Need thinkpad l410 bios dump
  • Siddig
    • Jun 2017
    • 264
    • Sudan
    Hi
    need thinkpad l410 bios dump
    dagc2amb8 i 0 (8l)
    thanks
  • imranromi
    • Jan 2015
    • 1291
    • Pakistan
    Re: Need thinkpad l410 bios dump
    Originally posted by Siddig
    Hi
    dagc2amb8 i 0 (8l)
    thanks
    post old bios.
    • Siddig
      • Jun 2017
      • 264
      • Sudan
      Originally posted by imranromi
      post old bios.
      this is old bios
      • imranromi
        • Jan 2015
        • 1291
        • Pakistan
        this is old bios
        Try this.
        • Siddig
          • Jun 2017
          • 264
          • Sudan
          Thank you dear
          • red_apache
            • Mar 2014
            • 9
            • indonesia
            Try this.
            bios tested for me
            thanks alot
            • mohammed mohan
              • Nov 2017
              • 210
              • F12
              Thank you
              Mohammed Mohan
              • Ahari
                by Ahari
                I...
                08-13-2025, 06:12 AM
              • mkdj
                by mkdj
                Dear all,
                10-19-2025, 04:41 AM
              • Habble7
                by Habble7
                Suspected Cause:
                Troubleshooting Attempts:
                05-22-2025, 07:28 AM
              • Joluvillas
                Lenovo ThinkPad L15 Gen 1 i7 (20U4) Bios and EC dump needed
                by Joluvillas
                Hi all! I was reading on tutorials how to flash a bios to remove password from a bios, and I ended up reading the EC chip instead of the main bios chip, it only gave me a .bin file of 1,024kb, I learned later that that is the EC chip not the main bios chip (I should have read the tutorials here instead before attempting anything, my bad), I went to flash the original backup, the 1,024kb size file into the same chip and laptop is not powering up anymore. I may have screwed the chip or even the motherboard (Hopefully not), I am trying to see if there is a fix before I discard it. I had a couple...
                06-18-2024, 10:35 PM
              • haitham sharabati
                [Request] Clean BIOS dump for HP 15-da2007ne (8XF55EA#ABV) - N4000 - BIOS Lock
                by haitham sharabati
                Hello engineers 😀,
                I’m kindly requesting a clean and unlocked BIOS dump for the following HP laptop, as it’s bricked after flashing SP152727. The system now keeps rebooting, and the original issue was an Administrator / Power-On Password that I can no longer access.😏
                🔧 Device Info:
                - Model: HP 15-da2007ne
                - Product Number: 8XF55EA#ABV
                - Serial Number: CND0338P0D
                - CPU: Intel Celeron N4000
                - EC/BIOS Chip: [Add chip number from the motherboard or BIOS chip]
                💀 Problem:😅
                - Device shows “Administrator Password”...
                08-07-2025, 04:54 AM
