bios dump for Asus x555LP rev 1.1
  • danieltoader69
    • Apr 2013
    • 39
    • romania
    HI !
    Need bios for Asus X555LP rev 1.1. I find dump for X555LPF but not working.
    Thanks in advance
  • cacla
    • Apr 2015
    • 444
    Re: bios dump for Asus x555LP rev 1.1
    I found 2 PLS test them
    • newnoob
      • Sep 2016
      • 17
      • Italy
      work for me...thanks from italy (i'm from debar)
      • eghbalm
        • Nov 2016
        • 8
        • iran
        try this
        • razor_amd
          by razor_amd
          12-15-2020, 07:07 PM
        • DynaxSC
          by DynaxSC
          06-14-2024, 03:49 PM
        • Ahari
          by Ahari
          I...
          08-13-2025, 06:12 AM
        • jbonavita
          by jbonavita
          Some issues
          Things I tried
          04-29-2025, 09:38 PM
        • ArkzG
          [REQUEST] ASUS TUF A15 FA506NF (2021) - Clean BIOS dump needed (UEFI Password locked)
          by ArkzG
          Hey guys, I have an "ASUS TUF Gaming A15 FA506NF (2021)" that's locked with a UEFI password, I need to reprogram the BIOS chip but can't find a clean ".bin" file for this specific model, I've tried the official BIOS updates from ASUS support page, but they're 32MB updaters that don't extract to a usable 2MB .bin file for direct chip programming.
          What I currently have available:
          - Model: FA506NF (2021)
          - BIOS chip: GD25LQ16 (16Mbit/2MB)
          - Tools: CH341A programmer ready to use
          Does anyone have either a clean 2MB .bin dump of this model,...
          09-26-2025, 09:34 PM
