I have notebook, that has a problem "HP bios version mismatch". Bios tries to update himself, but it's in a loop. If anyone can correct Bios, to the right version. Ive tried to flash it from antoher 840 G3, and thought i can change then the serial, but, it doesent eaven shows hp logo - blank screen.
HP EliteBook 840 G3
L3C65AV
5CG82188D9
Boot Block Version: 01.44
System BIOS Version: 01.47
I think i need system BIOS version 01.44 ? If anyone can help me.
Thank you
bios dump elitebook 840 g3
Hi, thanks for your assistance hoaca388 , I was absent for some days but now I'm back and I've just tried it and it is flashing White and Amber Led continuously and NOT powering OnLeave a comment:
Thanks for help anyway.....Leave a comment:
Try again with a clean me
if no luck than clean ram slot with IP & brush,
Resold ram slot pins cold solder also cause for no ram detect
remove data & clock switching ic make a jumper in between both data and clock line
Attached FilesLeave a comment:
Hello
I think i have corrupted BIOS can someone look at it?
Laptop gives 3 long beeps and 2 short wich means faulty memory but its not. RAM work on other laptops ok.
840 G3 Elitebook
Serial:
5CG7362P9J
Motherboard:
6050A2892401-MB-A01Attached FilesLeave a comment:
Can someone unlock it for me please.Leave a comment:
It is currently showing as HP EliteBook 850 g3 but i want it to show as HP EliteBook 840 g3 instead and also have the SN i assign to it.
THANKS.Leave a comment:
Using BIOS Config Utility, I got an Access Denied error as well. Is there anything I am missing?
I reverted back to the 850 g3 bios bin before attempting the BCU and it is stated I can't change the model because it is Read-only of which i still tried anyways with no luck . Right now, I am stuck. If i can get a working BIOS for 840 g3, it will be useful. One i have that works shows up as ZBook 14 G3.Leave a comment:
BIOS guides, methods, resources and tools
https://www.badcaps.net/forum/troubl...rces-and-tools⤵
3. Password removal by laptop brand -
I have motherboard HP ProBook 840 G3 ,
6050A2892401-MB-A01,
SN PFKZU00WB5659K
My bios is locked , can anyone please send me unlocked bios or unlock my bios in attachment?
My old locked bios is in attachment.
Thnx.Attached FilesLeave a comment:
Hi, Please i need help modifying a BIOS bin for HP Elitebook 840 g3
I bought a replacement motherboard which happens to be for HP Elitebook 850 g3 and i want to use it to replace a faulty HP Elitebook 840 g3 motherboard. I have attempted to transfer the model name and serial number from the faulty 840 g3 motherboard to the 850 g3 motherboard but it turned out unsuccessful. I tried using my knowledge of changing Apple SSN, HWC and Checksum on it and I was able to input the correct serial number and model name but wasn't able to rectify the checksum error. After putting the BIOS Chips back on the motherboard and powering on, it displayed CMOS reset page upon first boot and after pressing 'ENTER' key to restart, it didn't display again and started fan spinning.
I will be glad if anyone here can assist me in sorting it out or direct me on how to fix the checksum for it.
I have attached the original untouched BIOS bin for the 850 g3 and the modded BIOS [16mb and 8mb] as well. I have also attached the error i got from using ME Analyzer too
Model: HP Elitebook 840 g3
S/N: 5CG71004S9
ProdID: Y3R95UC#ABA
Board No: 6050A2892401-MB-A01
Thanks.
Hello, can someone help me clean my bios, it doesn't send a video
HP 840 G3
sn: W3G52UP
product: L3C65AV
board: 6050a2892401-MB-A01
Thank you
S/N: 5CG71004S9
ProdID: Y3R95UC#ABA
Thanks.
by Habble7The Samsung S49CG934SU monitor does not power on - no LED indicator activity and no response to power button. However, when 21V power is connected, it immediately draws 0.8A of current with no display output. The motherboard processor gets warm, and there is continuous reading activity from the W25Q128BV BIOS chip.
Suspected Cause:
Troubleshooting Attempts:
by DynaxSCHi, I have an MSI PRO B660M-G DDR4 board with damaged BIOS and i need a bios dump from a real board, along with MAC, UUID and Serial Number info (eg. a BIOS screenshot and pictures from the board stickers).
I need to reconstruct the bios on my board, based on another bios image form a real board - meaning a bios image containing MAC address, UUID and Serial number. A stock BIOS is not suffiecient, as it is impossible to discover where the MAC, UUID and SerialNumber are stored. Tried with a similar board, but there are too much differences, and the stock BIOS is missing a lot of...11-17-2023, 10:56 AM -
by mediadoctorCan you help me upload Bios dump from HP EliteBook 845 G8 with AMD CPU and Touchscreen please 🤝
Channel: BIOS Requests ONLY!
by GuestHello,
I have an EliteBook 850 G5. After a Windows update, including a BIOS update, the notebook turns on, but the screen remains black, and the fans spin at high speed—nothing else happens.
I assume the BIOS update failed, so I searched for the BIOS chip.
I found a Winbond chip located between the RAM and the hard drive, which has a size of 32 MB.
However, the BIOS update available on HP's website is only 17 MB in size. I used the update version that was previously installed when the notebook was still working.
Can the corrupted...-
by MDSIHello,
I'm requesting a full BIOS dump (including EC firmware) for an HP OMEN 17-an012nf laptop.
Details:
Model : HP OMEN 17-an012nf
Motherboard Part Number : DAG3BAMBAF0 REV : F
Serial Number (S/N) : 5CD7280D51
BIOS chip : Winbond W25Q64VSIQ
Programmer : EZP2023+
Issue : The motherboard is not powering on. Only the 5V rail is present. The 3.3V rail is missing because EN1 on the SY8286B remains stuck at 0V. This signal is driven directly by the EC/SIO. I replaced the 3.3V regulator and confirmed it's working.
I already...-
- Loading...
