HP Omen 15-ax201ns bios dump
    • 20932
    Re: HP Omen 15-ax201ns bios dump
    If it hasn`t worked from USB recovery then your only option is to use a programmer. Make a bios backup first,you can post it here if you want or go ahead and program the BID08217 .It has to be the right one,its the only bios for KABYLAKE H .Note that by programming a virgin bios you will lose all DMI info.That means the serial number and other info. There are some HP DMI tools posted here,and some videos too to help.
    • stingerchamp
      • Sep 2020
      • 425
      • Pakistan
      Originally posted by stingerchamp
      Thanks for your help. I will try to use these files to flash on bios chip using flash programmer. it will be last hope for my laptop mobo.
      I have done everything to save it but failed now only hope is flashing bios with fresh bin file .
      Yes i am trying to recover a bios file from USB or from this forum so i go ahead for flash programmer process.
      Hi guys ,
      Need HeLPPPPPPPPPPPPPP
      I have flashed my bios chip Gigadevice GD25B64CS1G using SPi flash programmer , bios file 80217F48, i have read old file using hex editor, bid is 08217 confirmed from old bios file. Now Hp omen 15 Ax236tx laptop fan running but still getting capslock 5 long blink and 3 short blinks. please help what to do next to fix this. any idea thanks
      • stingerchamp
        • Sep 2020
        • 425
        • Pakistan
        Hi, I did as you said, i created backup of bios flash using ch341a programmer plus soci8 clip adapter from my bios chip , posting here my retrieved dump file from chip. I need help , please check this origional bios dump file which has 08217 bid you were right .
        I have already flashed bios with 08217( confirmed bin ) on my chip but still getting no display and capslock blink 5 long 3 short
        thanks in advance.
        • stingerchamp
          • Sep 2020
          • 425
          • Pakistan
          Anyone help ?
          flashing a bios chip failed it means bios chip is toasted? or need to get new chip from the market and flash it with working bios file
          Please help me so i go ahead and fix my laptop HP OMEN 15- AX236TX. if you want to check my bios file which i retreived from the chip please check above post.
          Waiting for a reply Bros
          • peste
            • Dec 2016
            • 12822
            • ROMANIA
            Anyone help ?///////////////
            anyone????????????
            bios extracted from the HP site update, the laptop has six versions of your bios has 08217
            DMI 222000-2220FF
            KEYWIN 223000-22303F
            • stingerchamp
              • Sep 2020
              • 425
              • Pakistan
              #26
              DMI 222000-2220FF
              Thank you Sir
              Finaly someone replied
              Please tell me how to put this DMI info in bios file and yes bios has bid 08217
              and step by step process thank you.
              Furthermore Sir i forgot to mention getting 5.3 capslock error as i power on laptop.
              • peste
                • Dec 2016
                • 12822
                • ROMANIA
                #27
                Thank you Sir
                enter the original bios of the laptop and update 08217 in the HxD program, tick in both bios the DMI and KEYWIN region and copy-paste, then rewrite the bios chip.
                • stingerchamp
                  • Sep 2020
                  • 425
                  • Pakistan
                  #28
                  I have opened origional bios file in hex editor but unable to find DMI and keywin regions.
                  • stingerchamp
                    • Sep 2020
                    • 425
                    • Pakistan
                    #29
                    choosen files are identical when hex editor compares both files except below value
                      • 20932
                      Try NeoProgrammer software,it supports the GD25B64 Post #7 https://www.badcaps.net/forum/showth...=NeoProgrammer
                      • stingerchamp
                        • Sep 2020
                        • 425
                        • Pakistan
                        #31
                        Hi thanks for help
                        Here is what happend , i flashed bios file which you provided 08217F48 to chip
                        using Ch341a programmer and it identified chip giga device but showed 2 chips in selection
                        1- GD25B64
                        2-GD25B64C
                        i flashed both one by one with this file , first i read file and it did read it successfully showed me bid number 08217.
                        One more thing in IC list of the programmer there is no IC list for gigadevice
                        GD25B64CS1G, list starts with Gd25Q
                        • stingerchamp
                          • Sep 2020
                          • 425
                          • Pakistan
                          #32
                          Adding above if i have flashed bios chip with any of the bios file 08217 virgin one for example it should show display at least asking for product ID etc at display , in my case after flashing bios it has no display at power on and still same capslock 5.3 issue.
                          correct me if i am wrong , are you saying if i use neo programmer with virgin or old bios it will flash it correctly as it accepts gigadevice GD25B64CS1G chip
                            • 20932
                            NeoProgrammer has a search function,just type in GD25B .If the virgin bios is written correctly you should have something on the display.Erase the chip first,then write,then read back again and compare with HxD ,if there are any differences the bios chip is bad. If it has written correctly then i can only assume that the EC may be corrupt, as it was working ok before the bios update ?
                            • stingerchamp
                              • Sep 2020
                              • 425
                              • Pakistan
                              #34
                              Hi
                              Neo programmer has support for GD25B64C chip confirmed
                              Now what to do with files? and which one is valid for flashing.
                                • 20932
                                08217 for Kaby Lake H https://support.hp.com/rs-en/document/c05411183 i7-7700HQ = KABYLAKE H
                                BID08209 SKYLAKE U
                                BID0820D SKYLAKE H
                                BID0825F SKYLAKE H
                                BID08294 SKYLAKE H
                                BID08213 KABYLAKE U
                                BID08217 KABYLAKE H
                                • stingerchamp
                                  • Sep 2020
                                  • 425
                                  • Pakistan
                                  #36
                                  before the bios it was working ok and yes first thing i noticed was while i was looking at my desktop for files suddenly my desktop background went black ( only icons were visible with black screen) after that i tried to upgrade bios and recover bios using CMOS reset but my wireless card or device was not showing in Device Manager and i had to restart laptop to make it visible i shut down my laptop and turned it on again but this time bios corrupted , capslock 5.3 error , tried everything like reseat memory and what HP website said but nothing, repair guy told me to flash bios but he had none so he returned my laptop and i joined this forum for help , rest you know
                                  • stingerchamp
                                    • Sep 2020
                                    • 425
                                    • Pakistan
                                    #37
                                    Hi sorry for being so dumb but compare which file
                                    you mean virgin bios with old corrupted bios or the bios file which i will write using neo and opening same file in hex editor to confirm.
                                      • 20932
                                      Write the 08217 ,read it back,compare what you read back with the 08217. Both should be exactly the same. If they are the same and still no boot then it is no longer a bios issue and the problem is somewhere else
                                      • stingerchamp
                                        • Sep 2020
                                        • 425
                                        • Pakistan
                                        #39
                                        I will perform above steps and share results here, hoping for the best
                                        • stingerchamp
                                          • Sep 2020
                                          • 425
                                          • Pakistan
                                          #40
                                          Hi all
                                          here are the results , something wrong with mobo STILL NO BOOT AND NO DISPLAY. i see backlight when i put torch at LED.
                                          Both files were identical when compared
                                          IC identified and detected correctly
                                          capslock led disappeared for 5 sec then again appeared.
                                          THANK YOU
                                          • MDSI
                                            HP OMEN 17-an012nf BIOS dump with EC (DAG3BAMBAF0 REV : F)
                                            by MDSI
                                            I'm requesting a full BIOS dump (including EC firmware) for an HP OMEN 17-an012nf laptop.
                                            Details:
                                            Model : HP OMEN 17-an012nf
                                            Motherboard Part Number : DAG3BAMBAF0 REV : F
                                            Serial Number (S/N) : 5CD7280D51
                                            BIOS chip : Winbond W25Q64VSIQ
                                            Programmer : EZP2023+
                                            Issue : The motherboard is not powering on. Only the 5V rail is present. The 3.3V rail is missing because EN1 on the SY8286B remains stuck at 0V. This signal is driven directly by the EC/SIO. I replaced the 3.3V regulator and confirmed it's working.
                                            I already...
                                            07-28-2025, 07:11 AM
                                          • JoWed
                                            Problems with reflashing BIOS Chip on omen by hp laptop 17 an104ng
                                            by JoWed
                                            Hello Community,
                                            I recently tried to change the Batterie on my Omen by HP Laptop 17 an104ng and after putting in the new batterie ([Batterie Link](https://www.amazon.de/7xinbox-17-AN0...&keywords=16%2...
                                            07-01-2025, 09:32 AM
                                          • Habble7
                                            by Habble7
                                            Suspected Cause:
                                            Troubleshooting Attempts:
                                            05-22-2025, 07:28 AM
                                          • haitham sharabati
                                            [Request] Clean BIOS dump for HP 15-da2007ne (8XF55EA#ABV) - N4000 - BIOS Lock
                                            by haitham sharabati
                                            Hello engineers 😀,
                                            I’m kindly requesting a clean and unlocked BIOS dump for the following HP laptop, as it’s bricked after flashing SP152727. The system now keeps rebooting, and the original issue was an Administrator / Power-On Password that I can no longer access.😏
                                            🔧 Device Info:
                                            - Model: HP 15-da2007ne
                                            - Product Number: 8XF55EA#ABV
                                            - Serial Number: CND0338P0D
                                            - CPU: Intel Celeron N4000
                                            - EC/BIOS Chip: [Add chip number from the motherboard or BIOS chip]
                                            💀 Problem:😅
                                            - Device shows “Administrator Password”...
                                            Yesterday, 04:54 AM
                                          • Citymin
                                            by Citymin
                                            S/N : 5RNK9FFT70...
                                            08-05-2025, 05:12 AM
