need bios dump for asus u47a rev 2.0thanks
asus u47a bios
by razor_amdWith ASUS, not everything is quite so simple. I will show you my way. It may be longer or harder but it is the right way to do it in my humble opinion.
This is the picture of 3 similar ASUS motherboards, all of them being X555LD...-
Channel: BIOS Requests ONLY!
by DynaxSCHi,
Usually on ASUS boards it worked...-
by AhariHi all,
I...-
by jbonavitaHi, my laptop wont boot at all
Some issues
Things I tried
1- Update / clear ME: Took the non working bios, made a backup, and did this: https://www.badcaps.net/forum/troubl...theory/trouble...-
by kodoxneed original bios dump, original bios has flashed by other technician before me.
attached bios was read from the chip but no display and amperage fluctuating from 0.6A to 0.34 and back to 0.6A.
unit info:
Model: Asus ExpertBook B1400CBA-0711A1235U
S/N: R6NXNZ006657238
CN: 7F6F
Mainboard Code: B1500CBA R2.1...-
- Loading...
