Samsung NP-R580-JS03ZA bios dump required
  • ScorpioMan86
    • Dec 2016
    • 97
    • South Africa
    Hi Guys i need a bios dump for the following laptop
    Motherboard model number is BREMEN-M REV:1 (091217)-6
    Thank you
  • ScorpioMan86
    • Dec 2016
    • 97
    • South Africa
    Re: Samsung NP-R580-JS03ZA bios dump required
    Here is the current dump which has a bios password that i need removed
    • ScorpioMan86
      • Dec 2016
      • 97
      • South Africa
      Anyone ?
      • sourcebf
        • Jul 2016
        • 433
        • N/A
        try this ..........
        • ScorpioMan86
          • Dec 2016
          • 97
          • South Africa
          Originally posted by sourcebf
          try this ..........
          You sir are a legend, laptop working 100%. Thank you
          • memo adam
            • Jun 2020
            • italy
            sourcebf thank you
            • tojikatonoji
              • Sep 2017
              • 19
              • türkiye
              Thank you
              • Znuble
                • Sep 2020
                • 4
                • Norway
                Hi guys.
                I think I corrupted the bios on my samsung R580-JS03SE, as I tried to update it (the bios) from the samsung pages. During the process, it went black, and has not shown any signs of life since then, only a slight flash on the hdd led, and the fan going.
                I have tried to reset the bios buy removing the tiny battery on the motherboard for a few minutes, but still no action. I have also tried some usb-stick activitaion, with no succsess.
                The motherboard is Bremen 1.1, and I have downloaded the file presenteted above here, but how do I "flash" it into the bios?
                Gratefull for any help!
                Thank you!
                • peste
                  • Dec 2016
                  • 13853
                  • ROMANIA
                  Originally posted by Znuble
                  Hi guys.
                  Thank you!
                  you need an SPI programmer (ch341a, TL866a), open the laptop, remove the bios chip, read it with the programmer, make a copy of the original and check it with the HxD program, post it here, someone will help you and restore your bios. .more information and video can be found on the net ..
                  https://www.youtube.com/watch?v=DWWigscuQDY
                  • Znuble
                    • Sep 2020
                    • 4
                    • Norway
                    Thank you very much for answer!
                    Oh, my! This was very complicated! Is it not possible to flash it from a usb-stick?
                    • peste
                      • Dec 2016
                      • 13853
                      • ROMANIA
                      not...
                      • Znuble
                        • Sep 2020
                        • 4
                        • Norway
                        Thank you, for answer!
                        Hm... maybe I rather should buy a used motherboard on ebay? Do you think any model of Brenmen M -series will fit? Is upgrade a possibility here? f.i. cpu and/or capability of more ram? (mine is 8, upgraded from 4)
                        • peste
                          • Dec 2016
                          • 13853
                          • ROMANIA
                          maybe it would be better to try at a workshop that deals with what is going on in your area..for someone who is good it is not a big deal to rewrite your bios ..
                          • Znuble
                            • Sep 2020
                            • 4
                            • Norway
                            OK, thank you again!
                            Regards.
                            • chemseddine
                              • Jul 2017
                              • 34
                              • algeria
                              thankssssssssssss
                              • reset1986
                                • 308
                                • italia
                                hello everyone I have this samsung r580 with motherboard
                                bremen-m rev 1.0 (091112)-5
                                I get a black screen when it turns on, the fan can be heard but
                                I have no post I attach backup​
                                thanks
                                  • 22192
                                  thanks
                                  Thread merged. Post the serial number..................... https://www.badcaps.net/forum/troubl...before-posting
                                  • reset1986
                                    • 308
                                    • italia
                                    ZNCM93AZ100182B Thanks
                                    • Habble7
                                      by Habble7
                                      Suspected Cause:
                                      Troubleshooting Attempts:
                                      05-22-2025, 07:28 AM
                                    • Citymin
                                      by Citymin
                                      S/N : 5RNK9FFT70...
                                      08-05-2025, 05:12 AM
                                    • jeewantha
                                      Samsung NT-R580 Bios Dump Required
                                      by jeewantha
                                      Hi Guys,
                                      I need a bios dump for the following laptop.
                                      Samsung NP-R580
                                      Motherboard : BREMEN-M REV:1.0 (091112)-5
                                      Serial Number : BA68-05578A 20
                                      Thank you​...
                                      05-20-2025, 05:03 AM
                                    • Ahari
                                      by Ahari
                                      I...
                                      08-13-2025, 06:12 AM
                                    • Kjell
                                      Samsung Series 9 - BIOS issue
                                      by Kjell
                                      After installing Linux, I can no longer enter the BIOS of my Samsung Series 9 (NP900X3C) laptop. When pressing [F2] during boot I simply get a black screen. Same thing when pressing [F10] and choosing "Setup" from the "App Menu" tab. Apparently this is a relatively common issue with Samsung laptops of that generation, but unfortunately i haven't been able to resolve the issue (yet).
                                      Things i've tried so far; reinstalled Windows 10, checked for redundant boot entries, tried to factory reset using the emergency keyhole, attempted to clear the NVRAM by physically...
                                      08-01-2025, 09:15 AM
