Microsoft Surface Pro 4 (1724) SEMM remove from BIOS/UEFI dump
  • GeryMix
    • Apr 2021
    • 16
    • Hungary
    Hello everyone!
    I have a surface pro 4 (1724) with corporate management set up (in this case, I understand it's called SEMM). In the operating system installer (Pro version), after connecting to Wi-Fi, it asks me to enter the company system. If I don't sign in, it won't let me continue (similar to enterprise enrollment on chromebooks). This can be avoided if I install the Home version instead of Pro, and then upgrade to the pro version, but this is not very elegant. I would like the machine to be as it should be in factory condition. That's why I would like someone to remove this restriction from the bios dump.
    Serial: 022127762853
    Thank you!
  • alfredposadas09
    • Aug 2020
    • 342
    • Philippines
    Originally posted by GeryMix
    Hello everyone!
    Thank you!
    here try this first erase the operating system then flash this bios then install new operating system
    • GeryMix
      • Apr 2021
      • 16
      • Hungary
      Unfortunately, the machine does not start with it.
      • m.sabry2110
        • Oct 2017
        • 136
        • egypt
        try
        • GeryMix
          • Apr 2021
          • 16
          • Hungary
          Originally posted by m.sabry2110
          try
          Thanks, you too! This will boot, but the IDs and serial numbers are lost.
          • danito
            • Jun 2016
            • 1259
            • Romania
            Hello everyone!
            Thank you!
            try
            • m.sabry2110
              • Oct 2017
              • 136
              • egypt
              try
              • GeryMix
                • Apr 2021
                • 16
                • Hungary
                Originally posted by danito
                try
                Thanks, you too! The bios you posted is the same as the one posted by m.sabry2110. IDs are lost with this version.​
                • GeryMix
                  • Apr 2021
                  • 16
                  • Hungary
                  try
                  Thanks, you too! The bios you posted is the original bios I posted. There is SEMM locked.
                  • minhdigital
                    • Nov 2022
                    • 766
                    • Vietnam
                    Send to you, try
                    • ArkzG
                      [REQUEST] ASUS TUF A15 FA506NF (2021) - Clean BIOS dump needed (UEFI Password locked)
                      by ArkzG
                      Hey guys, I have an "ASUS TUF Gaming A15 FA506NF (2021)" that's locked with a UEFI password, I need to reprogram the BIOS chip but can't find a clean ".bin" file for this specific model, I've tried the official BIOS updates from ASUS support page, but they're 32MB updaters that don't extract to a usable 2MB .bin file for direct chip programming.
                      What I currently have available:
                      - Model: FA506NF (2021)
                      - BIOS chip: GD25LQ16 (16Mbit/2MB)
                      - Tools: CH341A programmer ready to use
                      Does anyone have either a clean 2MB .bin dump of this model,...
                      09-26-2025, 09:34 PM
                    • Alejandro Jr Diaz
                      Dell Optiplex 3090 SFF UEFI dump request
                      by Alejandro Jr Diaz
                      I need to get a bin/rom file from a Dell bios to modify, I have run into a PFS extractor in this forum. When i run the path it just says "Working... Done!" but no file is created.
                      I need to open it in UEFITool and exe or rcv file is not supported.
                      Model: Dell Optiplex 3090 SFF
                      Service Tag: DQKR0N3
                      Motherboard Model: Q470
                      Here is the link of the uefi/bios:​
                      https://www.dell.com/support/home/en...iplex-3090-sff
                      02-02-2025, 05:53 PM
                    • Ahari
                      by Ahari
                      I...
                      08-13-2025, 06:12 AM
                    • mkdj
                      by mkdj
                      Dear all,
                      10-19-2025, 04:41 AM
                    • Habble7
                      by Habble7
                      Suspected Cause:
                      Troubleshooting Attempts:
                      05-22-2025, 07:28 AM
