no start. the indicator light changed to flashing orange
bios dump elitebook 840 g3
Attached FilesLeave a comment:
First boot press f10 reset bios to factory defaults and exit.
use BCU to fill these DMI info:
Serial Number: 5CG8234BST
Product #/SKU: L3C67AV
CT Number: PFLAA00WBAX0QX
Description: HP EliteBook 840 G3
BuildID: 15WWCSET601#SABY#DABY
Feature Byte: 3X476J6S6b757B7H7M7Q7W7m7saBaEapaqauawbUbhcAdUdpdqfSgd.Tm
MAC Address : 10:62:E5:97:9B:BBLeave a comment:
MAC Address : 10:62:E5:97:9B:BBAttached FilesLeave a comment:
HELLO , i Need your help please.
HP ELITEBOOK 840G3
MB : 6050A2892401-A01
sn 5CG8234BST
RCUnlocker, HPUnlocker
it didn’t work, the board doesn’t start
HP EliteBook 840 G3 Notebook PCLeave a comment:
HELLO Guys , i Need your help please.
HP ELITEBOOK G3
sn/5CG7471RJL
REMAINS BLACK ? THAT'S AN BIOS ISSUE FOR SURE.
THX U FOR HELPLeave a comment:
hello 840 G3 6050a2822301-mb-a01
pls fix bios just turn fan
sn 5CG834541ZAttached FilesLeave a comment:
HP EliteBook 840 G3 Base Model Notebook PCLeave a comment:
corrupted bios you can fix plss
hp g3 840
SN-5CG70144VNAttached FilesLeave a comment:
Good morning
Sorry I forgot half of the things.
I read a lot on your forum, can I just unsolder the main chip and reprogram it with your HPunlocker software by dragging?
Is the password found on the main chip not on the EC?
THANKSLeave a comment:
Please read the rules.Serial number,backup etc..
https://www.badcaps.net/forum/troubl...before-posting -
Good morning
I will need the bios file for an elitbook 840 G3 with motherboard number 6050A2892401-MB-A01 with the two files Main + EC
I have notebook, that has a problem "HP bios version mismatch". Bios tries to update himself, but it's in a loop. If anyone can correct Bios, to the right version. Ive tried to flash it from antoher 840 G3, and thought i can change then the serial, but, it doesent eaven shows hp logo - blank screen.
HP EliteBook 840 G3
L3C65AV
5CG82188D9
Boot Block Version: 01.44
System BIOS Version: 01.47
I think i need system BIOS version 01.44 ? If anyone can help me.
Thank youLeave a comment:
HP EliteBook 840 G3
L3C65AV
5CG82188D9
Thank you
Hi, thanks for your assistance hoaca388 , I was absent for some days but now I'm back and I've just tried it and it is flashing White and Amber Led continuously and NOT powering OnLeave a comment:
by Habble7The Samsung S49CG934SU monitor does not power on - no LED indicator activity and no response to power button. However, when 21V power is connected, it immediately draws 0.8A of current with no display output. The motherboard processor gets warm, and there is continuous reading activity from the W25Q128BV BIOS chip.
Suspected Cause:
Troubleshooting Attempts:
by DynaxSCHi, I have an MSI PRO B660M-G DDR4 board with damaged BIOS and i need a bios dump from a real board, along with MAC, UUID and Serial Number info (eg. a BIOS screenshot and pictures from the board stickers).
I need to reconstruct the bios on my board, based on another bios image form a real board - meaning a bios image containing MAC address, UUID and Serial number. A stock BIOS is not suffiecient, as it is impossible to discover where the MAC, UUID and SerialNumber are stored. Tried with a similar board, but there are too much differences, and the stock BIOS is missing a lot of...11-17-2023, 10:56 AM -
by mediadoctorCan you help me upload Bios dump from HP EliteBook 845 G8 with AMD CPU and Touchscreen please 🤝
Channel: BIOS Requests ONLY!
by GuestHello,
I have an EliteBook 850 G5. After a Windows update, including a BIOS update, the notebook turns on, but the screen remains black, and the fans spin at high speed—nothing else happens.
I assume the BIOS update failed, so I searched for the BIOS chip.
I found a Winbond chip located between the RAM and the hard drive, which has a size of 32 MB.
However, the BIOS update available on HP's website is only 17 MB in size. I used the update version that was previously installed when the notebook was still working.
Can the corrupted...-
by MDSIHello,
I'm requesting a full BIOS dump (including EC firmware) for an HP OMEN 17-an012nf laptop.
Details:
Model : HP OMEN 17-an012nf
Motherboard Part Number : DAG3BAMBAF0 REV : F
Serial Number (S/N) : 5CD7280D51
BIOS chip : Winbond W25Q64VSIQ
Programmer : EZP2023+
Issue : The motherboard is not powering on. Only the 5V rail is present. The 3.3V rail is missing because EN1 on the SY8286B remains stuck at 0V. This signal is driven directly by the EC/SIO. I replaced the 3.3V regulator and confirmed it's working.
I already...-
- Loading...
