Lenovo Ideapad 100S-14IBR BIOS
  • malekservis
    • Mar 2017
    • 19
    • czech republic
    Model: Ideapad 100S-14IBR
    Motherboard: 1501B_01_01 REV: SOVP4
    KBC: ENE KB9028Q
    Old BIOS:
  • ridamouh159
    • Nov 2014
    • 365
    • maroc
    Re: Lenovo Ideapad 100S-14IBR BIOS
    salam
    try with this
    • malekservis
      • Mar 2017
      • 19
      • czech republic
      Didn't work, still won't turn on, 3V and 5V are present though. Could you please share EC as well
      • techman1025
        • Jun 2014
        • 497
        You need to check and see if you have the rsmrst 3.3v S5 3.3 voltage also any external mouse or keyboard light up after you press power button. If you have secondary voltage and RSMRST AND S5 then bios is working .
        Techman1025
        • el panke
          • May 2019
          • 78
          • argentina
          Originally posted by ridamouh159
          salam
          try with this
          bump to this.
          i used this bios file and it worked, now when boots, has bios password
          any clue of the password?
          thanx
          • thesame
            • Mar 2018
            • 141
            • Romania
            What type of adapter do you use for this type of smd (25Q64FW)to read and write it with the programmer?
            • johnyuce12
              • Sep 2020
              • 11
              • united kingdom
              did you sort the problem mate?
              • johnyuce12
                • Sep 2020
                • 11
                • united kingdom
                I have same issue asking bios password
                • el panke
                  • May 2019
                  • 78
                  • argentina
                  used ch341a with 1.8v adapter
                  • el panke
                    • May 2019
                    • 78
                    • argentina
                    still has password
                    • peste
                      • Dec 2016
                      • 13924
                      • ROMANIA
                      Originally posted by el panke
                      still has password
                      try..
                      • el panke
                        • May 2019
                        • 78
                        • argentina
                        Originally posted by peste
                        try..
                        man u rules
                        tnahx alot for the file
                        works like a charm
                        • mberbouch
                          • May 2014
                          • 109
                          • Morocco
                          try..
                          Thanks, works for me too
                          • rey sinadjan
                            Banned
                            • May 2023
                            • phillipines
                            lenovo ideapad 100s-14IBR bios please
                            hi guys. is it ok to change the bios chip of the laptop coz i think my bios chip is broken. is it still working ??
                            KBC: ENE KB9028Q
                            Old BIOS:
                            hi. can i ask. is it ok to change the bios chip of laptop lenovo ideapad?? i need this bios but i think my original bios chip is broken. i want to try to change the bios chip but before first i wanna ask is if it's ok to change the bios chip since the other chip is also 8mb suppotted. thank u.
                            Last edited by SMDFlea; 05-30-2023, 02:21 AM. Reason: Moderator edit,merged 3 posts
                            • razadom
                              • Apr 2015
                              • 106
                              • Madagascar
                              Hi all
                              I have lenovo ideapad 100s-14IBR MODEL: 80R9 S/N YD01EZRX with password. I used dump from post 11 by peste to unlock it. It's ok but I have two problem after: the sound card is not available and the SSD port also is not available. I suspect that this bios dump
                              is not compatible with my mb. Please, someone can unlock the original bios dump that I will attach on this post. Thanks in advance.
                            • peste
                              • Dec 2016
                              • 13924
                              • ROMANIA
                              Originally posted by razadom
                              Hi all
                              try..
                              • razadom
                                • Apr 2015
                                • 106
                                • Madagascar
                                Hi peste
                                your bin is always locked
                                • peste
                                  • Dec 2016
                                  • 13924
                                  • ROMANIA
                                  Hi peste
                                  update winrar or use 7zip..
                                  • mberbouch
                                    • May 2014
                                    • 109
                                    • Morocco
                                    man u rules
                                    works like a charm
                                    Works for me too, thank you very much.
                                    • mkdj
                                      Lenovo IdeaPad 3 - Hard Disk not recognized in BIOS
                                      by mkdj
                                      Dear all,
                                      I have recently fixed a Lenovo IdeaPad 3 15 ALC6 that was not booting due to a BIOS issue. After flashing the BIOS, the laptop boots up, but hard disk is not recognized in BIOS. Is says "Hard Disk : Not Installed". I have tried with 2 different drives (one that I know is working on another laptop) but I get the same result. I do not know if disks were recognized before I got the laptop and fix it, but I don't see any reason why not. I can boot on USB though.
                                      Here the steps I have taken to fix the laptop:
                                      - downloaded latest BIOS from Lenovo Website...
                                      10-18-2025, 03:43 AM
                                    • jendkkd jeje
                                      Lenovo IdeaPad 330 15-AST 81D6 BIOS Recovery
                                      by jendkkd jeje
                                      So a couple of years ago i got a bios update through Lenovo Vantage, so i installed it and bricked my whole BIOS, so i couldn't fix it so i put that ideapad in a box, 3 years later i found that one PC and want to recover it to switch from a 2014 hp laptop to this one.
                                      I found a method to recover the BIOS of many lenovo laptops tha consists in pluging in a USB Flash with the BIOS files and power on the laptop with Fn + R keys pressed until fans go loud and start beeping loud, but nothing worked, so i think filename is wrong, i tried naming the bios file as 07WW.BIN, BIOS.BIN, BIOS.fd,...
                                      10-11-2024, 03:12 PM
                                    • joven016
                                      Lenovo Ideapad S145 need working bios HELP!!
                                      by joven016
                                      Problem is blinking power led only
                                      i don't know exactly if it's s145-15igm or s145-14igm
                                      have a backup bios file but i dont know the serial.. coz text already erased at the back of the cover
                                      Mother board : fs440fs541 nm-c111 rev 1.0 2019-01-08
                                      Already tested some of posted bios here
                                      S145-14igm - success but invalid serial and not booting on OS
                                      S145-15igm - success with serial and some other info in bios but still not booting on OS
                                      already tried installing new windows but always booting on bios setup
                                      windows installer flash drive detected on...
                                      08-21-2025, 10:55 PM
                                    • lucaszmn
                                      by lucaszmn
                                      Problem:
                                      Initial Findings:
                                      • I concluded that the
                                      08-12-2025, 03:01 PM
                                    • mximiliandz
                                      help bios lenovo ideapad s145-14iil type 81w6
                                      by mximiliandz
                                      Good morning, gentlemen, I hope you can help me with my laptop, I told you that I saved it about 2 years ago because it wouldn't turn on, now I have a ch341a programmer, I made a backup of the bios, I flashed an original downloaded from lenovo and it started, but it turned off after a few minutes, I entered the bios configuration and the brand, model, serial number, windows serial number, etc. did not appear, I request your help, I did everything I found in the forum but I could not solve it, also now it won't start again, it turns on but the fan does not turn, I will share all the information...
                                      06-20-2025, 06:50 AM
