a1466 efi dump cleaning please
  • Diesalweasel
    • May 2016
    • 49
    hi if possible can anyone remove efi please
  • imranromi
    • Jan 2015
    • 1291
    • Pakistan
    Re: a1466 efi dump cleaning please
    Try this.
    • Diesalweasel
      • May 2016
      • 49
      Originally posted by imranromi
      Try this.
      thankyou
      • mkdj
        by mkdj
        Dear all,
        10-19-2025, 04:41 AM
      • loopster
        Need help cleaning ME region on Zbook 17 G1 bios dump
        by loopster
        Hello guys,
        could I please get some help cleaning the ME region of the attached Zbook 17 G1 bios dump (CH341a, neoprogrammer, chip-desoldered, dumped twice, identical checksum)?
        Symptoms, delayed BIOS post (ca. 45 secs.) keyboard not working, touchpad not working, booting linux live, console says "Management engine not configured".
        I tried following the ME firmware cleaning guide, but whatever Flash Image Tool version I try, I get the same error:
        Error 10: Failed to open with processed commands.
        Unable to open file: C:\Users\Elitebook...
        06-16-2024, 09:57 AM
      • howardc64
        by howardc64
        Problem
        08-04-2024, 10:36 PM
      • GeryMix
        Microsoft Surface Pro 4 (1724) SEMM remove from BIOS/UEFI dump
        by GeryMix
        Hello everyone!
        I have a surface pro 4 (1724) with corporate management set up (in this case, I understand it's called SEMM). In the operating system installer (Pro version), after connecting to Wi-Fi, it asks me to enter the company system. If I don't sign in, it won't let me continue (similar to enterprise enrollment on chromebooks). This can be avoided if I install the Home version instead of Pro, and then upgrade to the pro version, but this is not very elegant. I would like the machine to be as it should be in factory condition. That's why I would like someone to remove this restriction...
        04-29-2024, 06:39 AM
      • yura8
        Need BIOS/EFI dump for MacBook Air A1466 2015 EMC 2925 (8gb)
        by yura8
        Hi there! I have not so usual situation...
        I have 2015 MacBook Air A1466 EMC 2925 with 8Gb of RAM. It seams that I've killed it by bad SSD adapter. It starts, cooler works... But no chime, screen is black. SMC reset seams works, NVRAM reset doesnt works...
        My repair guy has checked all possible. It's all ok with power. The last idea - I could kill EFI firmware... So, I need a firmware of EFI to check it. I have a programmer. But I don't have a similar laptop now to download it and compare
        P.S. If you have else any ideas about repair, or you had a similar...
        12-20-2024, 02:31 PM
