Need HP Probook 430 G3 DAX61CMB6C0 REV.C Bios dump
  • cyngo
    • Jun 2015
    • 219
    • Indonesia
    need bios dump hp probook 430 G3 DAX61CMB6C0 rev. C, please
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: Need HP Probook 430 G3 DAX61CMB6C0 REV.C Bios dump
    Backup and try. Good luck. Post result
    • cyngo
      • Jun 2015
      • 219
      • Indonesia
      Thank you very much. this file works fine on my laptop. but how can it work? while series and board codes are different
      • mcplslg123
        • Jun 2015
        • 7262
        • india
        Dax61 and 63 bios is almost same and i was aware of it. Thats why i posted this bios. Anyway, glad to know it worked for you.
        • cyngo
          • Jun 2015
          • 219
          • Indonesia
          I understand now. Thank you for your help
          • Pascal Komlassan
            • Jan 2017
            • 806
            • TOGO
            backup and try. Good luck. Post result
            thanks
            • bilton2011
              • Nov 2017
              • 5
              • Uganda
              Thanks very much
              • biplob
                • May 2019
                • Bangladesh
                thanks
                • zhekamail
                  • Jun 2019
                  • 6
                  • Russia
                  thanks
                  • pepyluck
                    • Feb 2015
                    • 36
                    • indonesia
                    Thank you very much
                    • datarus
                      • May 2021
                      • 7
                      • Sweden
                      Thanks worked good
                      • syed faizan
                        • Aug 2019
                        • 7
                        • india
                        its working thanks
                        • Usedcom
                          Usedcom
                          • Dec 2015
                          • 24
                          • Polska
                          thanks
                          • rajib22
                            • May 2022
                            • french
                            Thanks it works like a charme !
                            I tried another unlocked Bios Dump from the same model HP 430 G3 with same motherboard ref. (the only difference is the first one was made01/10/2017 the second was made 07/16/ 2019) but it doesn't work !!
                            if anyone can help to unlock the first one ? thanks
                              VIP Moderator
                              • Aug 2018
                              • 4386
                              • Bulgaria 🇧🇬
                              Become a Badcaps supporter
                              Thanks to all supporters.
                              • rajib22
                                • May 2022
                                • french
                                Originally posted by Vesko356
                                Thanks for your prompt answer. I'll let you know tomorow
                                • rajib22
                                  • May 2022
                                  • french
                                  Great Job ! many thanks.
                                  • dewodewo
                                    dewodewo
                                    • Feb 2022
                                    • 5
                                    • pendik
                                    thanks %100 work
                                    • Cashcobra
                                      • Jul 2017
                                      • 26
                                      • GHANA
                                      thanks %100 work
                                      • irull89
                                        • Aug 2016
                                        • 7
                                        • kudus
                                        please clear password sir
                                        • Habble7
                                          by Habble7
                                          Suspected Cause:
                                          Troubleshooting Attempts:
                                          05-22-2025, 07:28 AM
                                        • studdy05
                                          Bricked HP Probook 450 G7 Bios questions
                                          by studdy05
                                          Hp Probook 450 G7 s# SCD0348W35 had a locked BIOS. Bought BIOS and EC chips off Ebay that were supposed to match this machine - the 450 G7. Flashed in the BIOS on chip i bought using a CH341. BIOS unlocked next boot. Some error to contact HP. Entered BIOS and reset to system defaults and rebooted. Machine worked fine but every cold boot the contact HP message popped and everything else worked as fine. Assumed the error was from EC chip not matching BIOS that i just flashed in. So i flashed in the EC that was supposed to match from the EBay chip i bought and instant brick.
                                          Ive got...
                                          07-08-2025, 09:24 PM
                                        • Citymin
                                          by Citymin
                                          S/N : 5RNK9FFT70...
                                          Yesterday, 05:12 AM
                                        • DynaxSC
                                          by DynaxSC
                                          11-17-2023, 10:56 AM
                                        • solomost
                                          need bios dump for HP ProBook 640 G2
                                          by solomost
                                          HI I need bios dump for HP ProBook 640 G2 PLZ☺☺
                                          prblm: black screen caps lock blinking 5 times then fan spening
                                          CT: PFKCT00WB69310 REV : 1.20
                                          motherboard : HSB J Mv-6 94v-0 E89382
                                          03-21-2025, 06:22 AM
