need HP 14-am015TX bios
  • cyngo
    • Jun 2015
    • 219
    • Indonesia
    need bios dump hp 14-am015tx DINERINL 6050A2822501 A01, please
  • imranromi
    • Jan 2015
    • 1291
    • Pakistan
    Re: need HP 14-am015TX bios
    Send old bios and problem what?
    • cyngo
      • Jun 2015
      • 219
      • Indonesia
      All voltage ok, power led on, but can't power on (not switch on).
      acin 3.3V
      pin 8 of ic bios 3.3V
      voltage on power switch 3.3V
      • cyngo
        • Jun 2015
        • 219
        • Indonesia
        backup bios
        • imranromi
          • Jan 2015
          • 1291
          • Pakistan
          Originally posted by cyngo
          backup bios
          try this same bios bid you old bios file.
          • cyngo
            • Jun 2015
            • 219
            • Indonesia
            thanks for your response. I've tried with this file but no change. whether the damage is not on the bios?
            do I need to flash EC IT8987E?
            • Ahari
              by Ahari
              I...
              08-13-2025, 06:12 AM
            • mkdj
              by mkdj
              Dear all,
              10-19-2025, 04:41 AM
            • Habble7
              by Habble7
              Suspected Cause:
              Troubleshooting Attempts:
              05-22-2025, 07:28 AM
            • haitham sharabati
              by haitham sharabati
              Hello engineers 😀,
              🔧 Device Info:
              - Model: HP 15-da2007ne
              - Product Number: 8XF55EA#ABV
              - Serial Number: CND0338P0D
              - CPU: Intel Celeron N4000
              💀 Problem:😅
              08-07-2025, 04:54 AM
            • Citymin
              by Citymin
              S/N : 5RNK9FFT70...
              08-05-2025, 05:12 AM
