HP DMI Tool NBDmiFit
  • imranromi
    • Jan 2015
    • 1288
    • Pakistan
    #121
    Re: HP DMI Tool NBDmiFit
    Originally posted by Miquell210
    Hello all.
    This is my first post as new user so hello all.
    Got similar problen with my laptop HP-15-r101na.
    After replacing motherboard receiving three error which I expected to easly fix.
    Well - not really.
    Can find proper tool to do so.
    1. System Board (00A) - Product Name
    2. System Board (00A) - Product Serial Number
    3. System Board (00A) - Product Number
    The only one think able to do was to update BIOS to version F.45
    Then I`ve tried to use different version of NbDmiFit with error platform not supported
    According to HP Serial Number Repository (Product Configuration Tracker) laptop was manufactured in 2014 so I`ve used tools supporting in theory this model - but platform not supported appear in DOS, Windows, WindowsPE
    Can you recommend proper tool or any idea what I am doing wrong, please.
    Post here bios dump if will fix.
    • Miquell210
      • Jun 2020
      • 6
      #122
      Already tried:
      - HP BIOS Configuration Utility (BCU) - unsuccessful
      -- wndmifit is not common to download - most of download links are going to 404 error or contain fake files - tried so far v 2.09 then v 1.1d to 1.14D
      I am keep looking
      • Miquell210
        • Jun 2020
        • 6
        #123
        Already tried:
        I am keep looking
          • 20446
          wndmifit is included inside the nbdmifit folder. Page #1 post #1 of this thread has different nbdmifit versions,try 2.10 in UEFI.The site is working ok, no 404 pages for me. You can post your bios in the "Bios Requests" sub forum if you want someone to try repair it for you - https://www.badcaps.net/forum/forumdisplay.php?f=40
          • Miquell210
            • Jun 2020
            • 6
            #125
            Originally posted by SMDFlea
            Use HP bios config utility BCU ,and/or wndmifit from windows or nbdmifit from UEFI flash drive . Use version 2.10 or above.
            Job done.
            WnDmiFit 2.07 working properly - all data changed successfuly.
            All done by creating pendrive in Rufus and used DOS version.
            Source I faund here:
            https://aiotutorials.wordpress.com/tag/wndmifit/
            Thanks for help all.
            • imranromi
              • Jan 2015
              • 1288
              • Pakistan
              #126
              Already tried:
              I am keep looking
              Now you done is good i done always via bios dump modified this type error.
              • Skunch
                • Jun 2020
                • 28
                Hello, I have an elitebook 9470m. I purchased a new motherboard and installed it. I have the error with the alert: "machine not in committed state"
                I'm not sure how to go about fixing this, as I have read online many people have this problem with new motherboards. Windows boots and functions normally. Does anyone know if I can fix this with software? A new part is nice, but am I better off returning the motherboard for a used one?
                • alas3376
                  • Nov 2011
                  • 382
                  • BENIN
                  #128
                  Job done.
                  thank you very much for sharing
                  • Skunch
                    • Jun 2020
                    • 28
                    okay, so I've used the tool, and I've learned that I now need 2 things; the "Feature Byte", and the "Build ID".
                    My own bit of research tells me that the feature byte is a long, case sensitive string of letters and numbers and it looks like this:
                    2U3E3X47676J6S6b727B7H7M7R7S7W7m7saBb3da.3Y
                    (this feature byte is for a ProOne 600 G2)
                    As for build ID...
                    I can't commit the board until I enter these last two fields! Does anyone know how I can find that info?
                    I have a 9470m i7 motherboard with HD+ graphics (1600x900)
                    also, classic bart mooning smilie? heck yes!
                    • Dragunbayne
                      • May 2012
                      • 12
                      Does anyone have a newer NBDmiFit? I have a 450 G5 that I got a replacement board from HP for and I don't think any in this thread are new enough.
                        • 20446
                        [QUOTE=Skunch;976137]okay, so I've used the tool, and I've learned that I now need 2 things; the "Feature Byte", and the "Build ID".
                        As for build ID...
                        Go to this site and enter your serial and country.With any luck the feature byte will be there.
                        https://partsurfer.hp.com/Search.aspx
                          • 20446
                          Use HP BCU, bios config utility.
                          • Biosuser1
                            • Apr 2020
                            • Norway
                            #133
                            Tanks
                            • Shay_G
                              • Aug 2020
                              • 7
                              • iL
                              #134
                              Originally posted by ala_borbe
                              hello
                              over the years i collected some versions of DMI tools for hp
                              and i wanted them to be all at one place
                              take note that some version are not correct (limited information, missing readme etc)
                              for some laptops you need older, for some newer but there is plenty here
                              also, you need to use this tool in dos
                              and there is Manufacturing Program Mode Error solution here since it is related to bios programming
                              enjoy and remember to share versions you have or related fixes
                              there is a tool for hp 430 G6 ¿?¿
                              • Aditya11ttt
                                Adi
                                • Feb 2019
                                • 177
                                • India
                                #135
                                https://drive.google.com/drive/u/0/f...KyclbyYaMa0d7F
                                try 2.14
                                • Shay_G
                                  • Aug 2020
                                  • 7
                                  • iL
                                  #136
                                  Originally posted by Aditya11ttt
                                  my MPM is locked,
                                  how to unlock my MPM¿,
                                  please give me tutorial
                                    • 20446
                                    my MPM is locked,
                                    https://www.youtube.com/watch?v=9T57ktw8n3Y
                                    https://www.youtube.com/watch?v=r2ubpyeUOB4
                                    Read the pdf manual as well in the first attachment in this thread on page 1:
                                    Manufacture Programming Mode in Unlock mode MPM
                                    • Shay_G
                                      • Aug 2020
                                      • 7
                                      • iL
                                      #138
                                      this guide is to LOCK the MPM,
                                      i want to do the opposite,
                                      i want to change the value of my motherboard from LOCK to UNLOCK to change my serial number
                                      • Aditya11ttt
                                        Adi
                                        • Feb 2019
                                        • 177
                                        • India
                                        #139
                                        my MPM is locked,
                                        upload ur old dump plz
                                        MOD EDIT: NO dumps in this thread, Upload to the bios requests section: https://www.badcaps.net/forum/forumdisplay.php?f=40
                                          • 20446
                                          Its both,just need to edit the * next to lock or unlock.
                                          • rex98
                                            HP DMI Tool
                                            by rex98
                                            HP DMI Tool is used to Extract DMI information from a HP BIOS Bin.
                                            DISCLAIMER: badcaps.net and its members do not support unlocking stolen or company-owned devices.
                                            The DMI Tool given here are for personal use only.
                                            DISCLAIMER: THE HP DMI Tool IS FREE AND ARE INTENDED FOR EDUCATIONAL PURPOSES ONLY.
                                            You CAN download it, use it.use it.I only ask that you DON'T modify it ,sell it or try to make a profit
                                            from it, and that you please credit the author...
                                            Yesterday, 05:51 AM
                                          • tsavpyn
                                            Requests to Intel Flash Programming Tool for Linux Ubuntu x86_64
                                            by tsavpyn
                                            Dear all,
                                            I forgot my BIOS password of my Surface Pro 3, I searched for solutions for a long time and knew that by using FPT to dump my bios to bin file and using decryptor, I can get my BIOS password.
                                            Now I have a problem that I am unable to dump my BIOS into bin file.
                                            My Surface Pro 3 currently runs on Ubuntu 22.04, with Secure Boot enabled and Boot From SSD Only.
                                            I searched for FPT but there is no Linux version and none of them work.
                                            I hereby request a copy of Intel Flash Programming Tool for Linux x64.
                                            I would really appreciate it if anyone...
                                            05-28-2024, 11:18 PM
                                          • salim5566
                                            loking for bio tool that hve all feature like ps5 bios and laptop bios unlock and repair 1 tool can do all please good tool?
                                            by salim5566
                                            Hi guys i like to buy tool that automatic unlock bios or find password also can flash and repair bios ic, looking for good tool have good software that have 1 click and unlock bios any recommend good tool? looking for sony ps5 and and laptop bios
                                            06-26-2025, 03:25 PM
                                          • tony359
                                            Best tool to place electrolytic SMD caps on a board
                                            by tony359
                                            HI all,
                                            I am working on some boards where all 100+ SMD caps have to be replaced (yes, they actually went bad!). I found a workflow to remove them comfortably (two irons, pre-heater and extra hot air for larger ones on ground planes).
                                            When it comes to soldering them back, I add solder to one pad and then I use a plastic tweezer to keep them in the right place while I solder that leg.
                                            The tweezer works - but I was wondering if there is a more "dedicated" tool or whether someone has a better idea. If it was for a bunch of caps then who cares. But because...
                                            01-28-2024, 06:23 AM
                                          • chromecut
                                            NVME support for Lenovo Insyde laptop B40-30 (circa2014)
                                            by chromecut
                                            I need some guidance-any logical sense of this would be mighty appreciated
                                            I usually prefer to do the work myself but to0 many impossible projects calling my name-Im having trouble getting nvme support for this lenovo insyde biios laptop B40-30-any moddying=brick-Ive unlocked all the register with direct hex edit to signed bios which didnt break the bios amazingly, signed the oem flashing tool and the bios (fptw allows full dump but no write back)to what I thought was success: no warnings fully flashed and then=brick
                                            I cant try the sleep bug trick as I need 9ccn30ww.exe which somebody...
                                            04-19-2023, 06:57 PM
