            Originally posted by smdflea
            heres another bios,with your dmi ,and ec included this time .
            thanks man i will try and reply.
            • Habble7
              by Habble7
              Suspected Cause:
              Troubleshooting Attempts:
              05-22-2025, 07:28 AM
            • robgerr
              Asus K3500P Main (X7400PC R2.2) Bios Dump Reques
              by robgerr
              Good morning forum, I'm trying different bios to try to resurrect this machine, with all the bios tried the machine turns on, the fans turn but the screen is black. I tried to download the correct bios from the Asus website (x3500PC by reading the QRCODE from the motherboard) but this is a PFAT AMI, I managed to decrypt it but I get several files and rebuilding it is very laborious, I tried with the uefi tool to extract only the main bios and cut the decrypted one and rebuild it in hex but it doesn't work the same. Wondering if anyone has a dump for this main board. I thank you.
              Attach...
              11-17-2023, 09:52 AM
            • DynaxSC
              by DynaxSC
              11-17-2023, 10:56 AM
            • cekcons
              g1 assassin Rev 1 bios dump - main and backup needed
              by cekcons
              main and backup ic dead so i cant post corrupt bios cause its 01 all over.
              thanks
              01-23-2024, 03:26 AM
            • grimacelord
              Trying To Find UUID In BIOS Dump - HP 14-dq0055dx
              by grimacelord
              This laptop is the same laptop I was working on in this thread and I wasn't sure if I should post a new topic or post in that thread because I already solved the issue that thread was discussing and this is a completely different issue although it is dealing with the same laptop. I decided to make a new thread since it's a new issue, but please move if I made a mistake.
              Motherboard model number: DA0PAMB46A1 REV: A
              Secondary motherboard model number: 0PAB
              SKU: 685K4UA
              Serial number is: 5CD3223BJP
              Recently reflashed this laptop with latest BIOS and once...
              05-07-2024, 08:06 AM
