PLEASE INEED A WORKING BIOS EC AND MAIN FOR HP G6 dar18dmb6d1 rev d.ORIGINAL DUMP ATTACHED.BID0338A.
dar18dmb6d1 rev d
Tags: None
Re: dar18dmb6d1 rev d
Try this bios, your DMI included. Sorry, no EC .Attached Filesif you find these attachements useful please consider making a small donation to the site
Heres another bios,with your DMI ,and EC included this time .Attached Filesif you find these attachements useful please consider making a small donation to the site
by AhariHi all,
I...-
by mkdjDear all,
I would appreciate if someone could take time to explain the issue, so that I can learn. But I would...-
Channel: BIOS Requests ONLY!
by Habble7The Samsung S49CG934SU monitor does not power on - no LED indicator activity and no response to power button. However, when 21V power is connected, it immediately draws 0.8A of current with no display output. The motherboard processor gets warm, and there is continuous reading activity from the W25Q128BV BIOS chip.
Suspected Cause:
Troubleshooting Attempts:
Hello engineers 😀,
🔧 Device Info:
- Model: HP 15-da2007ne
- Product Number: 8XF55EA#ABV
- Serial Number: CND0338P0D
- CPU: Intel Celeron N4000
💀 Problem:😅
- Device shows “Administrator Password”...2 Photos-
by robgerrGood morning forum, I'm trying different bios to try to resurrect this machine, with all the bios tried the machine turns on, the fans turn but the screen is black. I tried to download the correct bios from the Asus website (x3500PC by reading the QRCODE from the motherboard) but this is a PFAT AMI, I managed to decrypt it but I get several files and rebuilding it is very laborious, I tried with the uefi tool to extract only the main bios and cut the decrypted one and rebuild it in hex but it doesn't work the same. Wondering if anyone has a dump for this main board. I thank you.
Attach...-
- Loading...
