Re: LENOVO V110-15ISK Need Bios
thanks
here is clear me dump... 100% workingLeave a comment:
try..Attached FilesLeave a comment:
This my original BIOS Need HelpAttached FilesLeave a comment:
Re: Need bios bin file for Lenovo V110-15IAP
Desolder the bios,thats your next step.Leave a comment:
Is there anything I can do about it now, or is the board fried?
The laptop is completely unresponsive and dead, and the programmers barely read the bios anymore. Reading works sometimes, but the results look like a jumbled mess to me, and every other action (like ERASE, VERIFY, EMPTY ...) don't work.
Also most of the time when connecting the clip, the PC gives "USB Not Recognized The last USB device you connected to this computer malfunctioned, and Windows does not recognize it" error.
The programmer connection itself doesn't give that error, neither connecting the programmer with a bios from a different laptop...Leave a comment:
Are you using a clip ?Leave a comment:
Well fuck. I think I just shorted something on the mainboard
I tested the laptop after the previous flashing, and it didn't work so I wanted to reflash it using AsProgrammer, but like a fucking genius I forgot to unplug the battery this time before connecting the programmer to usb, and now it's unresponsive, not event those 2 led lights blink anymore, and AsProgrammer or CH341A don't detect the bios properly anymore:facepalm
Is there anything else left to do now?Leave a comment:
Try AsProgrammer software,its a good alternative.Choose CH341A in the hardware tab first,then choose the bios chip manually from the list.
https://www.badcaps.net/forum/showpo...6&postcount=10Leave a comment:
Thanks, but it gives the same error "file length beyond range will be ignored". In fact, it gives the same message even if I try to flash the backup bios. Am I missing something? I used ERASE>BLANK>WRITE>VERIFY in CH341A Programmer, and everything seemed ok, beside the error message when opening the bios files.
Anyway, I ignored the message and wrote the bios anyway, but nothing changed. The laptop is still dead. Only LED4 and LED2 are blinking intermittently.
Maybe an older version of bios would work?
try...extras site LenovoAttached FilesLeave a comment:
Here is my backup.
Thanks in advance guys.Attached FilesLeave a comment:
Better is to post your backup dumpLeave a comment:
Hey guys.
I have a major problem with this lenovo laptop. Windows 10 decided to update the bios by itself, but for some reason, after updating the laptop turned off and I haven't been able to turn it on ever since.
All it does now, is spin the fan for a couple of seconds and then it turns off again. Also the led light is blinking every 2-3 seconds. Sometimes the screen turns on for a second as well, but it's completely grey/white and then it turns off again. If i let the battery connected or the charger plugged in sometimes it looks like it's trying to turn on, repeating the symptoms listed above.
This behavior even happened a few times with the lid closed...
Anyway, the weird thing is that I can't even find an older bios for it anymore. On the official Lenovo site there is only 1 bios file, and it's from this year. This is very weird since I know for a fact there was an older bios (maybe even 2) which Lenovo removed from the site for some reason...
If anyone could help me out with a bios dump for this model it would be very much appreciated. Maybe there still are some older versions of bios for this model...
I'll post the bios backup tomorrow.Leave a comment:
by WahazHello,
I found 3 bios chips on the board, which I read with a bios programmer: two XMC model bios chips and a Winbond model bios chip. Each XMC model bios chip has two partitions named XM25QH128A [3.3V] and XT25F128A [3.3V]. And the Winbond model bios chip has three partitions named W25Q80BL 3.3V, W25Q80xV 3.3V and W25Q80DV 3.3V....-
Channel: BIOS Requests ONLY!
by grimacelordHello there.
I am working on a Lenovo Legion T5-26AMR5 desktop that currently has a corrupt BIOS and I have been unsuccessful thus far in trying to fix it myself.
History:
1. This computer came to me initially with an error message that said "BiInitializeLibrary failed 0xc0000001" or "0135 fan error". It would always be one of the two errors. It should be noted that when it produced the fan error, there was no physical problem with the fans. They were all spinning just fine.
I searched for this error online and discovered...-
by jendkkd jejeSo a couple of years ago i got a bios update through Lenovo Vantage, so i installed it and bricked my whole BIOS, so i couldn't fix it so i put that ideapad in a box, 3 years later i found that one PC and want to recover it to switch from a 2014 hp laptop to this one.
I found a method to recover the BIOS of many lenovo laptops tha consists in pluging in a USB Flash with the BIOS files and power on the laptop with Fn + R keys pressed until fans go loud and start beeping loud, but nothing worked, so i think filename is wrong, i tried naming the bios file as 07WW.BIN, BIOS.BIN, BIOS.fd,...10-11-2024, 03:12 PM -
by mximiliandzGood morning, gentlemen, I hope you can help me with my laptop, I told you that I saved it about 2 years ago because it wouldn't turn on, now I have a ch341a programmer, I made a backup of the bios, I flashed an original downloaded from lenovo and it started, but it turned off after a few minutes, I entered the bios configuration and the brand, model, serial number, windows serial number, etc. did not appear, I request your help, I did everything I found in the forum but I could not solve it, also now it won't start again, it turns on but the fan does not turn, I will share all the information...
by 1g0rHello everyone,
First, the data in brief:
Manufacturer: Lenovo
Model: ThinkPad L15 G3 21C3-0016GE
motherboard: LG4 LT5 ADL RT UMA MB 8L - 448.0PZ26.0011
IC Bios 1: MX77L25650F
IC Bios 2: MX25L25673G
EC Chip: NPCX997KAABX
So far I've been a silent reader, but now I need your help
I bought a laptop. The seller said the bios was locked. I was looking for a way to remove this ban.
I then got the CH341A and pulled the corresponding files from here https://www.badcaps.net/forum/troubl...evices-and-ele...The laptop was brought in with a BIOS problem and a password. After reading the dump, the information was damaged. I ask for help in the BIOS with a clean ME region. Motherboard 213035-1. Serial number: PW+04e998, Type number: 21c3-0016ge - Loading...
