ASUS n61Jq bios dump needed
  • magnetepazzo
    • Feb 2017
    • 85
    • italy
    ASUS n61Jq bios dump needed thanks
  • caspian
    • Oct 2015
    • 1589
    • Laptop
    Re: ASUS n61Jq bios dump needed
    Here it is. Just try it. I am not sure whether it works or not.
    • magnetepazzo
      • Feb 2017
      • 85
      • italy
      thankyou bro
        • 20771
        N61jq me_clean
        • elakhes
          • Nov 2015
          • 5
          • turkish
          thanks
          • coder78
            • Aug 2015
            • 67
            • turkey
            thanks
            • Kingtonino
              • Apr 2021
              • Italia
              It works, thank you
              • ricoleal
                • Oct 2012
                • 9
                • Portugal
                • DynaxSC
                  by DynaxSC
                  06-14-2024, 03:49 PM
                • DynaxSC
                  by DynaxSC
                  11-17-2023, 10:56 AM
                • jbonavita
                  by jbonavita
                  Some issues
                  Things I tried
                  04-29-2025, 09:38 PM
                • TacticalFahrrad
                  [REQUEST] Fujitsu Lifebook E5513 – Full BIOS Dump Needed (.bin)
                  by TacticalFahrrad
                  I'm trying to recover a Fujitsu Lifebook E5513 (most likely 2023 model) that was bricked during a BIOS update. The update was interrupted (probably due to power loss), and now the laptop is stuck in a boot loop showing "PBB rollback" / "SBB rollback" messages.
                  BIOS access (F2) and Boot Menu (F12) are no longer possible – the system instantly reboots after the rollback messages.
                  I extracted the official BIOS update package from Fujitsu (contains FJNB2FD.CAP, ~18.7 MB) and tried tools like UEFIExtract, but it seems to only contain...
                  06-30-2025, 04:09 AM
                • vinaypundith
                  Razer RZ09-01682 Blade Stealth 13 2016 BIOS dump needed
                  by vinaypundith
                  I have this laptop that does boot but it's on an older BIOS that has issues with Secure Boot, and I cannot use the normal Razer BIOS updater because for some reason the serial number is missing / got deleted somehow (Common issue on this model, from what I've read). I got a dump of the BIOS chip (or at least what I think is the BIOS chip), and its 16MB in size - the files from the Razer BIOS update are 8MB. (There's two 8MB files, am I supposed to combine these somehow? Or combine with an Intel ME firmware? I have no idea).
                  So, I'm looking for a BIOS dump for this machine - a 16MB one....
                  08-03-2024, 12:32 PM
