Acer one KAV60 bios needed
  • String2016
    • Nov 2015
    • 2238
    • philippines
    Hi friends!I need a working bios for this model Acer One KAV60 board id:KAV60 LA-5141P REV 1.0 2009-03-05.thanks in advance.
  • sancheti81
    • May 2014
    • 191
    • India
    Re: Acer one KAV60 bios needed
    post backup dump please
    • mcplslg123
      • Jun 2015
      • 7262
      • india
      Backup and try this.
      • String2016
        • Nov 2015
        • 2238
        • philippines
        here is the original can someone fix this or share a working bios
        • String2016
          • Nov 2015
          • 2238
          • philippines
          thanks for the response mcplsig bios is working, but i have problem on the power button switch anyone can help how can i make jumper for this because press power button nothings response, but when i short pin3 and pin4 it turns on,because pin3 have 3.3v.I have attached the image on the power button anyone can help me please
          • JaroTech
            • Mar 2015
            • 351
            Hi, pin 3 is the +3VALW and pin 4 is the ON/OFFBTN#. On the board you could have a diode who is open, follow the trace from the switch to pin 4, you should have 3.3V on the switch also.
            • String2016
              • Nov 2015
              • 2238
              • philippines
              I checked on the switch pin 3 have 3.3v but pin 4 have 17.42v
              • JaroTech
                • Mar 2015
                • 351
                When you push the switch, does the 3.3V on the switch go to zero?
                • String2016
                  • Nov 2015
                  • 2238
                  • philippines
                  on the connector on pin 3 have 3.3v when press power button 3.3v on not goes to zero.on power button no 3.3v
                  • String2016
                    • Nov 2015
                    • 2238
                    • philippines
                    i have attached the image on the switch
                    • JaroTech
                      • Mar 2015
                      • 351
                      There you go, if you don't have 3.3V on the power button, it will not work. Follow the path from the switch to one of the chips, the chip could be open.
                      • String2016
                        • Nov 2015
                        • 2238
                        • philippines
                        the one the chips on the power button?
                        • String2016
                          • Nov 2015
                          • 2238
                          • philippines
                          pin 4 is connected on this chip on power switch but still the same voltage 17.42
                          • JaroTech
                            • Mar 2015
                            • 351
                            You have to follow the path from the switch to one of the chips, not the ribbon cable to the chip, you have to find out why you do not have 3.3v on the switch.
                            • JaroTech
                              • Mar 2015
                              • 351
                              When you find which one, you should have 3.3V on the other pin of this chip.
                              • String2016
                                • Nov 2015
                                • 2238
                                • philippines
                                This chip has no continnuity kn the power button and the 1st pin have 17.42 the ontgrr pin has 0v
                                • JaroTech
                                  • Mar 2015
                                  • 351
                                  What about the other chip?
                                  • String2016
                                    • Nov 2015
                                    • 2238
                                    • philippines
                                    The other chip the second one continuity connected to pin3 and pin 2and 3 of the chip has 3.3v
                                    • JaroTech
                                      • Mar 2015
                                      • 351
                                      What about the voltage of the other pins? Is the third pin of this chip connected to the switch?
                                      • JaroTech
                                        • Mar 2015
                                        • 351
                                        To be sure, on your picture of the board, write down all the voltages of both chips and the flat cable.
