Lenovo Ideapad 100S-14IBR BIOS
  • malekservis
    • Mar 2017
    • 19
    • czech republic
    Model: Ideapad 100S-14IBR
    Motherboard: 1501B_01_01 REV: SOVP4
    KBC: ENE KB9028Q
    Old BIOS:
  • ridamouh159
    • Nov 2014
    • 365
    • maroc
    Re: Lenovo Ideapad 100S-14IBR BIOS
    salam
    try with this
    • malekservis
      • Mar 2017
      • 19
      • czech republic
      Didn't work, still won't turn on, 3V and 5V are present though. Could you please share EC as well
      • techman1025
        • Jun 2014
        • 497
        You need to check and see if you have the rsmrst 3.3v S5 3.3 voltage also any external mouse or keyboard light up after you press power button. If you have secondary voltage and RSMRST AND S5 then bios is working .
        Techman1025
        • el panke
          • May 2019
          • 78
          • argentina
          Originally posted by ridamouh159
          salam
          try with this
          bump to this.
          i used this bios file and it worked, now when boots, has bios password
          any clue of the password?
          thanx
          • thesame
            • Mar 2018
            • 121
            • Romania
            What type of adapter do you use for this type of smd (25Q64FW)to read and write it with the programmer?
            • johnyuce12
              • Sep 2020
              • 11
              • united kingdom
              did you sort the problem mate?
              • johnyuce12
                • Sep 2020
                • 11
                • united kingdom
                I have same issue asking bios password
                • el panke
                  • May 2019
                  • 78
                  • argentina
                  used ch341a with 1.8v adapter
                  • el panke
                    • May 2019
                    • 78
                    • argentina
                    still has password
                    • peste
                      • Dec 2016
                      • 12775
                      • ROMANIA
                      Originally posted by el panke
                      still has password
                      try..
                      • el panke
                        • May 2019
                        • 78
                        • argentina
                        Originally posted by peste
                        try..
                        man u rules
                        tnahx alot for the file
                        works like a charm
                        • mberbouch
                          • May 2014
                          • 108
                          • Morocco
                          try..
                          Thanks, works for me too
                          • rey sinadjan
                            Banned
                            • May 2023
                            • phillipines
                            lenovo ideapad 100s-14IBR bios please
                            hi guys. is it ok to change the bios chip of the laptop coz i think my bios chip is broken. is it still working ??
                            KBC: ENE KB9028Q
                            Old BIOS:
                            hi. can i ask. is it ok to change the bios chip of laptop lenovo ideapad?? i need this bios but i think my original bios chip is broken. i want to try to change the bios chip but before first i wanna ask is if it's ok to change the bios chip since the other chip is also 8mb suppotted. thank u.
                            Last edited by SMDFlea; 05-30-2023, 02:21 AM. Reason: Moderator edit,merged 3 posts
                            • razadom
                              • Apr 2015
                              • 100
                              • Madagascar
                              Hi all
                              I have lenovo ideapad 100s-14IBR MODEL: 80R9 S/N YD01EZRX with password. I used dump from post 11 by peste to unlock it. It's ok but I have two problem after: the sound card is not available and the SSD port also is not available. I suspect that this bios dump
                              is not compatible with my mb. Please, someone can unlock the original bios dump that I will attach on this post. Thanks in advance.
                            • peste
                              • Dec 2016
                              • 12775
                              • ROMANIA
                              Originally posted by razadom
                              Hi all
                              try..
                              • razadom
                                • Apr 2015
                                • 100
                                • Madagascar
                                Hi peste
                                your bin is always locked
                                • peste
                                  • Dec 2016
                                  • 12775
                                  • ROMANIA
                                  Hi peste
                                  update winrar or use 7zip..
                                  • mberbouch
                                    • May 2014
                                    • 108
                                    • Morocco
                                    man u rules
                                    works like a charm
                                    Works for me too, thank you very much.
                                    • mximiliandz
                                      help bios lenovo ideapad s145-14iil type 81w6
                                      by mximiliandz
                                      Good morning, gentlemen, I hope you can help me with my laptop, I told you that I saved it about 2 years ago because it wouldn't turn on, now I have a ch341a programmer, I made a backup of the bios, I flashed an original downloaded from lenovo and it started, but it turned off after a few minutes, I entered the bios configuration and the brand, model, serial number, windows serial number, etc. did not appear, I request your help, I did everything I found in the forum but I could not solve it, also now it won't start again, it turns on but the fan does not turn, I will share all the information...
                                      06-20-2025, 06:50 AM
                                    • jendkkd jeje
                                      Lenovo IdeaPad 330 15-AST 81D6 BIOS Recovery
                                      by jendkkd jeje
                                      So a couple of years ago i got a bios update through Lenovo Vantage, so i installed it and bricked my whole BIOS, so i couldn't fix it so i put that ideapad in a box, 3 years later i found that one PC and want to recover it to switch from a 2014 hp laptop to this one.
                                      I found a method to recover the BIOS of many lenovo laptops tha consists in pluging in a USB Flash with the BIOS files and power on the laptop with Fn + R keys pressed until fans go loud and start beeping loud, but nothing worked, so i think filename is wrong, i tried naming the bios file as 07WW.BIN, BIOS.BIN, BIOS.fd,...
                                      10-11-2024, 03:12 PM
                                    • Wahaz
                                      by Wahaz
                                      10-30-2023, 08:42 PM
                                    • grimacelord
                                      Lenovo Legion T5-26AMR5 Desktop - Corrupt BIOS
                                      by grimacelord
                                      Hello there.
                                      I am working on a Lenovo Legion T5-26AMR5 desktop that currently has a corrupt BIOS and I have been unsuccessful thus far in trying to fix it myself.
                                      History:
                                      1. This computer came to me initially with an error message that said "BiInitializeLibrary failed 0xc0000001" or "0135 fan error". It would always be one of the two errors. It should be noted that when it produced the fan error, there was no physical problem with the fans. They were all spinning just fine.
                                      I searched for this error online and discovered...
                                      03-15-2023, 03:29 PM
                                    • Popel1083
                                      Lenovo IdeaPad U330p Read Bios than Bios Password Remove
                                      by Popel1083
                                      I want to remove the Bios Password of my Lenovo IdeaPad U330p with the Lenovo autopatcher. I have the CH341A Black and I'm using NeoProgrammer. The Programmer has an LED that indecates when it reads or writes the Chip. When I try to Connect my Programmer to the Bios Chip (Winbond 25Q64FVSIQ) the LED lights up even though I didn't click on Detect botton in NeoProgrammer. If i click on Detect the LED still remains on and NeoProgrammer says "IC not responding".
                                      SN: QB08570065
                                      MB: DA0LZ5MB8D0; REV: D; MODEL J31/N02
                                      08-06-2024, 05:52 PM
