HP DMI Tool NBDmiFit
  • peterschmidt
    • Sep 2018
    • Deutschland
    #41
    Re: HP DMI Tool NBDmiFit
    HI everyone - im trying to change the model from a 840g3 - it was accidently changed to zbook g3 - I tried the 2.10-2.13 utility under windows. Nothing worked - tried different SMC.BIN files at the root always showing command unsuccesfully. Date from SMC msg is 00/00/0000 - 0043/255/255 - DOS doesnt work either - telling me to run the utility for Windows.
    So I need to unlock the MPM - any clue, hints or workaround?
    Any advice is much appreciated
    • startergo
      • Jul 2019
      • 5
      I have replaced my motherboard and reprogrammed the UUID, serial (except the feature byte and build Id).
      The problem is that during boot it says :
      "Warning Machine is not in committed state"
      When I open the DMI firmware tool it says MPM is not in unlocked mode and the "Commit only" button on the bottom is greyed out.
      The other problem I have is I checked the Vpro status and it states it was set but it complained it was unsupported and my sticker says Vpro. I cannot reprogram it to supported because it says it was once already set.
      Where can I find the feature byte and build Id how can I unlock MPM? I read SMC.bin has to be generated based on the UUID and the SN
      • imranromi
        • Jan 2015
        • 1288
        • Pakistan
        #43
        The other problem I have is I checked the Vpro status and it set it was said but it complained it was unsupported and my sticker says Vpro. I cannot reprogram it to supported because it says it was once already set.
        What model you want unlock MPM..?
        • startergo
          • Jul 2019
          • 5
          Folio 9480m.
          Thanks for the quick reply
          • startergo
            • Jul 2019
            • 5
            Do you need more info like UUID and the s/n?
            • imranromi
              • Jan 2015
              • 1288
              • Pakistan
              #46
              You want smc.bin file?Sorry if you want unlock Mpm i need bios dump
              • startergo
                • Jul 2019
                • 5
                Is there a way to dump the bios in Windows or Linux on HP9480m? I tried under OSX with the flashrom but it came with some errors. I used the starting region found by the flashrom FF000000 and the end region as FFFFFFFFF in RWeverything. The dumped bios is 16,384KB but apparently it is not a good image. There are no passwords in the bios (except the default "admin" in the ME). Has anybody tried: chipsec_util.main(['spi', 'dump', 'rom.bin'])
                using chipsec?
                • umarg6677@gmail.com
                  • Aug 2019
                  • 10
                  • Rwanda
                  #48
                  HP DMI TOOL NBDMIFIT FOR HP ENVY X360 15-U437cl
                  • mr.Data
                    • Sep 2018
                    • 74
                    • Netherlands
                    #49
                    Thank you!
                    • rclksr
                      • Sep 2019
                      • 6
                      I have an EliteBook 8460P. The system board needed to be replaced so I purchased a used one. I would like to put in my old serial number, Product number, UUID. I am looking for a step by step procedure if anyone has one. I just cannot seem to reprogram this systemboard. Any help or starting place would be great! Just to add I do not yet have an OS on this laptop. I am planning on putting Windows 10 on it, but I replaced the Hard drive as well. Any of the tools I've used so far give me a "Failed to write SKU number" Failed to write model name" "Press any key to continue..." I'm at a loss.
                      • imranromi
                        • Jan 2015
                        • 1288
                        • Pakistan
                        #51
                        You need to save bios dump if you have programmer post here i will send you file you can own add serial number any info.....
                        • xe_d_sono
                          • Aug 2013
                          • 22
                          • Portugal
                          #52
                          What version of DMI Tool are you using?
                          • rclksr
                            • Sep 2019
                            • 6
                            "save bios dump" I'm not sure what you are referring to. Please explain
                            • rclksr
                              • Sep 2019
                              • 6
                              As for the version of DMI Tool, I started with NbDmiFit_2.13.zip. I then tried
                              NbDmiFit_2.09.zip since I seen on another forum that this was what he used for his 8460P.
                              • rclksr
                                • Sep 2019
                                • 6
                                I hope this is the BIOS dump you are referring to. I loaded Windows to run the universal bios toolkit. Thanks for your help
                                  • 20477
                                  Thats not the full bios, and bios requests should go into the "Bios Requests" sub forum.
                                  https://www.badcaps.net/forum/forumdisplay.php?f=40
                                  • h3ru7
                                    • May 2011
                                    #57
                                    thanks Sir,
                                    MPM work well in Probook 6470b
                                    • 65c102
                                      • Apr 2017
                                      • 28
                                      • england
                                      #58
                                      im having issues with hp 450 g4 mpm (see pic)
                                      ive tried a few dmifit programs but cant find the one that works on this model
                                      does anyone have the version for 450 g4 ?
                                      thanks
                                      • imranromi
                                        • Jan 2015
                                        • 1288
                                        • Pakistan
                                        #59
                                        thanks
                                        Q:How to come this error?If program new bios file then come use original update bios he recover auto your dmi info.
                                        Or you want any dmi then send me bios file if you read i try add all info
                                        • 65c102
                                          • Apr 2017
                                          • 28
                                          • england
                                          #60
                                          this machine originally had bios password, I reflashed a new bios and everything was ok but after a few months I get this error ?
                                          I will install windows and try the hp bios update
                                          thanks, I will let you know how things go. Thanks for your offer to fix the bios dump (I might need it)
                                          back soon
                                          • rex98
                                            HP DMI Tool
                                            by rex98
                                            HP DMI Tool is used to Extract DMI information from a HP BIOS Bin.
                                            DISCLAIMER: badcaps.net and its members do not support unlocking stolen or company-owned devices.
                                            The DMI Tool given here are for personal use only.
                                            DISCLAIMER: THE HP DMI Tool IS FREE AND ARE INTENDED FOR EDUCATIONAL PURPOSES ONLY.
                                            You CAN download it, use it.use it.I only ask that you DON'T modify it ,sell it or try to make a profit
                                            from it, and that you please credit the author...
                                            07-02-2025, 05:51 AM
                                          • tsavpyn
                                            Requests to Intel Flash Programming Tool for Linux Ubuntu x86_64
                                            by tsavpyn
                                            Dear all,
                                            I forgot my BIOS password of my Surface Pro 3, I searched for solutions for a long time and knew that by using FPT to dump my bios to bin file and using decryptor, I can get my BIOS password.
                                            Now I have a problem that I am unable to dump my BIOS into bin file.
                                            My Surface Pro 3 currently runs on Ubuntu 22.04, with Secure Boot enabled and Boot From SSD Only.
                                            I searched for FPT but there is no Linux version and none of them work.
                                            I hereby request a copy of Intel Flash Programming Tool for Linux x64.
                                            I would really appreciate it if anyone...
                                            05-28-2024, 11:18 PM
                                          • salim5566
                                            loking for bio tool that hve all feature like ps5 bios and laptop bios unlock and repair 1 tool can do all please good tool?
                                            by salim5566
                                            Hi guys i like to buy tool that automatic unlock bios or find password also can flash and repair bios ic, looking for good tool have good software that have 1 click and unlock bios any recommend good tool? looking for sony ps5 and and laptop bios
                                            06-26-2025, 03:25 PM
                                          • tony359
                                            Best tool to place electrolytic SMD caps on a board
                                            by tony359
                                            HI all,
                                            I am working on some boards where all 100+ SMD caps have to be replaced (yes, they actually went bad!). I found a workflow to remove them comfortably (two irons, pre-heater and extra hot air for larger ones on ground planes).
                                            When it comes to soldering them back, I add solder to one pad and then I use a plastic tweezer to keep them in the right place while I solder that leg.
                                            The tweezer works - but I was wondering if there is a more "dedicated" tool or whether someone has a better idea. If it was for a bunch of caps then who cares. But because...
                                            01-28-2024, 06:23 AM
                                          • chromecut
                                            NVME support for Lenovo Insyde laptop B40-30 (circa2014)
                                            by chromecut
                                            I need some guidance-any logical sense of this would be mighty appreciated
                                            I usually prefer to do the work myself but to0 many impossible projects calling my name-Im having trouble getting nvme support for this lenovo insyde biios laptop B40-30-any moddying=brick-Ive unlocked all the register with direct hex edit to signed bios which didnt break the bios amazingly, signed the oem flashing tool and the bios (fptw allows full dump but no write back)to what I thought was success: no warnings fully flashed and then=brick
                                            I cant try the sleep bug trick as I need 9ccn30ww.exe which somebody...
                                            04-19-2023, 06:57 PM
