ASUS k550jd MB X550JD REV 2.0 Bios
  • riki_22
    • Jun 2014
    • 72
    • italia
    I search a dump bios for this notebook,
    X550JD REV. 2.0
    CHIP BIOS 25B64BS10
    ITE IT8585E
  • angel-boy
    • 550
    • Romania
    Re: ASUS k550jd MB X550JD REV 2.0
    try this , and i see that you are a new user , and only have post with asking dumps, try to help other to
    • rager007
      • Feb 2016
      • 106
      • Usa
      Re: ASUS k550jd MB X550JD REV 2.0 Bios
      start ok no display black screen
      • peste
        • Dec 2016
        • 13917
        • ROMANIA
        try..
        • samz2021
          • Feb 2021
          • 15
          • lebanon
          Re: Asus k43sd rev: 4.1 bios
          please i need bios asus for x550jd
          • peste
            • Dec 2016
            • 13917
            • ROMANIA
            post the backup of the bios, and clear pictures with the white or green stickers on the motherboard.
            • mcm022006
              • Jan 2015
              • 24
              • romania
              can someone help me repair this bios
              mb x550vd rev 2.0
              • peste
                • Dec 2016
                • 13917
                • ROMANIA
                mb x550vd rev 2.0
                try..
                • husnu16
                  • Jun 2020
                  • 123
                  • Türkiye
                  Originally posted by peste
                  try..
                  Thanks master
                  • appiend96
                    • May 2022
                    • 6
                    • indonesia
                    try..
                    work sir tks
                    • mkdj
                      by mkdj
                      Dear all,
                      10-19-2025, 04:41 AM
                    • razor_amd
                      by razor_amd
                      12-15-2020, 07:07 PM
                    • pirati
                      by pirati
                      10-27-2025, 04:20 PM
                    • DynaxSC
                      by DynaxSC
                      06-14-2024, 03:49 PM
                    • Ahari
                      by Ahari
                      I...
                      08-13-2025, 06:12 AM
