asus d550ma bios dump
  • OZMEN55
    • Aug 2017
    • turkey
    hii
    Can't find a working bios for:
    asus D550MA bios dump ı need help me
  • cacla
    • Apr 2015
    • 442
    Re: asus d550ma bios dump
    Pls give me sn for this notebook
    • mcplslg123
      • Jun 2015
      • 7262
      • india
      Originally posted by OZMEN55
      hii
      Post your old bios here. There are many members who can help you.
      • rioreno
        • Feb 2009
        • 540
        • Indonesia
        hii
        d550ma same with x551ma ...
        Please check your board code... it should x551ma rev2.0 board..
        if am right, many thread here about x551ma bios..
        • DynaxSC
          by DynaxSC
          06-14-2024, 03:49 PM
        • grimacelord
          Trying To Find UUID In BIOS Dump - HP 14-dq0055dx
          by grimacelord
          This laptop is the same laptop I was working on in this thread and I wasn't sure if I should post a new topic or post in that thread because I already solved the issue that thread was discussing and this is a completely different issue although it is dealing with the same laptop. I decided to make a new thread since it's a new issue, but please move if I made a mistake.
          Motherboard model number: DA0PAMB46A1 REV: A
          Secondary motherboard model number: 0PAB
          SKU: 685K4UA
          Serial number is: 5CD3223BJP
          Recently reflashed this laptop with latest BIOS and once...
          05-07-2024, 08:06 AM
        • jbonavita
          by jbonavita
          Some issues
          Things I tried
          04-29-2025, 09:38 PM
        • Habble7
          by Habble7
          Suspected Cause:
          Troubleshooting Attempts:
          05-22-2025, 07:28 AM
        • Anchar777
          ASUS P1412CE need BIOS DUMP
          by Anchar777
          Sorry for creating a second post, I didn't understand how to fix the error in the message. I need help, laptop ASUS P1412CE (P1411CEA-EK0395X) SN: N4NXCV033901146. There was a failure during BIOS flashing, and the laptop stopped turning on. The original, non-working BIOS is attached. Unfortunately, I was unable to correctly generate the BIOS from what is presented on the Asus website. Help me make a dump. Thank you....
          06-26-2025, 03:39 AM
