bios programmer
  • akande
    • Dec 2017
    • 278
    • Nigeria
    bios programmer
    i need a good bios programmer, which should i go for? i havh 3421a black type but am not ok with it
    • 21197
    Re: bios programmer
    A good cheap programmer user by many repair shops is the MiniPro TL866 .There are 2 versions available,the TL866A ,and TL866CS .
    • Pascal Komlassan
      • Jan 2017
      • 809
      • TOGO
      Re: bios programmer
      (TL866CS) YES
      • akande
        • Dec 2017
        • 278
        • Nigeria
        Re: bios programmer
        Originally posted by Pascal Komlassan
        (TL866CS) YES
        thanks for reply , many of this type on ali express can u give exat on plz
          • 21197
          Re: bios programmer
          No, can`t give you exact one, it depends which adapters you need. Some of the TSOP adapters sold by some sellers aren`t original ,if you need those adapters buy from reliable source,if you can use ebay buy from sunwenjun (seller name).
          • jasko_jacker
            • Oct 2014
            • 1137
            • italy
            Re: bios programmer
            I use EZP2010 not EZP2013 and work very fine
            • mcplslg123
              • Jun 2015
              • 7262
              • india
              Re: bios programmer
              You can consider RT809F. Works well. can program ene kbc also.
              • dskall
                • Oct 2016
                • 2905
                • usa
                Re: bios programmer
                Might look at this. Will also program nand flash
                https://www.ebay.com/itm/302387526194
                • Pascal Komlassan
                  • Jan 2017
                  • 809
                  • TOGO
                  Re: bios programmer
                  https://www.amazon.com/gp/slredirect...d_rd_w%3DYdTSp
                  • Pascal Komlassan
                    • Jan 2017
                    • 809
                    • TOGO
                    Re: bios programmer
                    Where can I buy this?
                    • wadim_m
                      • Feb 2018
                      • Latvia
                      Re: bios programmer
                      for many notebook bios chip:
                      https://www.ebay.com/itm/CH341A-Seri...8hJqRqNukjoqQw
                      • wadim_m
                        • Feb 2018
                        • Latvia
                        Re: bios programmer
                        I have, also I am still happy :
                        https://www.ebay.com/itm/Universal-U...EAAOSwYHxWOFkv
                        • wadim_m
                          • Feb 2018
                          • Latvia
                          Re: bios programmer
                          full complete from Aliexpress :
                          https://www.aliexpress.com/item/High...ceBeautifyAB=0
                          • sureshbobby
                            • Mar 2015
                            • 137
                            • India
                            Re: bios programmer
                            Hi bro
                            Dont buy tl866 buy RT809F or if you can afford Go with RT809H
                            • Pascal Komlassan
                              • Jan 2017
                              • 809
                              • TOGO
                              Re: bios programmer
                              Originally posted by sureshbobby
                              Hi bro
                              okay i will try thanks
                              • STKR123
                                The right BIOS Programmer - The right software (HP Elitebook 820 G1, 840 G2) no soldering, EC, DMI, ME
                                by STKR123
                                Greetings badcaps community,
                                I havent done this for a long time and want to start it all again, after some evil and annyoing illness.
                                So I apologize in advance, if some phrases might sound a bit like gibberish or illogical to you.
                                Im trying my best to fully describe what I plan to achieve and hope I was choosing the right sub-forum for my new adventure.
                                I have a Elitebook 820 G1 and a Elitebook 840 G2 here.
                                These ask for a password when entering the BIOS, but boot just fine from the internal SSD.
                                I learned that desoldering...
                                10-29-2024, 06:03 AM
                              • hotcrossedbuns999
                                M715q Desktop (ThinkCentre) - Type 10M3 - Request bios chip location and useable bios for use with CH341A Programmer.
                                by hotcrossedbuns999
                                My pc updated bios through Windows Update and I was greeted with BLACK SCREEN WITH CPU FAN MAX SPEED. I don't think there is even a screen signal, because it triggers my monitor for a couple seconds and then the monitor turns off. I tried the other outputs as well.
                                1. I tried clearing bios, resetting bios, removed the CMOS battery, removed m.2 ssd, wifi, and ram. Still black screen with CPU fan blasting.
                                2. I tried using the Lenovo BIOS CD and BIOS USB, but neither worked. At least I couldn't get anything to work.
                                3. I could only locate two chips that look like bios chips. Could someone verify this
                                01-03-2025, 12:32 PM
                              • macabook
                                by macabook
                                🧩 Initial Issue
                                07-24-2025, 02:17 PM
                              • zlr8r
                                looking for fully extracted by programmer Bios for a Dell Inspiron 17 (7786)
                                by zlr8r
                                looking for a fully extracted (by programmer) Bios for a Dell Inspiron 17 (7786) v.1.09 or newer, so I can compare it with my own bios to check for corruption.
                                cheers
                                Dell Inspiron 17 (7786) Laptop
                                Service Tag: 5J0NHT2
                                Bios: 1.9.0
                                MOBO: RO 15 17 WHL 2GB MB / 18706-2
                                Attached;
                                1. My saved bios using a programmer
                                2. Dells Bios updater .exe (v1.16)
                                3. Dells Bios recovery file
                                4. What I got when i tried to extract the main bios .bin file from Dells Bios v1.16 exe/rcv using some .py script i found online.
                                5. Image of ME...
                                12-18-2023, 03:08 PM
                                by Vesko356
                                08-11-2023, 03:27 AM
